Blown Head gasket rebuild....@297k
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 8, 2017.
  1. Patrick Wong
    18,212
    6,529
    Chap is referring to the smoke emitted at the chimney of the Sistine Chapel, when a new pope is selected.
    I assume that you meant a popping noise, and it is possible you have an exhaust system leak upstream from the muffler.
  2. amos
    amos Active Member
    376
    285
    los angeles
    It may be the remains of some oil left and its just burned out. Better monitor your oil level.is there a trail of white smoke when you drive or only when you start driving?
    IF you didnt change the rings than just be patient and monitor it
  3. Jose Reyes
    Jose Reyes Junior Member
    63
    Anaheim
    I had a used engine from a 2012 with 80,000 miles and tranny put in. I think it is a loose or maybe broken engine mount. Cause it only happens from a start and when driving it does not happen. Otherwise, the ac compressor is very noisy seems like im going to be do for a new one soon. But, at least that is a repair i can do and the ac is functioning normally. The creek happens regardless of the Ac and from a complete start. There was a burning smell, but went away when a huge summer shower came. MPG is back to normal 41 with a Ave of 45 mph and A/C we are going through a heat wave in socal.
    amos likes this.
  4. amos
    amos Active Member
    376
    285
    los angeles
    That dealershop. I wish i knew what they did.invoice shows replace gasket kit toyota p/n 04112-37253. Now my city mpg is down like 30mpg. But fwy is 52mpg on avetage speed of 70 mph when i drove back last friday from vegas.with at least 105 degreea outside and a/c constantly on.
  5. Mendel Leisk
    42,368
    Is the engine shutting off, in around town driving? (n)
    amos and Data Daedalus like this.
  6. amos
    amos Active Member
    376
    285
    los angeles
    Hey mendel.
    Do you have any idea whats that valve replacement kit contains.
    Again the toyota p/n is 04112-37253 .thats what the dealer did when they replaced my head gasket.
  7. Patrick Wong
    18,212
    6,529
    I don't understand your post. Your post #201 indicates what the dealership did. The part number is for a cylinder head gasket and valve cover gasket.
    amos likes this.
  8. amos
    amos Active Member
    376
    285
    los angeles
    I was wrong about reading it properly.trying to upload a photo but no success. Looking at it again.it says very specifically 04112-37253 gasket kit, engine v.
    Sorry for not being able to upload a photo.
    #228 amos, Sep 4, 2017
  9. Jose Reyes
    63
    Anaheim
    It may be that the computer takes a while to adapt after a full refresh. I have driven 300 miles since I got the car. Another thing to consider is that A/C usage kills mpg in short trips. In my 2013 I average 35ish during the 100 deg weather we have been getting.
    amos likes this.
  10. amos
    amos Active Member
    376
    285
    los angeles
    Im heading back to vegas soon. Will post results.
    Could it be that because im a new member , they wont let me upload a photo?
  11. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    It wasn't me......kinda wish it was......I mean I live in Palmdale & my Shop (Hybrid Pit) is in Buena Park.
    iPhone ?
    idohavemail and Raytheeagle like this.
  13. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    This might seem like a dumb question but why would the AC need a recharge? No need to remove the compressor from the car for a motor removal.
    Did he use the correct refrigerant?
    iPhone ?
  14. Jose Reyes
    63
    Anaheim
    I have been wondering the same thing. The a/c compressor is very noisy. Time will tell if it fails within a couple of weeks. I wanted the engine and tranny removed and replaced as one unit. The computer seems happy and the car drives okay. Minus a noise that sounds like something is loose my guess is a engine mount kinda a pop noise or cracking. Any ideas? You drive from Palmdale that is at least a 2 hour drive and there is no way to avoid the traffic. I took the mountain road to the 210 and even then it was a long drive.
    #234 Jose Reyes, Sep 4, 2017
    sfv41901 likes this.
  15. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I know that the "hybrids" use a different refrigerant due to the electric compressors. If ur guy used reg refrigerant then this might explain the noises u are hearing.
    Wish I would have known u we're looking for an engine. I've got 2:
    '12 Prii motor & tranny w/ 17k miles
    '12 Lexus CT200h motor & tranny w/24k miles
    I'm use to the drive. Been doing it for 5+ years now
    iPhone ?
  16. Mendel Leisk
    42,368
    AFAIK the refrigerant is the usual, BUT the lubricating oil is unique/special, and substitution with the usual oil can damage the system.
  17. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    There u go. That's the additive I was trying to remember. Thx.
    iPhone ?
  18. JC91006
    16,938
    8,647
    The oil used in the compressor is nd-11 oil. Anything else is a no no.
    But I believe must people just charge with straight 134A refrigerant. Oil is not needed
  19. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    danlatu, do you have a list of parts and brands and/or part number that you bought?
    I'm going to do head gasket on my 2010 and want to know what I should order.
    My current list is head gasket, copper spray, head bolts, crank seal(?) etc.?
    Thanks.
    Raytheeagle likes this.
  20. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    How many miles on your Prius? Do you have an oil consumption issue as well?
