Bluetooth turns off after 60 seconds.
Discussion in 'Prius c Audio and Electronics' started by rjdriver, May 27, 2016.
  1. rjdriver
    rjdriver Active Member
    406
    167
    Rhode Island
    Thanks for the suggestion, but now that mine is back to normal I don't want to turn that off. I have this nice app that reads text messages to me through the car's speaker system. I need Bluetooth to have text access for it to work.
  2. dr.Berkes Attila
    dr.Berkes Attila New Member
    Hungary
  3. dr.Berkes Attila
    Hungary
    The solution comes from SID000.
    She found it at an android forum.
    I stumbled upon this mysterious " Prius bluetooth off " issue today and this solved the problem right away.
    ( 2012. Prius Plug-in
    Samsung Galaxy Note 8 )
    ▪Bluetooth
    ▪Paired devices
    ▪Settings
    ▪Disable text
    Thanks for helping each other.
    bisco and mryder66 like this.
  4. mryder66
    mryder66 Junior Member
    South
    Thanks to Dr. Berkes Attila. I Simply turned off text messaging in bluetooth settings for car multi media on my phone, and It works like a charm! No more Bluetooth shutdowns
  5. bobk37
    bobk37 New Member
    Philadelphia, PA
    I am so glad I found this thread. This started happening to me yesterday, and I never would have thought that my phone would be the one causing the problem. I can understand a phone issue causing a bluetooth connection to be dropped, but I still can't understand how a phone can cause the car to essentially shut down its bluetooth connection, to such a point where you can't even start it up again without restarting the car!
    Nonetheless, once i stumbled on this thread, I realized that I had enabled the Samsung email app on my phone the day before (it's a Samsung S7). At first I tried changing the email app's permission, so that it couldn't update system settings, but that didn't help. So I uninstalled it (I don't think the uninstall process deleted it since it's one of those native Samsung apps that came with the phone). And that fixed the problem, and my bluetooth stays on.
  6. Hk996
    Hk996 New Member
    I found this forum when I had this issue with my new Samsung Note Ultra. I just added the phone and 2 days later I noticed that it wasn't connected while driving. When I reached my destination I noticed that bluetooth was turned off and I couldn't access it. After turning off and on the car, I realized that it turned off after about a minute. I found this post off of google and tried a couple things.
    I deleted netflix and the phone from car and vice versa. When I reconnected, I chose it to not accept text messages. That seemed to work. I have since reloaded Netflix yesterday and it still seems okay.
    I thought I would update this forum since this phone just came out and it was very helpful to me.
    Thanks for the info!
  7. Jay Kang
    Jay Kang New Member
    Houston, TX
    This really help, it solved my problem. I thought that I have problem with the hardware, then I tried not connecting my phone bluetooth. My Prius bluetooth is stayed on for 30 minutes. So I know it is software problem. By not allowing text messages, bluetooth is working perfectly.
  8. domingo2610
    domingo2610 Junior Member
    paraguay
    My prius c is from 2013 and I have the same problem. I just want to be sure that we have the same radio, mine is this:
  9. rjdriver
    406
    167
    Rhode Island
    Like my own radio, gunfam's profile would indicate that his C has the 6" touch screen system used in the trim levels 3 and 4 back in 2012 and 2013. That doesn't mean your issue might not be coming from the same source.
