Block voltages
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jgurley, Apr 19, 2017.
  1. Rodger C.
    Rodger C. New Member
    Lancaster
    So I see you post in nearly every thread I've read... how come when I changed out the battery modules from my Gen3 to my Gen2, I started getting codes P3012 & P3013? Saying the battery is becoming low on block 2 & 3? But when the cells were in my other prius, that was never a problem. At all. They're all in sequence. I feel so lost man :/
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    I'd be happy to chat with you about it and do some troubleshooting. Feel free to call.
    608-729-4082 Don't beat yourself up too hard. You'll figure it out.
    Basically go open things up and methodically check things.
    It is easy, and common, to make a small mistake. The nice things is that you the error codes are giving you a place to hone in on.
    Do you have a way to watch live data?
    Dr. Prius's app, Torque Pro app, or Hybrid Assistant app. All run on Android phone/tablet.
    Also need an ELM 327 OBDII adaptor to relay data from car to the app.
    Raytheeagle and George W like this.
  3. C Wagner
    C Wagner Member
    183
    60
    Boston
    Since I didn't see an answer on this thread to the "what torque for the terminals", I'll answer what I used: 48 Inch pounds (not foot pounds!). Several of you said this elsewhere on Priuschat. Electronautomotive said up to 60 inch pounds, but I used 48. If, like me, you're a bit rusty with your torque wrench, practice on your dead/sick/removed modules first!
  4. dolj
    dolj Senior Member
    8,641
    4,393
    Wellington, New Zealand
    48 inch*lbs is correct, "Electronautomotive" is incorrect.
    C Wagner likes this.
