Block heater apparently not working
Discussion in 'Gen 2 Prius Technical Discussion' started by JimboK, Oct 2, 2007.
  1. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    <div class='quotetop'>QUOTE(JimboK @ Oct 7 2007, 06:40 PM) [snapback]522568[/snapback]</div>
    It was a general "hint" for anyone with a similar situation.
  2. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    <div class='quotetop'>QUOTE(Rae Vynn @ Oct 15 2007, 09:20 AM) [snapback]525839[/snapback]</div>
    I put a multi-plug with an embedded light on the end of the extension where the ebh plugs in. That way I know for a fact when current is going to the ebh.
  3. Errel
    Errel New Member
    24
    Sorry if this is a different topic but :(
    Does anyone knows how to turn off the "engine maintainance" light off? This is the light that turns on
    when the Prius need an oil change.
    Please help
    Thank you :)
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(Errel @ Oct 15 2007, 01:00 PM) [snapback]525913[/snapback]</div>
    Yes, it is completely off topic. In the future please first do a search for your subject. If you can't find it already listed (you should, this has come up dozens of times) then start a new thread in an appropriate forum.
    Turn on the car and make sure your Odometer is on the main Odometer reading (not trip A or trip B)
    turn off the car. Press and hold the ODO button then hit the Power button twice (foot off brake) while continuing to hold the ODO button. Look at the dash display. You'll see dashes where the odometer reading should be, then the dashes will tick away as you hold the odo button, it'll flash and display the correct odometer reading and you're done. Shut down or start and go as you desire.
  5. rokibler
    rokibler Member
    88
    31
    Cabin John, Md.
    My EBH failed in the spring of 2009. Thanks to this and other posts, I knew what to look for. It turns out the cord was the culprit. But I can't figure out exactly where the cord failed. I suspect it is the female end of the cord that connects to the heater coil. The center socket seems to be missing or very thin or perhaps just burned up. I checked it with a volt meter and the ground connection is not working. I am willing to send the old cable to anyone on Priuschat who wants to do further examination. I bought a second complete EBH kit and replaced the cable and now its back in business.
    Thanks to you Priusheads for your help and recommendations.
    :cheer2:
  6. PaulHS
    PaulHS Member
    200
    SE PA
    Evan, a couple questions. You've apparently repaired your EBH several times. Has the problem always been the same; a broken wire at the male plug end? You've also mentioned a brittle plug at the heater end. Has this occurred more than once? When it occurred, are you sure there was no degradation of the block temperature before the wire failure?
    My EBH has, over the last four months, gradually lost its effectiveness. Current and Resistance measurements read ok, but the scangauge now reads no more than 107 deg F when the car is started in the morning. The heater core appears to be dying. The only other possibility might be loss of heat transfer to the block because the grease has dried up, but this appears unlikely. A search reveals no other complaints of this symptom; by far the broken wire is the typical failure.
    Has anyone else experienced a failure like this?
  7. efusco
    19,891
    1,196
    Nixa, MO
    Yes, it's always been the same problem. Never had the core burn out. Was on the first for about 2-3 years and have been on the current one for about 2 years.
    I'd bet the reason you're seeing lower engine temps is b/c the weather is getting colder. We're probably measuring different things, but I see as high as 145F or so in the summer and as low as 110 in the winter with the EBH.
    Perhaps you can graph the ambient temp vs ICE temp for a few weeks and see if that's the correlation. I suspect that when the core burns out it'll be catstrophic and an all-or-nothing problem. I do think the dried out thermal transfer grease is a factor, but it seems that that dries out pretty quickly.
  8. PaulHS
    PaulHS Member
    200
    SE PA
    Thanks for the quick reply. Yes, the temps are getting colder, especially the last week which has been unseasonably wet and cold. But I first noticed the greatest drop in engine temp (I use my EBH year-round) from 130 deg F in the second half of July, about a 15 deg F drop. Since then, further drops in morning engine temps have been minor, and may be due to colder weather. Maybe the EBH failure was more catastrophic than I thought, and occurred in the summer. Hmm...
    When (or if) we see a dry, warm day again before winter, I'll get under the car and check the grease, the core and the core plug.
  9. efusco
    19,891
    1,196
    Nixa, MO
    Better have a replacement cord and core ready then. There's no way to check the core and grease without first unplugging the orange core plug...and that will disintegrate if you try to unplug it.
    I suggest you simply live with it unless and until it becomes non-functional--or so impaired as to not provide benefit.
  10. PaulHS
    PaulHS Member
    200
    SE PA
    Yes, that's the reason for asking about your experience with the brittle core plug, to find out how frequently or quickly it breaks down. I am prepared with a replacement kit, just in case. Thanks, Evan, for sharing your knowledge.
  11. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Up here, we are lucky to get 2 winters out of a plug
  12. PaulHS
    PaulHS Member
    200
    SE PA
    What is the failure mode, jayman? Broken wire? Burned out element? Brittle core socket?
    TIA
  13. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Well, after 2 and half years of daily use, the EBH on my car decided to quit working. A quick check with a multimeter found it open circuit. I had wrapped the male plug end with two layers of wire loom to prevent it from bending too much when I installed it. I guess that didn't help much. :(
  14. Mendel Leisk
    42,366
    I've noticed the plug is kind of warm after a couple of hours use, with ours. On our 2010 I've had to splice in a new cord/plug one, but that was due my forgetting to unplug: it got pulled out, dragged on the road, and so on.
    With a previous Civic Hybrid, the block heater cord just died, a couple of times I think. Could be the cord gauge just isn't sufficient for 400 watts, day after day?
  15. 2009Prius
    2,705
    512
    63
    Update: just got it fixed last night. It was a break right at the base of the stress relief rubber accordion thingy.
