Blown Head gasket rebuild....@297k
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 8, 2017.
  1. Jesus82
    Jesus82 Junior Member
    24
    63
    Denver co
    Ok that's good to know I will perform the entire manifold and EGR cleaning before I go any farther in the engine and put it back together and gave it a try, hopefully I don't have to do any Head work
    Thanks for the response
  2. Jesus82
    24
    63
    Denver co
    I Will try anything before getting in to the engine thanks
  3. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    Since your head gasket is probably blown, a couple of members here have used k seal to buy some time.
    m.wynn, Jesus82 and mjoo like this.
  4. Jesus82
    24
    63
    Denver co
    Hi danlatu,
    I'm going to do the Head gasket, just to be safe, is there any special tools for the head gasket job? Or anything special that I need to know about, I have replaced timen belts on vw Jetta and Honda's and always worked on my own cars, so I have a good idea on where to start but any help before the project will be nice,
    I will like to do the entire engine because it is burning oil but my knowledge is not all there for the entire job so head gasket should be ok for now thanks.
    amos, danlatu and Raytheeagle like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    If you want another opinion, @leeb18c did a head gasket replacement while the block remained in the Prius ;).
    danlatu likes this.
  6. Jesus82
    24
    63
    Denver co
    Nice thanks raytheeagle
    Raytheeagle likes this.
  7. danlatu
    533
    1,367
    maryland
    You will need a set of external torx sockets, i used zip ties to hold up the ac compressor, pull the passenger side wheel off and remove the timing chain cover and engine mount, you can use the ac compressor bolts to pull the pulley. The timing chain cover is going to be a pain to pull off. I left the entire manifold connected and just removed the studs to pull the head off. Make sure the cams and piston are tdc (top dead center) and mark the chain with white paint marker and the cam sprockets, if you are off one tooth, it will run like crap. I used grey rtv on reassembly, new head bolts new head gasket and I would replace the valve seals while you have it apart.
    Cactus Chuck and kc410 like this.
  8. Jesus82
    24
    63
    Denver co
    Perfect I will probably start the project later today after work, thanks
    amos likes this.
  9. Jesus82
    24
    63
    Denver co
    Hey danlatu, did you by any chance still have the information on the head bolts -timen cover sequence for loosing and torque the bolts?
  10. Jesus82
    24
    63
    Denver co
    Never mind I was able to download all the information from online, thanks
  11. Jesus82
    24
    63
    Denver co
    Hey guys,
    I when over all of this conversations and specially to all of danlatu information on his engine rebuild thanks for all the pictures,
    danlatu I know my engine is burning oil and I'm the same way is you are, I prefer to get new piston rings, and don't take chances with a used engine, so i started to remove everything to do the head job, but instead I will be removing the whole engine and installed new rings I'm very confident on doing it my self, I Will inform of any new updates with my engine job,
    Danlatu did you honed the cylinders using the normal tool to do this job? And did you have to replace any of the connection rods or camshaft bearings? Did you have pictures from the paper gauge measures? To show specs, what about torque spec for connecting rods bolts and cams bolts as well timen chain bolts, sorry for all the questions man I just like to go smoothly, let me Know please
    Thanks for all your help you can pm me the pictures to [email protected]
    amos, danlatu and m.wynn like this.
  12. danlatu
    533
    1,367
    maryland
    All the bearings were in spec and torque specs are all in the manual I have provided for download below, 180 medium hone stone using a 30-40 degree crosshatch pattern.
    qettyz likes this.
  13. Jesus82
    24
    63
    Denver co
    Thanks again man,
  14. Jesus82
    24
    63
    Denver co
    Hey danlatu,
    Is me again, wandering if you can answer couple of questions 1/2 is ther torque converter bolts holding the transmission Attached to the engine like a regular automatic transmission, or is just like a stick transmission only a shaft? 2/2 you mentioned you have to remove your crankshaft pulley for clearance what about the water pump did you remove it as well? I'm on this 2 last steps to pull my whole engine out let me know man,
    Thanks
  15. Jesus82
    24
    63
    Denver co
    Engine is out, very easy to remove with out water pump and pulley is plenty of room,
    I can say this is probably easier than civics lol thanks danlatu, now to start the rebuild
  16. Jesus82
    24
    63
    Denver co
    Some pictures from today, engine with out the water pump and pulley getting ready to be removed
    amos, m.wynn, Lightning Racer and 5 others like this.
  17. Jesus82
    24
    63
    Denver co
    Today's progress on the Prius engine, all the parts need to be cleaned and then put back together probably next weekend, here is some pictures,
    Piston #1 was the head gasket fail, that one Piston is nice and clean probably steam cleaned
    amos, m.wynn, Lightning Racer and 8 others like this.
  18. danlatu
    533
    1,367
    maryland
    Every head gasket looks to pop cylinder number 1. Car was definitely burning oil from the looks of the pistons.
    Jesus82 likes this.
  19. Mendel Leisk
    42,377
    Please remind me again: number one, as you're standing at the front of the car with the engine installed, is on your left?
    (I don't think the $#&*+ Repair Manual says, seem to recall looking.)
    One other thing, @danlatu noted with his, one piston at TDC was a little low, and that turned out to be a hydro-locked case, with piston arm bent.
  20. ChapmanF
    19,060
    I think the pretty much eternal universal convention is that cylinders are numbered starting at the "front" of the engine ... in a transverse-mounted engine of course that's the side of the car ... the side where the transmission isn't ... so, yes.
    On a V engine, one bank will be slightly frontward of the other one, and the frontmost cylinder in that bank is #1.
    -Chap
    Jesus82 and Mendel Leisk like this.
