Blowing smoke at 63k, any chance Toyota will cover??
Discussion in 'Gen 4 Prius Main Forum' started by Hurricane350, Nov 25, 2018.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Nope:(.
    Just a little light that tells you when the coolant is too hot:cool:.
    A engine temp gauge would have been nice, but that was soo 20th century :rolleyes:.
    51,790
    the light comes on when you need a new engine, very helpful. same with oil
    qettyz, Tande, m.wynn and 2 others like this.
  3. Mendel Leisk
    41,233
    I distinctly remember driving my daughter-in-law's Pontiac Sunfire to Costco for a tire repair, muttering to myself: "even this pos has a coolant temp gauge".
    m.wynn and Raytheeagle like this.
  4. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    Wow...as others have said...this is not good news at all. :eek:
    From reading the thread it seems quite a few of us are jumping to conclusions here. However, I'm hoping this is an isolated incident NOT related to the EGR. Should be interesting when/if we find out what the actual problem was.
    #24 farmecologist, Nov 27, 2018
    alanclarkeau and m.wynn like this.
  5. Mendel Leisk
    41,233
    Yeah I hope more info is forthcoming. Dealerships doing warranty work tend to be terse. They might even replace head gasket when it wasn't necessary.
    Tande, m.wynn and Raytheeagle like this.
  6. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    Don't forget that a temperature gauge only works - if someone looks at it. I know a number of people - yes, relatives - who had major damage when they "didn't notice" it going up.
    And - if it's a catastrophic failure - like in Dad's case, the hose blew off on the way home from service because it wasn't tightened (yes they fixed it), the gauge went up and back down again so quickly he didn't notice it because there was no water left - he saw lots of steam, glanced at the gauge and it was actually lower than normal. Driving on the Motorway at the time, the head already needed replacing by the time he pulled over.
    I like the concept of the IDIOT Light like in some cars back in the '50s/'60s. Or, maybe - enter limp home mode for long enough to pull over.
  7. Hurricane350
    Hurricane350 New Member
    Boston
    Three Touring
    Sorry for the late response but my prepaid phone doesn't work in this country I guess!
    Anyways.. It wasn't diagnosed as the head gasket, I have been told it was the exhaust coolant exchange pipe.. And even better, it's being replaced under warranty! That and their doing my electrical recall . Parts should be in tomorrow (Thursday) , and fixed that day .Unfortunately I'll be out of the country till mid December so hopefully my friend that picks it up will be able to verify the work!
    Can I edit the title once I confirm it was what they say it was? Don' want to scare people!
  8. alanclarkeau
    7,045
    7,592
    Good news.
    I've just reported it - requesting it be re-titled:
    kithmo and UltraJetRefill like this.
  9. Mendel Leisk
    41,233
    Maybe "blown head gasket" should be kept in the title though, with explanation, since it was the focus of discussion.
    rosencrantz likes this.
  10. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    Okay I’ll bite... what does an “exhaust coolant exchange pipe” do? Is it the EGR cooler? I’m not surprised to hear Toyota covered this under warranty- especially being just out of warranty. Nice to hear they stepped up, though.
  11. Mendel Leisk
    41,233
    It runs coolant through a chamber alongside (hot) exhaust gasses, to accelerate engine warm up. It's further along the exhaust system than EGR, no connection. It's a fair sized contraption near the front end of the horizontal run; you can see it just looking under.
    m.wynn and rosencrantz like this.
  12. rosencrantz
    rosencrantz Member
    97
    77
    Central Valley, CA
    2018 Prius
    Thank you. It’d be interesting to learn what the root cause of failure was....
    Mendel Leisk and m.wynn like this.
  13. Hurricane350
    Boston
    Three Touring
    They really didn't though . This component is part of the emission system, which is warrantied to 100k, according to my sa...
  14. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Or maybe "Losing coolant, blue smoke coming from exhaust" since those were the symptoms and everything else was speculation until it eventually got diagnosed.
    mjoo likes this.
  15. Mendel Leisk
    41,233
    Maybe a fail weld? It's similar to the EGR cooler in construction: a coolant radiator in exhaust gas. A lot of stresses I guess.
    Regardless, the initial question and most of the response concern head gasket. Responders were surprised with "early onset" head gasket failure. Maybe retain the OP's original title, plus added suffix, about the outcome.
    #35 Mendel Leisk, Nov 29, 2018
  16. dbf
    dbf Member
    78
    86
    NE Ohio
    Even though it's not the head gasket, it still sounds pretty serious. And, it happened at relatively low miles on the car. Let's hope it's an outlier.
  17. farmecologist
    1,958
    1,799
    Southern MN
    Yikes...this may be even worse news if it is related to an EGR clog. Hopefully just an isolated case with a defective part. Let's wait for definitive info though. :D
    Tande and Raytheeagle like this.
  18. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Hoping for it, but if the OP leaves the car at the dealer unattended, I’m not sure we will:cool:.
    You know what happens while the cats away:whistle:?
    I would love to see the failed parts or at least have them left in the car for personal diagnosis after dealer intervention ;).
    Hope we can see that(y).
    #38 Raytheeagle, Nov 29, 2018
