Bluetooth Audio display
Discussion in 'Prime Audio, Electronics, and Infotainment' started by eveyo, Nov 20, 2021.
  1. eveyo
    eveyo Junior Member
    85
    2019 Prius Prime
    Hey guys I just got a new phone and since then the display doesn’t show what music is playing. music plays but there is no info displayed. I had a galaxy S21. now I have a pixel 6. I checked the settings on the phone and the car. is the new phone just not fully compatible? I have a prime premium 2019. Any tips would be helpful thanks guys.
  2. speedwagon
    speedwagon Junior Member
    Had similar issue with Prius 2015 and a new Android phone today. Got it fixed by lowering the Bluetooth AVRCP version to 1.3 in the Developer options on Android.
    Go into Settings -> About phone, find "Build number" section and keep tapping it until it says that you are now a developer. You should see a new menu option show up: Settings -> System -> [Advanced] -> Developer options. Inside Developer options menu you should see "Bluetooth AVRCP version". Set that to 1.3. That's it. Disable and enable back Bluetooth so that your phone re-connects to the car and everything should work now. You can hide the developer options menu with a toggle at the top of Developer options section if you don't want it to be shown, or you can leave it be.
    #2 speedwagon, Dec 15, 2021
