bluetooth garbled
Discussion in 'Prius v Audio and Electronics' started by chickenvet, Oct 29, 2013.
  1. chickenvet
    chickenvet New Member
    2013 Prius v wagon
    Connecting a Droid 4 with 2013 Prius v (lowercase v) bluetooth but words ar garbled. Reverted back to my Jabra Freèway bluetooth speaker phone which is much clearer. Our company just purchased 6 Prius V and we're all having the same bluetooth garbled communication. Can anyone tell me how to tweek Prius bluetooth to get better audio output?
    Ken
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,877
    6,829
    Texas Hill Country
    Works fine with an IPhone, IPAD and Motorola flip phone. No adjustments needed. Perhaps there are some options in the Droid.
  3. Whirldy
    Whirldy Junior Member
    89
    ***The iPhone pairs fine. Would be nice IF music wouldn't immediately begin when paired though.*** :(
    Turn off signatures in Tapatalk Tapatalk
  4. rjparker
    10,877
    6,829
    Texas Hill Country
    Mine is so clear some don't realize I am on a speakerphone in a car. I would recommend keeping the windows closed and the fan on medium. The mic is on the maplight. I would try someone's iPhone and see if it sounds good. If it does work well, then it might be the Droid.
  5. mikefocke
    4,068
    1,855
    Sanford, NC
    Fine with a Samsung Galaxy II Droid 2.3.6
  6. chickenvet
    2013 Prius v wagon
    Ok. Sounds like it's a problem with connecting to a Droid4...... does anybody have experience with connecting Prius v (lowercase v) with Motorola Droid
  7. Rainy
    Rainy New Member
    I am having issues with the fan of air conditioner on LOW and people tell me out sounds like all the Windows are down and going 90mph and they can't hear me and get frustrated with back ground noise. Id's there a fix or solution tho this or is it a bad design issue? The service advisor said it was normal and turn off while talking. He also said no one else has complained about this being an issue.
    Please help and advise off there is an adjustment off fix tho this.
    Thank you for your help!
    Rainy
  8. rjparker
    10,877
    6,829
    Texas Hill Country
    I have no problems with the mic which is located on the ceiling next to the map lights. I would suggest the dealer change the part. Or look into a possilbe windshield leak blowing air into that assembly. You could test in the driveway by doing a phone call: a) without the AC on and then b) with the AC on but not moving.
  9. Cristino
    Cristino Junior Member
    46
    24
    Bayamon, Puerto RIco
    Rainy,
    I used to get the same complaints. In my case the center vents were aimed too high and air was blowing into the microphone. Try lowering the center vents and test again...
    Good luck!
  10. KennyGS
    KennyGS Senior Member
    1,243
    1,046
    Keystone State
    I have the same problem with my hatchback -- garbled, cuts in/out.
    I use an iPhone 5, and it seems to only have this issue when I'm driving/moving. Otherwise, it sounds fine when I'm parked (not moving). BTW, my windows are up, there's no (substantial) blowing from vents.
    Maybe there's something to this?
  11. Air_Boss
    Air_Boss Senior Member
    4,237
    1,192
    New Yawk
    Works fine on Nokia WindowsPhones 1520 and 900
