Block heater failed
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mendel Leisk, Sep 24, 2019.
  1. Mendel Leisk
    42,346
    I use an extension cord with outlet like this:
    As opposed to this:
    And yeah, you want to loop the extension cord around something strong, and verify the pull-out tension is not much. Just in case.
  2. Mendel Leisk
    42,346
  3. Mendel Leisk
    42,346
    New block heater installed today. Did not remove wipers etc: from above unbolted a few cable brackets, in particular the black one that's pretty much where the block heater needs to be, to go in.
    Then from below, got it started, but it sorta hung up, would not go further. Eventually tried tapping with a 1/2" ratchet extension, but still wouldn't go further.
    Finally tried using that extension to push the cable bracket up a little more outa the way, and that was the trick: in it went, the clip clicked.
    I used a bit more than half of the heat transfer grease, seemed thick enough, and seemed like if I added more it would have just scraped off on the way in.
    Pre-attached the wiring harness, which made it kinda cumbersome, but probably best.
    Also, applied the grease after a dry insert, at the last second to avoid getting it all over everything, and/or attracting grit.
    Car was raised and underpanel completely off.
    Robert Holt, dig4dirt and Raytheeagle like this.
  4. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    Glad to see you went the DIY route for this re-install.
    I have been seriously considering one for each Gen3 and "c" (actually since I purchased both 5 yrs ago)
    I noticed the "c" looks cake, and the Gen3 looked terrible, but nice post on that vid
    to show exactly where it is, and really am gonna think more on this EBH now.
    My Gen3 has to start up every morning for a 1.2 mile round trip to take the kiddies to school
    (which I think you have similar for your gkids?)
    And I always think of the wear and tear this is doing.
    I finally (after 8 YEARS) cleaned out my garage to fit BOTH Prii in, lol and want to continue to "baby" them
    since we will try our best to resist temptation (ohh Prime you are getting serious close to Prime Time now!!! :) )
    and hold onto them as long as we can before upgrading autos.
    ** @Mendel Leisk Have you thought about a plan to perhaps check the fitting/grease on a schedule?
    As in possibly once a year, pull out EBH and re-apply grease if leaked out and missing?
  5. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    Did you also see on that website you listed...dealersupplywarehouse
    interesting? now 202 watts?
    PU140-00913-2 APPLICATION: This has replaced PU140-00913-1, it is now a 202 watt engine heater instead of a 400 watt and includes a longer silicone cord
  6. Mendel Leisk
    42,346
    The pit of procrastination... I think you can see ours, commencing at left side of frame. Move-back-home son's apartment content mostly...
    I'd be loath to do that; it is not a lot of fun. First issue: the tang on the block heater clip is about 1/8" long. I've seen pictures where it's a good 1/2", but not mine. :confused:
    This is what you have to press on, to lever the clip up enough to pull the heater element back outa the hole. A small screw driver helps in lieu, but bear in mind: that requires two arms up there, and it's really difficult, the drive shaft CV joint is right in front of you (you basically can't see the location and reach it at same time). Also, you're reaching arms on either side of the drive shaft: the aft side requires signif. contortion, and I think if I was 50 pounds heavier it wouldn't be happening.
    But yeah, I might... :ROFLMAO:
    Plan B: use the block heater, this time of year/temp, for a couple of hours, start the car and see how much above ambient the coolant is, say 60 seconds after start up (temp tends to homogenize, rise, in the first few seconds). Then repeat the exercise in a year, check for variation, might "might" indicate heat transfer grease loss.
    I have a ScanGauge I can use for this temp check. I'm reluctant to leave SG on constantly though: I'm pretty sure it was causing "check hybrid system" errors, miscommunication, due to constant weighing on the OBD port.
    Huh, no. I went with the dealership recommendation, the part number with last digit changed from 0 to 5. I compared old and new: the block heater itself is identical, same dimensions, shape, all numbers the same, including 400 watt designation. The differences I saw were only in the cord and plug in, more robust sheathing, stiffer and harder to flex around corners, and a fair bit shorter if I'm not mistaken: I just made it out to front grill, usual location. No problems, but just enough.
    #26 Mendel Leisk, Oct 28, 2019
    Raytheeagle and dig4dirt like this.
  7. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    Yeah that sounds like you, haha. Im sure that time will come around.:whistle:
    But yeah I have SG I keep plugged in my C, and only few various times plug in the Gen3
    So I will start with one of the new 202w heaters on my C (since it seems to be 90% easier install)
    and see what it gives me and go from there.
    Might need the 400w for the Gen3 on colder mornings.
    :cool:
  8. Mendel Leisk
    42,346
    I'd like to see governments mandate a factory-installed, immersion-style block heater, in every car that rolls off the line. It's cheap/easy to do during engine assembly, and immersion-style is much more bullet-proof. Doing such an install later is such a hassle, wastes coolant.
    I'm sure 90% of them would never get used though. In particular those in the coldest regions: there seems to be an inverted attitude towards block heater use, lol.
  9. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    Very strange.
    According to that sheet, the 905 part number is for the Gen1 and Gen 2 with 1.5L engine?
    I guess it just seems to fit both?
    Did you chat about the wattage when you ordered at dealer?
    Perhaps they opted to stay with the 400w direction for above the US/CAN border?
  10. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    Do you not SEE the words you are writting?????????? o_O:confused:
    The more any government gets involve, the worse things get!
    Grit and Mendel Leisk like this.
  11. Mendel Leisk
    42,346
    @dig4dirt I did not ask about wattage.
    On a phone, and partial text quote is hopeless.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Oh no, you let one back on the payroll :whistle:?
    They’re supposed to stay off once they leave;).
    I know I got the size 11 boot once I left for college(y).
    RMB, Peter123, Grit and 3 others like this.
  13. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Caught Mendel’s hidden political agenda!!! I’d love to see him at our meet ups one day and we go on politic banter.
    RMB and Mendel Leisk like this.
  14. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Not everyone has the luxury to run an extension cord to the car. People living in apartments cant do that, nor do oil changes.
  15. Mendel Leisk
    42,346
    Once I'm elected apartment block parking lots will be a rat's warren of extension cords, awash with spilled oil. :sneaky:
  16. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Careful with those words around here;).
    Soon we’ll get this thread to the kids area:eek:.
    But if those are your platforms, I’d support your candidacy (y).
    Grit, Mendel Leisk and Robert Holt like this.
  17. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    Is that part factory installed on Prii sold in cold climate?
    One thing (certainly) never needed at down here:)
  18. Mendel Leisk
    42,346
    I think so, in Alberta for instance.
    I use block heater year 'round. Always shortens warm up. I appreciate its really only a necessity in bitter cold winter, but doing a lot of short trips I like the faster warm up.
    Grit likes this.
  19. Mendel Leisk
    42,346
    First use today (we don't get out much): 2 hours use, with temp in the garage at a steady 42F, coolant temp readings with scan gauge (with car "on" not "ready"):
    Tuesday, October 29, 2019 test:
    Plugged in at 11:05 AM, coolant temp 42F (ambient temp 42F)
    Checked around 12:10 pm, coolant temp 95F (ambient still 42F)
    Checked around 1:50, coolant temp 100F (ambient still 42F)
    Differential: 58F (32C)
    You can see after just one hour it was starting to plateau. The second hour doesn't make that much "apparent" difference, but in actuality I find it does. I get the sense the heat doesn't climb much more, but spreads, less of a hot spot right at the block heater.
    I disconnected the SG before starting up, but I know in the past, within about 30 seconds of start up, temp really jumps, as the warmed coolant homogenizes.
    Grit likes this.
  20. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I low grill block year round and this morning I finally did 100% lower grill block. It was 37F during the morning hour commute. Also Inverter HV temp maxed out at 93F, it goes up to 133F during non block summers.
