Block Heater SMOKIN'!! (PICS)
Discussion in 'Gen 2 Prius Accessories & Modifications' started by tballx, Jul 22, 2007.
  1. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Again, please do not forget to apply the thermo grease.
    Ken@Japan
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(FireEngineer @ Jul 31 2007, 09:03 AM) [snapback]487964[/snapback]</div>
    It shows up fine for me in the first post Wayne...maybe the host site was down temporarily.
    hmmm, ok, now it won't show up in my post....lemme try something else....
  3. oly_57mpg
    oly_57mpg New Member
    360
    Olympia, Portland, Seattle...
    <div class='quotetop'>QUOTE(FireEngineer @ Jul 31 2007, 10:03 AM) [snapback]487964[/snapback]</div>
    It might have been the same/correct part - but it was not in the correct hole. If you look at the picture above from the OP, you can see how the block heater is in crooked. Plus the fact that you cannot get a camera in that area to take a picture also proves it's the wrong hole.
    Ken's picture above is the only picture I know of that clearly shows the block heater hole - of course, usually there are pipes around it and an inverter on top of it...
    <div class='quotetop'>QUOTE(Godiva @ Jul 31 2007, 01:55 AM) [snapback]487878[/snapback]</div>
    Don't let this thread discourage you. It's an easy install. It just takes forever to feel around when you're laying on your back, reaching up through the engine to find a small hole. Then comes the fun of lubing it up and sliding it in, baby. B)
    <div class='quotetop'>QUOTE(ken1784 @ Jul 23 2007, 02:04 AM) [snapback]483477[/snapback]</div>
    There's NO thermo grease in the OP picture. When I was done with my install, I could feel grease all around the hole and anywhere my hand had wandered. There should be 'some' lube showing somewhere.
    OK... I found my pictures on an old [dlt] tape backup:
    Looking underneath from the front of the car:
    http://picasaweb.google.com/traitorous8/Pr...375820508591618
    Looking up from the bottom:
    http://picasaweb.google.com/traitorous8/Pr...375820508591602
    As far as a small point-n-shoot camera can reach:
    http://picasaweb.google.com/traitorous8/Pr...375820508591586
  4. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    Man do you have a clean Prius! What kind of aluminum polish do you use under your car?? ;)
  5. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    <div class='quotetop'>QUOTE(Godiva @ Jul 31 2007, 12:55 AM) [snapback]487878[/snapback]</div>
    I'm still picking my menu items.
    Wayne
  6. Godiva
    Godiva AmeriKan Citizen
    10,339
    <div class='quotetop'>QUOTE(ken1784 @ Jul 31 2007, 09:34 AM) [snapback]487986[/snapback]</div>
    Question:
    Does this mean the EBH has to be removed periodically and re-greased?
    Also: What is the lifetime on this thing? Would I have to buy another (and regrease and reinstall) every few years?
  7. oly_57mpg
    360
    <div class='quotetop'>QUOTE(Godiva @ Jul 31 2007, 01:41 PM) [snapback]488153[/snapback]</div>
    No. It's a one time deal for installation. It's not a moving part. The thermal grease is used to better transfer heat from the EBH to the engine block. It's the same idea as the thermal paste that's used on computer CPUs to transfer the heat from the die/packaging to a heatsink.
    Life of the car as long as it's installed in the correct hole... :mellow: How long have you had your oven heating elements? Yeah, the EBH will last a good long while.
    All of the watt-hour metering that I have done shows that it soaks 400W-415W. As long as you see a _little_ spark on the NEMA L5-15 (three prong plug you attach to an extension cord/wall plug) when you plug it in - you'll know it's still working!
  8. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Here is another picture from the exhaust side.
    Looking at OP's picture again, found a big space between heater and hole.
    The diameter of the hole is too big than the heater.
    Again, my bet is it was wrong hole.
    Ken@Japan
  9. tballx
    tballx New Member
    130
    Edmonds
    All right, all right. I'm tempted to go throw it up on the ramp right now but it's story time for the kids. Obviously, I've gone from wrong part, right hole to right part, wrong hole. No I didn't go berserk on the grease for the simple reason that if any is left shooting out the hole upon insertion it's wasted. But it was on the tube. Clearly, there is another similar sized hole as a decoy or something <_< At any rate, I'll climb under again and give it a shot with the new part. My experience certainly shouldn't dissuade anyone. It's actually kind of fun to tinker around anyway.
    Rereading my post sounds like a response in a remedial porn-cinematography class. Geez.
  10. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(tballx @ Aug 1 2007, 11:55 AM) [snapback]488457[/snapback]</div>
    Following is the instruction sheet.
    Please find "CAUTION: Do not operate in air".
    The heater will burn out if it did not have good thermal transfer to the engine block.
    Ken@Japan
    edit:
    I think tballx's trial was very good challenge.
    "You never fail until you stop trying."
    Hope next person will succeed to install it.
  11. oly_57mpg
    360
    <div class='quotetop'>QUOTE(ken1784 @ Aug 1 2007, 12:50 AM) [snapback]488499[/snapback]</div>
    That brings back memories from sex ed class...
  12. tballx
    tballx New Member
    130
    Edmonds
    SUCCESS!!
    Second try is a charm. No worries. Now off to acquire a timer for my outlet. :D
  13. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(tballx @ Aug 5 2007, 03:39 AM) [snapback]490575[/snapback]</div>
    Congratulations!
    Now, you found the grease helped a lot for your sexual pleasantness, didn't you? <_<
    Ken@Japan
  14. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(tballx @ Aug 4 2007, 01:39 PM) [snapback]490575[/snapback]</div>
    Good for you. Now that you have it can you show a wider shot showing where you inadvertantly installed it the first time...just so others know NOT to do it there.
  15. tballx
    tballx New Member
    130
    Edmonds
    <div class='quotetop'>QUOTE(efusco @ Aug 4 2007, 01:52 PM) [snapback]490618[/snapback]</div>
    Well, perhaps next weekend. I'm done with the ramp for today. It's a good idea though since I think I can show both where I attempted to install and a portion of the indentation in the block from the actual insertion point in the same frame. I intentionally took the first shot up close to illustrate the lack of uniform contact.
    <div class='quotetop'>QUOTE(ken1784 @ Aug 4 2007, 01:10 PM) [snapback]490604[/snapback]</div>
    Umm... thanks for the support but remember that playing with American idiom too much can be dangerous or at least weird. B)
  16. FireEngineer
    1,247
    124
    I guess I'll scratch this location from the trip manifest. Congrats.
    Wayne
  17. tballx
    tballx New Member
    130
    Edmonds
    Thought I would try a little post mortem to illustrate the WRONG spot to insert the heater. The photos are taken with the camera placed somewhat awkwardly considering the cramped conditions. Click them to enlarge. Here is where I installed the heater core:
    Notice the small metal band in the frame above the hole that I've outlined in yellow? If you rotate the camera 90' so that it is facing toward the front of the car you can then see that same metal band in relation to the place where the heater should've been inserted.
    The actual cord that runs down from above to power the block heater is outlined in red. You can see the indentation from the insertion hole in blue. The band is in yellow again. The obvious error is that originally the core was inserted such that the power connection faced the passenger side whereas inserting the heater core in the proper hole results in the power connection facing the driver side. Lastly, I can't get a shot of the indentation that is at the rim of the proper hole but you can feel it with your hand and once your clip is seated properly over it you are good to go.
    It's actually quite simple. If you've ever built a toy for your kids at Christmas or assembled furniture from Ikea you'll do fine installing it yourself.
  18. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(tballx @ Aug 13 2007, 02:37 AM) [snapback]494324[/snapback]</div>
    Now, we know your original (wrong) hole was on the transaxle (near MG1) instead of the engine block.
    Ken@Japan
  19. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    <div class='quotetop'>QUOTE(oly_57mpg @ Aug 1 2007, 11:57 PM) [snapback]489085[/snapback]</div>
    ESPECIALLY that "Do Not Operate in Air" warning!
