Bluetooth Protocol (Feature)?
Discussion in 'Gen 2 Prius Technical Discussion' started by Hytec, May 27, 2008.
  1. Hytec
    Hytec New Member
    236
    MS Gulf Coast
    I can't transfer the phonebook from a Kyocera K323P cell phone to a 2005 Prius (Package #6), otherwise I can place and receive calls with no problem.
    I contacted Cellular South Tech Support for assistance, and they asked if the Prius uses FTP or A2DP feature (protocol) for data transfer? Does anyone know?
    Thanks
  2. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    I can't tell you what the protocol is but this is very common. You will have to transfer one number at a time.
  3. Hytec
    Hytec New Member
    236
    MS Gulf Coast
    David, thanks for the reply.
    Unfortunately, transferring one number at a time doesn't work either.:(
    I believe the problem is within the Prius Communication firmware. The Kyocera phone Contact List displays, and transfers, phone numbers formatted as (xxx) xxx-xxxxx, with or without the preceding 1 for long distance access. Apparently the Prius firmware can not decode the open parenthesis, and then rejects all characters following. I notice the Prius accepts a preceding 1, but all following are rejected due to the open parenthesis. Furthermore, in the case of the Cellular South access number (*611), all digits are accepted by the Prius firmware.
    So, until Toyota updates the Communications firmware (and makes it available at no cost), I will enter all necessary numbers by hand.
