Blue neon
Discussion in 'Gen 2 Prius Accessories & Modifications' started by roger, Oct 15, 2004.
  1. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Probably not.
    Here is what I believe to be the relevant CA Vehicle Code Section:
    25102. In addition to the lamps otherwise permitted by this
    chapter, any motor vehicle may be equipped with lamps on the sides
    thereof, visible from the side of the vehicle but not from the front
    or rear thereof, which lamps, together with mountings or receptacles,
    shall be set into depressions or recesses in the body of the vehicle
    and shall not protrude beyond or outside the body of the vehicle.
    The light source in each of the lamps shall not exceed two
    candlepower and shall emit diffused light of any color, except that
    the color red is permitted only on authorized emergency vehicles.
  2. wb9tyj
    wb9tyj 2017 Prius Prime Advanced
    389
    95
    Indiana and Nevada
    In Indiana, Blue neons violates the Indiana Blue Light law...Blue Lights are authorized on vehicles belonging to Firefighters and authorized emergency vehicles...ie Police vehicles. No Blue light may be showing in any direction except in the above aforementioned. police run red and blue, firefighters run blue...emergency medical techs run green, and fire trucks, ambulances run red with combos of white.
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    So i can as long as the light source isn't seen.. ok.. i'm sure neon lights are not considered too bright
  4. IsrAmeriPrius
    4,333
    Southern California
    I don't have the patience to go through every CA Vehicle Code section regarding lights. You can access it at this website: CALIFORNIA VEHICLE CODE.
    The lighting equipment is covered in sections 24250 through 26106.
