Blown Head gasket rebuild....@297k
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 8, 2017.
  1. Former Member 68813
    3,524
    983
    US
    This thread is better than most sticky posts here. I'm going to download pictures before links go bad.
    danlatu, m.wynn, Montgomery and 3 others like this.
  2. Mendel Leisk
    42,369
    Maybe report it, ask that it be "stickied"?
  3. ETC(SS)
    7,575
    danlatu likes this.
  4. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    Cylinder number identification usually starts at the timing chain. TDC and the alignment of the timing gears always starts @ cylinder1. My bent rod was in cylinder #1 closest to passenger side.
    The cylinder has a coolant jacket that surrounds it to keep the engine @ about 195 degrees farenhient while taking in 14 parts air and 1 part fuel for combustion. If the combustion runs too lean, water pump fails, cat/exhaust clogged the engine will run hot. The heat causes the metal (aluminum to steel/aluminum) to expand and contract. This friction causes the head gasket to fail. The coolant is roughly 1/2 inch away from the cylinder and is the first to enter the cylinder. The coolant is what bent the piston. If you google hydro locked motor, you will find some interesting failures. Water entering the intake, failed egr cooler, throttle body(some have coolant running through them)gasket, sea foam pored in to fast can cause a hydro lock.
    When the combustion chamber has coolant in it, some of it will burn and turn white while exiting the tailpipe. The other unburned portion of coolant then passes through the rings and mixes with the oil. The egr getting clogged in my opinion is responsible for the head gasket to fail because the computer runs a different programming/tune for timing and air/fuel ratio when the egr is opened. A bad tune will destroy an engine. Opening the egr will do nothing when the egr cooler is clogged. That is why some of us are experiencing rough idle at start. My girlfriends car did this one time but has not done it since. I wonder if it is the oil catch that is keeping the egr system clean. Burning oil is essentially carbon build up.
    #104 danlatu, May 17, 2017
    MikeFixes, iskoos, mjoo and 2 others like this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    My guess is that when liquid dribbled into the intake, #1 was simply the cylinder with the open intake valve. Luck of the draw.
    danlatu and Mendel Leisk like this.
  6. Mendel Leisk
    42,369
    Just for giggles, before breakfast this morning I wander out to the garage (in housecoat and slippers...) and took a look at that EGR pipe, maybe the canary in the coal mine? This is at 67K km's, and to be fair I did clean it out once before, around maybe 35K. Well it looked pretty much pristine. A little carbony, but no build-up to speak of, not even worth cleaning. A bit of condensation, fwiw. Guess I better go back out there and put things back together.
    danlatu and Raytheeagle like this.
  7. danlatu
    533
    1,367
    maryland
    Started right up first try, ran so smooth and quiet that I did not know it was on. It is also smoking right now and I do not want piss off my neighbors and have the fire department come out. I have to run this @ 2k rpm's and break the rings in. I will do this during the day tomorrow and let you know. Thanks to Nuts&Bolts youtube video on maintenance mode and coolant bleed. There is one missing 12mm nut in the whole rebuilt for the egr valve. Not too bad.
    I've been reading a lot about different motor break in procedures. Getting plates tomorrow. I am going to idle till warm, run motor @2k rpm for 30 min and then flog it. I'm sure there is coolant still in the cat/exhaust system so I'm going to run this thing around the industrial area.
    #107 danlatu, May 17, 2017
  8. ChapmanF
    19,052
    Yeah, dropping from 12 to 9 volts drops the V²/R heating nearly in half, so as long as it's enough to open the valve, and it does, you've got a much more comfortable safety margin if you're not using the purpose-built electronics to pulse the injector properly.
    I don't remember how long it took for the exhaust to stop making white clouds after we changed the head gasket in a friend's Civic. I think days, anyway, may have been a week. She'd been driving with the bad HG for a while....
    -Chap
    MikeFixes, iskoos and danlatu like this.
  9. jerrymildred
    11,517
    14,171
    Tampa, FL
    Sweet!! Looks like a new car. I think this is one of the best threads ever. Well done. I hope it becomes a sticky.
    danlatu, Montgomery, m.wynn and 3 others like this.
  10. Mendel Leisk
    42,369
    I've "reported" you Jerry, asking if they could sticky it. Good idea. (y)
  11. danlatu
    533
    1,367
    maryland
    My ocd was kicking in hard and wanted all the veins clear on the egr cooler. I use #20awg solid copper wire and poked through the little radiator core's and was not having to much luck. I knew it was still clogged due to the purple power foam settling at the top. Then I put it on a drill and wallah! It works the carbon loose as it spins like a plumbers snake. Copper is soft so I was not worried about damaging the stainless steel. IMG_0115.JPG IMG_0116.JPG IMG_0117.JPG
    MikeFixes, iskoos, Montgomery and 5 others like this.
  12. Mendel Leisk
    42,369
    Good idea!
    You know: just looking at the EGR pipe on ours yesterday, what impresses me is the precision engineering, (near-impossible without 3D CAD), that the pipe is such a good fit. It bridges between two disparate components, that in turn are bolting to opposite sides of the engine. Very tricky geometry is in getting that pipe just right.
    #112 Mendel Leisk, May 18, 2017
    danlatu likes this.
  13. Tande
    Tande Active Member
    556
    339
    Mich.
    Incredible! ......do you make "House/Calls".......:ROFLMAO:
    MikeFixes and danlatu like this.
  14. danlatu
    533
    1,367
    maryland
    I posted anyone can cook! I meant it. It takes effort, trail and error. In the end you will have the greatest satisfaction knowing you did it yourself and saved a sh!t ton of money. Having a garage would be super nice too.
    Tips
    1. If your knees hurt from leaning over the bumper to work on the car. Just point your toes @ the 10 and 2 "o'clock" position and bend your knees. This will prevent hyper extension and knee soreness when working on cars.
    2. Use large pieces of cardboard to work under the car. Absorbs oil, its soft and it gets you low to the ground. If you drop something, you can find it. Sometimes when you drop things with a creep you have to pull out because the bolt/nut is under you.
    3. Use an electric 3/8 ratchet and 1/2 impact gun. The correct tools make the job go quicker and make it fun, so does drinking beer or two:):)
    4. Do not rush, measure twice cut once kind of thing!
    MikeFixes, Bbonez, Tbkilb01 and 6 others like this.
  15. Mendel Leisk
    42,369
    I like to use a football as headrest when under the car. I rarely get around to finding it though, lol. Just seems like otherwise your neck tendons start protesting after a while, constantly tensing to look up at stuff.
  16. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Perfect, we've actually got a Nerf foam rubber football in the garage. :)
    MikeFixes, danlatu and Raytheeagle like this.
  17. Mendel Leisk
    42,369
    I go whole hog, have an NFL and a CFL kicking around somewhere, if I could find them, lol.
    MikeFixes and Raytheeagle like this.
  18. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    This is now a sticky thread:)!
  19. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    So let me get this straight:. In an Atkinson cycle engine the valves do not close until the piston reaches TDC yet it hydrolocked? (Sorry for my poor understanding and not reading all the posts...)
  20. Mendel Leisk
    42,369
    I'm thinking any engine has compression, has to.
