Blue hood badge, why?
Discussion in 'Gen 3 Prius Main Forum' started by swich2mac, May 24, 2009.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Afterthought is slapping a badge over a smooth painted metal surface. If you remove the badge, you are left with the "form" it was originally designed.
    I think if you remove the new Toyota badge, you will be left with "indent" in the sheet metal. That's because the car was designed with the badge and not after the design stage.
    I wish they design the front and rear license plates as part of the design as well. They are a bit more tricky because every country has different sizes.
  2. a priori
    a priori Canonus Curiosus
    3,083
    408
    23
    Chicagoland (West)
    The paint job behind the metal "T" has a bit of a 3D effect -- really looks like neon lighting -- though it is entirely flat and entirely paint. The metal "T" itself, though, is the same 3D object glued on to the car.
    Somehow the one on the front hides the radar that is part of the adaptive cruise control. I can't figure it out!
  3. Tideland Prius
    16,678
    I don't know... I kinda like the badge but I like the Lexus hybrid badge even more because it's a darker blue shade and a black background so it stands out and looks more aesthetically pleasing. The blue used in the Toyota ones are kinda like the blue in my avatar <------
  4. a priori
    3,083
    408
    23
    Chicagoland (West)
    It appears we have some similar tastes, Scott. From first viewing it in January, I have not liked the bigger badge nor have I liked the neon blue paint inside the big badge. The U.S. Toyota folks didn't really like it, either, but this is one that Japan said was going to happen.
    I don't know that there is any way to replace the front one if you have the Prius V w/ Adv Tech Pkg. Otherwise, I think you could paint over the background. I would consider it but for the ATP.
    One reason I chose the Blue Ribbon Metallic was my hope the neon blue in the badge would not be as obvious! It is still quite distinct, but I don't believe it stands out as much as it does with other colors.
  5. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Yeah the car is going to look awful with the badges removed, there will just be a large flat, indented oval spot...
    Its just a badge guys, ignore it.
  6. neilz
    neilz Member
    134
    Staten Island, NY
    It's a green car.The badge should be green.
  7. hptsang
    hptsang Member
    139
    Houston, Tx
    I think sigma automative sell the blacken set you can replace it with your Blue badge but it will cost you like at least $200
  8. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    replace the thin plastic film with one of a different color? It's not brain surgery..LOL
    I actually like it with my silver Prius
  9. dc202
    dc202 Member
    230
    22
    Pacific Northwest
    There are a number of Toyota executives who are Dallas Cowboy fans, hence the blue and silver. :p
  10. G3priusV
    G3priusV Member
    131
    17
    UT
    Removed.
  11. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
  12. mcamp52
    mcamp52 New Member
    32
    Central Florida
    I don't care much for it, but I think I'll just leave it alone.
  13. RoyThePriusGuy
    RoyThePriusGuy New Member
    186
    25
    phoenix
    Why don't you mod it, as the attached link points out below? Sounds like a simple fix. What color is your car? If red, it's a must-do.... Most any other color seems to be owner-optional.
  14. Tideland Prius
    16,678
    blue is the green in Japan. That's why. Note that the headlight covers are also tinted in blue. On Lexus models, the taillight covers are tinted blue.
  15. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    The sky and ocean are blue. Blue is associated with nature, which is why it is green.
  16. TalkingMuffin
    TalkingMuffin New Member
    26
    27
    Earth
    i love the blue.
    why everybody gotta hate?!?
  17. concertinajohnnyboy
    104
    Minneapolis
    I think blue is beautiful. Thank you Toyota.
  18. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    The rear emblem can be popped off pretty easily. The blue plastic can be removed revealing body color, then emblem snapped back on. My avatar shows the results.
  19. maomao
    maomao New Member
    93
    DC
    Any tip abotu how to pop off the rear emblem without body damages? Thanks.
  20. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    It's marginally acceptable with some colors but seems to clash badly with red and sandy beach. I think it looks OK on my silver car and actually matches the blue background of the Oregon Crater Lake license plates.
    If you search the Gen3 Modifications forum you will find 3 or 4 threads on changing the color. But as previously stated the front one on the radar equipped cars might be best left alone, it must be transparent to the frequency of the radar unit which is mounted a few inches behind it.
