BLUETOOTH OFF , Unable to turn on???HELP
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Manny koutalides, Feb 10, 2016.
  1. Manny koutalides
    Manny koutalides Junior Member
    For some reason recently, I noticed my bluetooth was not connecting, when i went to troubleshoot it, I realized some how the Bluetooth was OFF, mind you, i never turned it off. Now when I click on Bluetooth OFF to turn it back on, nothing happens and i don't have access to some of there other bluetooth features without it being turned on. I tried everything to get it to turn on, has anyone else had this problem. Im very familiar with paring and bluetooth in general and have been using it on my 2012 prius c 3 since i purchased the car new. I even went as far as disconnecting the negative battery terminal to see if that would reset it, but it didn't, any help would be greatly appreciated
    thanks again
    Emanuel
  2. InPriusLove
    InPriusLove Member
    165
    40
    California, US
    2015 Prius c
    Electronic components do break down of their own accord. You may need a repair of the console to some minor degree.
  3. RootBreaker
    RootBreaker Member
    98
    52
    Williamstown, NJ
    Interesting. I came here to search as I just took my car in for 50k oil/tire rotate and found I am having the same issue. Did you take your car in recently. Think they would do a flash of some sort to fix things like recalls?
    Galaxy Note 3
  4. Brett121
    Brett121 Junior Member
    Brentwood, California
    I had the same issue. Bluetooth just turned off one day and wouldn't let me turn it back on.
    I updated the Entune on my 2012 Prius 3 to version 5.2.0 and that fixed it.
    redcoral likes this.
  5. JJMe
    JJMe New Member
    Chicago, IL
    How do you upgrade the Prius?
  6. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Download the update to a usb stick and plug it in.
  7. Got2bnu
    Got2bnu New Member
    Thought i would share my Fix, Had the same problem, any time a 12v battery is replaced, your phone needs Bt reset too.
    2015 prius two, 57031 stereo, BC no Nav, no en-tune software upgrade available from Toyota web site for the 57031.
    Settings, Bluetooth, Detailed Bluetooth settings, (greyed out) Bluetooth power OFF.
    Turned out to be my iphone x Bt settings click on “Car Multimedia” then tap forget this device, now go to add device, on the stereo and “Car Multimedia” will show back up on your phone, click on it,
    Sometimes electronic components dont fail, most of the time, its user error.
  8. CaseyHealer
    CaseyHealer New Member
    Plug it in where?
  9. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    USB port next to the aux in.
  10. Smallssyy
    Smallssyy New Member
    Hawaii
    I’m having the same problem. Did it work? What update?
  11. Smallssyy
    Hawaii
    Did you try it? Did it work?
  12. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    I haven't done it, but others have.
