Blown Head Gasket
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JVS, Jul 14, 2022.
  1. JVS
    JVS New Member
    Los Angeles
    need a little help...
    Does anyone have experience with replacing an engine with blown head gasket, with a used engine?
    A little background ... we bought a 2012 Prius about a month ago, 186k miles on it, for $4k.
    The head gasket blew just a few weeks later.
    My mechnaic is quoting between $7000 to $8000 to repair the engine, and he recommended against getting a used engine. He said replacing the engine will cost even more.
    But another mechanic says dont bother with repairs, just drop in a used engine.
    Does anyone have a recommendation or experience with replacing the engine?
    Any help is greatly appreciated ..
    James
  2. JC91006
    16,933
    8,643
    I think a used JDM engine will be best. You already have 186k miles on your engine.
    I have a mechanic I regularly use in Rosemead that will be much better price than $7000 - $8000. I'm guessing it should be less than $4000 for a used JDM engine installed
    JVS and nate358 like this.
    52,773
    and get a gen 4 engine if you can, no sense in putting another oil burner in
    nate358 likes this.
  4. Mendel Leisk
    42,254
    Or the gasket sealer the seller dumped in gave way...
    If it's JUST head gasket failure so far, DIY head gasket replacement would be cheapest. The simplest shopping list for parts required would be Toyota's gasket kit (includes head gasket, and pretty much everything else in the engine), which is around $250, and (to play it safe) new head bolts, maybe around $100. Part no's for both items in the attachment.
    Take a look at the head gasket links in my signature.
    Also, clean the EGR system thoroughly (including EGR passages in intake manifold), or you'll be having another head gasket failure in short order.
    This video will give you an idea what's involved:
    #4 Mendel Leisk, Jul 15, 2022
  5. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    i would get a used engine
  6. AzusaPrius
    AzusaPrius Senior Member
    2,249
    940
    Take a trip to Buena Park and visit Hybrid Pit Stop.
    Tell them Azusa sent you.
    You can call or check out the engines on their website hybridpit.com
    You can also use the code azusa to save!
    mikey_t and nate358 like this.
  7. rjparker
    rjparker Tu Humilde Sirviente
    10,995
    6,892
    Texas Hill Country
    This is your best bet. Used gen3 engines are a big risk for repeating your problem in the next month or year. Fix it or get a rebuilt.
  8. nate358
    nate358 Junior Member
    94
    Columbus, OH
    I don't have any experience with putting in a used Gen 4 engine, but after trying to go the cheapest route replacing the head gasket myself... There are so many special tools you need... My valves needed lapped... There are just so many things that can go wrong once you open up the engine... It's not just the parts cost... It's the time cost. I'm 4 months in on this car and yeah I replaced all the suspension, brakes, rotors, wheel bearings, cv axles, but I did all this engine work and I still don't know if I'm putting it back together correctly and that's with me following the Toyota manual and a ton of YouTube videos. If I could do it all over again, I would first of all made sure my head gasket wasn't blown before doing all the other stuff and I would have just put a used Gen 4 engine in and called it a day. All you CA folk are lucky with all the specialty hybrid shops you have. I use my car for work and basically haven't been able to work the past 4 months... So yeah do the quickest way possible because time is money even if you're the one doing the work. If my engine does work after I get it back together... I'll be sourcing a Gen 4 for sure.
  9. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    I'm having a rebuilt engine installed at Hybrid Pit next week for half the cost of what your mechanic is quoting you for a "repair". Based on what I've read about what happens when an engine blows its head gasket, I think it's the best option.
    douglasjre and nate358 like this.
  10. nate358
    94
    Columbus, OH
    I looked at Hybrid Pit online store and noticed that they doesn't ship their rebuilt engines... That's a darn shame.
    mikey_t likes this.
  11. JVS
    JVS New Member
    Los Angeles
    Thank you JC.
    To add to my confusion, another mechanic tested the car and he says there is nothing wrong with it. I will look into JDM idea just in case.
    mikey_t likes this.
  12. mikey_t
    371
    391
    Los Angeles
    Hey James, if you're ever looking for a trustworthy mechanic in LA I recommend Olive Auto in Burbank. I've been going to them for years for regular maintenance with different cars. They really took care of me.
  13. OptimusPriustus
    OptimusPriustus Active Member
    335
    142
    Finland
  14. Mendel Leisk
    42,254
    ^ Bookmarked. (y)
  15. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    So they inspect the rods twice? Or just sloppy editing?
  16. douglasjre
    douglasjre Senior Member
    2,246
    751
    Null, NL
    Nate do you have any update for us
    mikey_t and Mendel Leisk like this.
