Bluetooth with GPS in a phone
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Ilya, Mar 25, 2013.
  1. Ilya
    Ilya New Member
    Sunnyvale, California
    Hi All:
    I run into this very annoying problem with my PriusC 2 and android phone (2.2). BT connects fine. I can receive calls fine. But, every time BT is connected and I go to the media page of the audio system the phone's music player starts up automatically. It is possible to pause it. However, if I have navigation running on the phone every time the program is trying to say something the music resumes and overwrites the directions. In the BT settings it is possible to disable the audio, but then nothing can be heard at all.
    Does anyone know what settings have to be changed to make sure that the music player doesn't start (I understand that it may be phone rather than car question)?
  2. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    it's on the phone's side. you'll have to rummage thru the settings to see if there's an automatic resume option in your music player. if not, unfortunately, you'll just have to deal with it.
  3. cmstlist
    cmstlist Member
    183
    40
    Toronto, ON
    My Galaxy Nexus fades the music while navigation speaks, then the music unfades. When I have no music playing I do not experience the problem you are seeing.
    It could just be a bad build of Android 2.2 which is heavily outdated by now. So I'd point my finger at the phone. Which device and carrier?
    In newer versions of Android you can also go into the Bluetooth settings and disable media audio while leaving phone audio on. So if you're OK with the GPS sound coming out of the phone's speaker, you can have it connected for phone audio without it also trying to be a music player.
