Blown Head gasket rebuild....@297k
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 8, 2017.
  1. schmuber
    schmuber Member
    115
    85
    Georgia
    You didn't drop the coolant? IMHO the coolant passages collect almost as much junk when the engine is taken apart…
  2. schmuber
    schmuber Member
    115
    85
    Georgia
    The car is back together and running just fine, despite the fact that I have an extra bolt and a non-matching nut left. These likely belong to some wire harness near EGR cooler. May figure it out later… or not.
    At first startup got 3 scares in a row. First when the engine, after initial chain tensioner rattle, suddenly began knocking and throwing codes. But of course it would work much better if I plug the MAF sensor in!… The second scare happened shortly after when I saw white smoke coming from behind the engine. Did I forget to tighten the exhaust manifold nuts?!… Nope, that was just liquid wrench residue burning out. The last scare was when I noticed a large pool of fluid coming from under the car. Guess what, a week outside in rainy weather… The AC had to pee!
    Time for a test drive.
    Edit/update: 60 mile test drive, everything works great.
    PS: At the next oil change I'll install the OCC.
    #622 schmuber, Jul 21, 2019
    RMB, Mendel Leisk, mikey_t and 4 others like this.
  3. peakay
    peakay Junior Member
    85
    SoCal
  4. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    But a lot of guys have responded there with fantastic suggestions.
    Whatvother message donyou want to get?
    SFO and Mendel Leisk like this.
  5. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    What tool needed to take off main bearings and connecting rods.
  6. Raphael Muscarelle
    661
    222
    I happen to agree with you in rebuilding what you got. Buying used engine you never know what shape it is in unless you pull it apart.
    Only buy used engine if block or something else is cracked.
  7. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    ....or an engine you've the history from a junkyard. I doubt such info exists with the yard guys.
  8. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I paid the 19.99 for a Carfax on the VIN for the engine I bought. Most yards have the VIN on file.
    Dxta and Mendel Leisk like this.
  9. Raphael Muscarelle
    661
    222
    Unless they have x-ray vision no report can tell condition of engine.
    Example mine was perfect right up untill it wasn't.
    Dxta likes this.
  10. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    The engine I installed was out of a wrecked vehicle that was just past its first oil change. And I had it apart for inspection/head installation. So I feel extremely confident in its condition.
  11. Raphael Muscarelle
    661
    222
    Rod bends becouse coolant leaks into cylinder and during compression stroke physics take over and liquid can not be compressed crank shaft does not stop due to powerful electric engine turning it. Weak point is the connecting rod which then bends.
  12. Raphael Muscarelle
    661
    222
  13. Raphael Muscarelle
    661
    222
    I felt confidant in condition of my engine right up untill head gasket blew out.
    And I'm a mechanic by traid.
    I'm sure you'll get many miles out of a newish engine.
    Comment was not intended for super low mileage engine btw.
  14. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Point taken. My suggestion to anyone doing a swap, since the engine is already out, especially if the replacement engine is also from a Gen 3, is pull the head and replace the head gasket. That should set you up for years of trouble free service.
    Robert Holt, m.wynn and RMB like this.
  15. Raphael Muscarelle
    661
    222
    I never looked at maintenance schedule. But now I wonder if retorque head at 200k miles is in there infact I would suggest replace head bolts at 200k. Elongated head bolts from the engine running for that length is probably the cause of head gasket blowing.
    Robert Holt likes this.
  16. Mendel Leisk
    42,383
    Head bolt retorgue is not in there. Any thoughts on the method: just cinch them all? Or loosen and retorque?
    Quite a production too: the engine mount, crankshaft pulley, timing chain cover, valve cover, cams, all have to come off...
  17. Raphael Muscarelle
    661
    222
    I would loosen as per directed in disability and torque in standard assembly.
    The thing is the combustion is probably stretching the bolts. After so long they could provide enough slack to allow cross flow in head gasket.
  18. Raphael Muscarelle
    661
    222
  19. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    The spec for the head bolts tightening is 49 Nm, followed by 90*, followed by 45*. All that of course in a specific sequence on all 10 bolts, starting at the middle and working out from there.
    During the angular steps, assuming these are torque to yield, the bolts will be stretched into the plastic deformation zone, as designed. This means that "retorquing" is not as simple as it would be on normal fasteners (that are not designed to yield upon installation), where you might just loosen them and re-torque to the specified torque. Similarly, they should not be re-used. The angular steps cannot go forever - each progression into the plastic zone moves you closer to the point of fracture.
    Removing all bolts and replacing with 10 new bolts should work. No comment on how likely this would be to fix anything. And BTW, I've had my Prius for about a month now, so my knowledge is mostly based on other cars, engineering, and physics.
    Ragingfit likes this.
  20. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Only problem is: you cannot access the head bolts without removing the camshaft housing.
    iPhone ? Pro
