Blown Head gasket rebuild....@297k
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 8, 2017.
  1. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah
  2. Mendel Leisk
    42,369
    Ah man. Where's the harm in at least entertaining that there could be pros and cons to both sides? I came upon this thinking solder was THE way, but I've heard some interesting arguments for crimping. Don't turn it into trench warfare, lol.
    For starters, the manufacturers: pretty much 100% crimped?
    #482 Mendel Leisk, Oct 20, 2018
    m.wynn, Threej and Raytheeagle like this.
  3. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Dog fight
    Pixel XL ?
  4. ChapmanF
    19,052
    They still seem to be pretty enthusiastic users of solder on circuit boards, inside things.
    And then there's the inside of the Gen 2 fan controller, where
    hobbit found several connections spot welded
    instead of soldered, just to keep things interesting.
    -Chap
  5. padroo
    padroo Senior Member
    2,763
    2,253
    Every electrical connection has a slight voltage drop and I think solder wins hands down in that area.
  6. ASRDogman
    8,070
    4,092
    Just keep on beating that dead horse.
    Imagine what could be done if you pull all that effort into something useful????
  7. ChapmanF
    19,052
    The post from padroo is useful; it's a nice, crisp, testable hypothesis. Those are always useful. This one could be checked using just some samples of each kind of joint and a nice milliohm meter.
    Sometimes you can also get the answer using a library, if the question has enough industrial importance that you'd expect someone's already done the experimenty bits. This one might be in that category.
    The experiments are fun, but if there's concern about using time usefully, the library tends to pull ahead on that score.
    For padroo's point, I'd be pretty surprised if the data couldn't be found either in the Air Force report already linked, or in one of its listed references (this one might be a likely candidate).
    -Chap
    #487 ChapmanF, Oct 21, 2018
  8. ASRDogman
    8,070
    4,092
    STILL beating a dead horse!
  9. Mendel Leisk
    42,369
    Crimped vs soldered has been going on for 3 pages now, and the thread's about rebuilding, blown head gasket. Start another thread?
    Threej and RMB like this.
  10. padroo
    2,763
    2,253
    The two military aircraft I worked on were manufactured by Grumman and Fairchild republic, one soldered their plugs and the other used crimped pins that were insertable into the plug. The crimped pins were more practical
    In my opinion but inside electronic boxes you will find soldered connections with very few exceptions.
  11. Ragingfit
    Ragingfit Active Member
    189
    249
    Aurora, IL
    If you unplug your EGR valve, the rattle or knock will go away. Yes, it will throw a CEL code. Or you could replace the EGR valve. There was a recall on the ERG valve up to 150,000 miles.
    warranty enhancement; P0401 EGR Valve | PriusChat
    danlatu and amos like this.
  12. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    Our 2010 threw an egr code 6k miles ago and all I did was clean it along with the egr cooler. No codes have popped since. I do believe the occ works because since 75k our prius has not burned oil (127k now) or knocked. I installed the occ when the car had it's first cold start knock. Found pool of oil in the im and traced it back to the pcv. I do know the prius was burning a little oil during that first knock and does not do it anymore. I am also doing 5k oci and watch it like a hawk while checking the occ. The im is much cleaner, no big pools of oil/water/fuel. During the winter is where the occ really shines.
    As for everyone getting excited about crimp vs solder. Crimping can be done safely and reliably in elements with the use of ideal noalox, I actually used it to repair the hybrid battery, all my copper terminals were heavily corroded. The humidity here in MD is not ideal (joke) for electrical connections, I use noalox often. Soldering and applying liquid electrical tape works. I use a ts100 portable soldering iron, 450c in 12sec and runs off 12~25vdc. I
    Ragingfit and amos like this.
  13. amos
    amos Active Member
    376
    285
    los angeles
    Short update.
    Knocks and misfire are gone. Its about 600 miles after i changed and cleaned all parts involved for the second time. I guess the first clean round was good for about 40k miles. I am still not going for the OCC. might need to smog it for the first time this coming february
  14. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Many here in Cali have oil catch cans in our Prius, it’s either remove it for smog, install in the underside so the smog tech doesn’t see it, or know someone who smogs it for you AND understands OCC can only help and do no harm.;)
  15. amos
    amos Active Member
    376
    285
    los angeles
    Yes it seems like no choice but to install occ. I will see if a smog will be required this april and if i wont get the gen4 than i will install that occ after that and stay with it. depends on my finance.
    Raytheeagle likes this.
  16. HeavyFooted3SGTE
    HeavyFooted3SGTE Junior Member
    53
    Minneapolis, MN
    What will this do then? Keep the valve closed and not recirculate?
    amos likes this.
  17. Mendel Leisk
    42,369
    I believe so. I've read here a few times that the (properly functioning) EGR system is paramount to keep the engine temps down. I would be very reluctant to defeat it; would instead try to clean/maintain it.
    m.wynn, mjoo, amos and 2 others like this.
  18. Ragingfit
    189
    249
    Aurora, IL
    Yep. I have found that the EGR doesn't close during idle or low speed driving causing the rattle or chug, chug, chug. When you pull the plug, the EGR just doesn't open anymore. The chug, chug, chug doesn't come back, ever.
    amos and danlatu like this.
  19. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    I got mine smogged with catch can still attached/installed and passed CA smog. Either the tech didn't see it or ignored(not likely) it. However, my catch can is black and hoses are too so maybe he think it's stocks. :) I got lazy and decided not to remove it since the shop has one free re-test if I fails so I take a chance. :)
    amos, RMB and Raytheeagle like this.
  20. Mendel Leisk
    42,369
    Yeah my OCC is shiney aluminum, but their was some versions, a bit more compact and satin black. Another good ploy is to get automotive hose clamps instead of the screw clamps: looks more legit.
    Mine is mounted on the lower cross-beam too, so even shiney, you really have to look to see, through the jumble of airbox and hoses.
    amos likes this.
