Blue Magnetism Touch-Up Paint any one?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Charly Brown, Mar 22, 2018.
  1. Charly Brown
    Charly Brown Junior Member
    26
    Miami, Florida
    2018 Prius Prime
    OK, less than a 1,000 miles and I already got two nice dents on my Prius Prime hood. They are relatively small but you can see the metal underneath which contrast with the blue and are very noticeable, two white dots right there. If they were on a door or on the front of the car I wouldn't care but right there in the middle of the hood kind of sucks
    Any experience with Toyota touch-up paint? Is it worth it or would it look worse? I found the color, Toyota 791 and the original Toyota touch-up paint online, around 20 bucks but not sure if it is a good idea
    Disappointed that my hood has "factory paint protection" and it dented so soon. Dealer didn't charge me extra for that supposed protection but still. Will take a picture a post it later
  2. Diemaster
    Diemaster Active Member
    290
    260
    so. cal
    i ordered a touch up paint from parts department and it took 1.5 weeks to arrive. Dried paint is (i think) a exact match. will post pics later.
    Dael likes this.
  3. Wuzki
    Wuzki Member
    101
    34
    los angeles
    I got so many dents in my front. I will have to touch up every week. It’s something unavoidable, so I chose to accept the condition of my situation. I force myself to look at my car as Dalmatian. Such painful decisions to make
    Dael likes this.
  4. Mendel Leisk
    38,659
    Clean chip and a little bit beyond with isopropyl alchohol. Make sure there's no loose paint. Apply touch up paint, maybe with a tooth pick, as surgically as possible, and stop while it's still wet. Wait an hour and apply a second time, going a little further. If the touch up paint is pen style, with color coat and clear coat, I'd be inclined to avoid the clear coat: I've found it prone to lift the color coat.
    If you're getting a lot of hood chips maybe need to increase following distance.
    Dael likes this.
  5. Charly Brown
    26
    Miami, Florida
    2018 Prius Prime
    got the touch up paint pen. On top of the plastic cap there is a tip made of a hard material, feels slightly rough to the touch. I read the instructions on the bottle and it says to use that hard tip BEFORE, then clean the area with isopropyl alcohol and then apply the paint, any experience using this tip? is it like some sort of cleaner or rust remover by abrasion?
  6. Mendel Leisk
    38,659
    Sounds like a Dupli-Color pen. Look on the box, it's described as "Abrasive tip, removes loose paint and rust". I've got one of those, and also a Toyota Pen, not sure which I prefer.
    One thing with the Dupli-Color, seems like I ALWAYS manage to open it upside down, the first time, lol.
  7. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    I can understand your concern, and admire your sense of pride in your Prius, but here's a tip: don't agonize over the small stuff. I look on the small dings and chips on my 2009 Gen II (131,000miles) as scars (think Heidelberg) - they can be filled/repaired/painted with touch-up paint, but my Prius wears its scars with pride! (y):rolleyes:
    In fact, here's what I did with my Toyota Corolla DX Wagon, after a fallen branch put a very distinct (but small) dent in the tail-gate. The dent was about ½" deep, and about 1½"x1½", so I sealed where the paint had broken, filled it with Bondo, and painted it (to seal the filler) the car was white, and fashioned a "patch" from a piece of grey GafferTape, with rounded corners, and then made some "sutures" from back GafferTape, each "suture" being about ½"x¼" and stuck at right-angles to the edge of the patch, making it look like the patch was stitched to the car. (I'll try to find some pics.) and yes, the hard nib is to prepare the surface, just follow the instructions! Good Luck!
  8. pilotgrrl
    pilotgrrl Senior Member
    891
    1,796
    Chicagoan in TX
    Not sure if this applies to all the extra cost colors, but since you said you saw white underneath...
    You might need to put a base coat of Toyota Super White, then the special color, then top with clear coat. Definitely applies to Blizzard Pearl, may apply to the other metallic colors, YMMV.
  9. AnneLW
    AnneLW Member
    118
    95
    California desert
    Where on-line did you find the blue mag? I've been looking and failing.
  10. Mendel Leisk
    38,659
    McGeorge Toyota is one I use, just for part look up. No dealership nearby?
  11. Charly Brown
    26
    Miami, Florida
    2018 Prius Prime
  12. Stever56
    Stever56 Junior Member
    US Crestwood, illinois
    Rc9000 likes this.
  13. Mendel Leisk
    38,659
    Just walking into a local (Canadian) Toyota dealership parts department, their touch-up pen (color one end, clear the other) was $13.58 (CDN). FWIW, part number (for Classic Silver Metallic, code IF7) was: C0355-001F7.
  14. Charly Brown
    26
    Miami, Florida
    2018 Prius Prime
    Just FYI, yesterday I used the paint, kind of tricky to control the flow of paint using the pen side, one of the dents was very small and I had to clean and reapply the paint a few times as it was too much liquid at every push of the pen, it takes some "finesse" to do it right. Other than that it works pretty well, exactly the same color and when it dries the two dents were replaced by two little circles of paint, much less noticeable than the white spots.
    Didn't use any primer as I think the exposed area was the primer, it didn't rust after a few weeks of exposure to the elements. Haven't applied a second coat or polished the area as the dents are small, I don't think it is worth it
  15. Mendel Leisk
    38,659
    With the pen style and tiny dings, I've resorted to loading it up with paint, then picking up a bit of that paint with a toothpick, applying it thus.
    pilotgrrl likes this.
  16. MSAGRO
    MSAGRO 2010 Prius Five with Advanced Technology Package
    259
    227
    Portland Oregon
    8570B773-423C-4DFA-82DB-077C44FCD6C7.jpeg 0DEBD6C9-5722-4A91-AB71-088CD7F24FDD.jpeg Best touch up brush ever...one dab on chip fills in perfectly.. then toss when done.
    Pdog808 and Mendel Leisk like this.
  17. AZeus
    AZeus New Member
    Boise, ID
    2018 Prius Prime
    Thanks for the link!!
  18. schja01
    schja01 One of very few in Chicagoland
    1,744
    1,162
    Chicagoland
    2018 Prius
    I just picked up some Hypersonic Red (3T7) from ebay seller "oremautogroup" which is a toyota dealership on the west coast.
    It consisted of two 0.5 oz tubes (Base color and Clear Overcoat) for $20. It's the real mcoy. Got it in 3 days.
    Here is theie link for blue magnetism $16.97 Free Shipping:
    https://ebay.to/2PzxT9K
  19. Pdog808
    Pdog808 Active Member
    414
    271
    Los Angeles
    2018 Prius Prime
    Damn - that's a great idea. Plus a friend of mine is a dentist. Perfect :)
