Block voltages
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jgurley, Apr 19, 2017.
  1. jgurley
    jgurley Junior Member
    42
    17
    I've had a sudden rash or DTCs of late (I'm convinced it was a deep puddle), but P0A80 and P3012 (Block 2 weak) are among them. With 215K on the '05, it's not extraordinary, but to occur among a half dozen other codes is suspicious. Includes C1259, C1310, P3000 as well.
    Anyway, the scanner shows Block1 & 2 at 16.50v, blocks 3 thru 13 at 18.10 (or thereabouts) and block 14 at 17.5v. These values are freeze data from when the code was thrown, so the engine was running and the car moving. Are these values expected?
    Is there a way to to get "current" block voltages from TechStream when the ICE is not running?
  2. JC91006
    16,936
    8,647
    blocks 1 and 14 will normally have a lower voltage than the rest of the pack. But if the ECU picked up a weak block, it's usually a correct diagnosis of a problem.
    SFO likes this.
  3. jgurley
    42
    17
    I've got the battery out of the car and on the bench, and the first four cells all measure 7.35v wile the rest (including block 14) measure 7.86v or so. Any advice about replacing all four cells, just Block 2 cells (the DTC complaint) or the whole battery? I'm selling the car, but I don't want to sell a lemon. The fourth alternative is to call CarTalk and have them haul it away.
    There's lots of corrosion on the buss bar nuts.
  4. JC91006
    16,936
    8,647
    Your battery just needs to be cleaned and charged back up. I don't think you have any issues with it.
    Clean the copper bus bars using Vinegar, soak it overnight. Do not soak the nuts
  5. jgurley
    42
    17
    I'll give it a whirl...
  6. JC91006
    16,936
    8,647
    You would actually need a grid charger or someone with the capability to do it. When the battery is inside the car, it limits the charge to only 80% full, you'll never get a full charge
    How rare do you see 3 blocks going bad at once? Unless this batteries had a chance to sit long periods, 3 blocks failing is rare.....but of course possible
    I guess a load test is in order for the questionable blocks
    SM-N900P ?
    SFO likes this.
  7. strawbrad
    953
    1,007
    Yes, click on "Data List" when in the HV Battery section of Techstream. It always takes two times to get into the live data. The first will error out. Just hit retry.
    I have to disagree with JC91006. Your battery needs to be rebuilt. You have readings showing three different pairs of modules being weak. Static voltages of bad modules can bounce back.
    While looking at live data ( block voltages) with Teachstream do a forced charge and discharge. The weak modules will clearly stand out.
    Brad
    SFO likes this.
  8. jgurley
    42
    17
    The car did sit for about three months this winter. It's disassembled for now, as I wait for a DC6 charge/conditioner to arrive.
  9. strawbrad
    953
    1,007
    I would say two modules in different blocks failing at the same time is common. The OP's block 14 running .35 volts under the rest is suspect.
    Cycling and load testing of all the modules is needed.
    Brad
  10. jgurley
    42
    17
    So I've conditioned the four cells that were under performing, and they're all sitting at 8.15v after 24 hours. The remaining cells are still at 7.70v or so. Do I need to have all the voltages matching or can I re-assemble the thing and give it a try?
  11. JC91006
    16,936
    8,647
    You should at a minimum, load test the 4 that you've charged. That will help you determine if they are bad BEFORE you put them back in.
    If you have the time, why not recondition all of them and make all the voltages match?
  12. jgurley
    42
    17
    That process would involve discharge/charge cycles, then discharging the best until they match the worst (assuming the worst is a good cell)?
    What is the recommended charge and discharge currents for the process?
  13. JC91006
    16,936
    8,647
    Maybe discharge the modules to the same level as the other ones. Then assemble and try. Fingers crossed.
  14. jgurley
    42
    17
    I charged all 28 cells to 9.0v, and after a day of settling to 8.1-8.2v, I reassembled the pack, put it back in the car, then drove about 20 miles with no battery warnings. The live data on Techstream showed block two was actually a little higher than the other blocks.
    Unfortunately, the car threw a P0301 (Cylinder 1 misfire), so I swapped the coils between 1 and 2, and the code changed to P0302, so I ordered a new coil. I either damaged it when I changed the plugs or the big puddle forced some water into the plug hole.
  15. JC91006
    16,936
    8,647
    Sounds like you've got it under control.
  16. jandjautoworks
    jandjautoworks New Member
    what is the meaning of a negative value on techstream for a battery block? 39605709_516731975431281_3155124228802478080_n.jpg
    Rodger C. likes this.
  17. dolj
    dolj Senior Member
    8,641
    4,393
    Wellington, New Zealand
    You need to examine the voltage sensing wire(s) for evidence of corrosion or breakage. Be aware that corrosion may not be that evident and may go a significant distance along the wire under the insulation.
    If you are in trade and care about your business reputation, just buy a replacement wiring kit from Toyota and replace the whole lot, but at least the voltage sense wiring. You may need to clean up corrosion in general while in there.
    jandjautoworks likes this.
  18. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Maybe you forgot to reattach some nuts?
    Or maybe you forgot to use and inch-pound torque wrench to properly tighten the nuts?
    If you just guessed at whatever "felt tight enough", it is likely you were wrong. :)
    You do not want them over tightened or undertightened. Can cause arcing and possible fire.
    jandjautoworks and Raytheeagle like this.
  19. dolj
    dolj Senior Member
    8,641
    4,393
    ^^^^ +1 to that advice too.
    Eric know his stuff.
  20. jandjautoworks
    What are the torque specs?
