Blown Head gasket rebuild....@297k
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 8, 2017.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Good to see you back:).
    How’s the head gasket doing:whistle:?
    Might do a meetup in a couple of weekends if you are around;).
    Maybe we’d get to see the Prius this round instead of that nice white shiny Bolt(y).
    SFO and amos like this.
  2. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    Our 2010 prius had a knock at start up. No codes @ 70k found a pool of oil in IM coming from the pcv. Egr ports on IM where relatively clear for air flow. I only cleaned the IM and installed an OCC. 2.7 years later @ 125K p0401 egr code popped with car running fine with no knock since 70k. I pulled the IM, EGR and EGR cooler to clean them. Reinstalled everything and car is running fine.
  3. Jon Watkins
    Jon Watkins Active Member
    131
    115
    Bluffton SC
    2024 Prius
    I’m wondering if the 2015 really needs a catch can due to the revised pistons/rings. Bought my wife’s 2015 two about 6 months ago with 37.5 miles and immediately installed a catch can with stainless scrubbing pads in it. It has been driven appx 4k miles since then. Waxed it yesterday and checked the catch can while I had it in the garage. I tend to check the catch can about every 1k miles or so. Yesterday it had less than 1/2 teaspoon of water consistency oil in it. Over the 4k miles she has driven it I don’t think I’ve gotten more than a tablespoon of oil out of catch can in total. I know...cheap insurance regardless.
    RMB, Montgomery, amos and 2 others like this.
  4. Mendel Leisk
    42,365
    Your post has me starting to type, then deleting. Maybe there's less oil mist in the PCV air flow with the revised pistons/rings?
    A post-winter check of the OCC should yield the most, fwiw. Revisit the intake manifold occasionally too: The easiest way with a good view is to lift off the throttle body: I've checked ours a year post-install, and there was just a sheen of oil at the intake manifold sump, no more pool.
    amos, Raytheeagle and RMB like this.
  5. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    I didn't know they put in different rings for my 2015. I have approximately 34k miles right now. Did Toyota really put in different pistons and rings?
  6. Mendel Leisk
    42,365
    That's what I'm seeing, just plugging various 3rd gen years in at McGeorge Toyota, and asking for pistons and rings:
    Note that the latest pistons/rings part no's are those spec'd in the TSB for excessive oil consumption fix.
  7. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Mendel, if time permits, can you dig a little deeper and look into year 2016 and up for the models using the same Gen 3 engines as in Prius v, Lexus CT200h and perhaps Gen 4 piston and rings part numbers to compare?;)
    Edit: I’m just curious if those engines are also using the improved parts, just curious, it’s not important at all.:p
  8. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Time :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:.
    He’s got time(y).
  9. Montgomery
    2,254
    2,244
    Orange County, CA
    Wow! looks like I bought it at the right build and time.
  10. Mendel Leisk
    42,365
    I checked Prius v, it is similar, except the transition occurs completely in 2015, 2014 has the old pistons still.
    4th gen has a new piston and ring.
    It's quite easy to check any year/model: just enter the vehicle on McGeorge, then search for piston or piston ring.
    Yes. Funny thing is, a lot of older 3rd gen Prius are not using any oil. Except overnight they can start. It seems like there could be a threshold. Maybe having cleaned EGR and an oil catch can helps too: time will tell.
    amos, RMB and Raytheeagle like this.
  11. Mendel Leisk
    42,365
  12. padroo
    padroo Senior Member
    2,763
    2,253
    Looks like a work in progress with pistons and especially piston rings. It would be interesting to know what they changed.
  13. Mendel Leisk
    42,365
    Yeah I tried googling those part numbers, hoping to find some images to compare. No luck.
    amos and padroo like this.
  14. Landon51
    Landon51 Member
    190
    63
    US
  15. bwiencek
    bwiencek Junior Member
    16
    Kansas City
  16. Titus415
    Titus415 New Member
    San francisco
    did you add the seal packing to the front of the head gasket to seal against the timing cover? is it required?
  17. Mendel Leisk
    42,365
    Repair Manual instruction is to apply a bead under:
    And then atop the head gasket, in the same zone. More info in attached.
    danlatu likes this.
  18. Mendel Leisk
    42,365
    Great video here, btw. Lots of hands-on tips:
    Patrick Wong and padroo like this.
  19. padroo
    2,763
    2,253
    He works pretty quick, I always do a better job of cleaning parts.
  20. Patrick Wong
    18,212
    6,529
    In the video, I am surprised they use a steel blade to scrape the aluminum surfaces. I think that risks scratching the aluminum. It would be better to use a plastic tool and solvent to clean the aluminum.
    amos and Mendel Leisk like this.
