Bluetooth won't turn on
Discussion in 'Prius v Audio and Electronics' started by Lats118, Dec 29, 2016.
  1. Lats118
    Lats118 Junior Member
    CT
    I have a 2012 Prius V and I've been using bluetooth successfully until just now. My phone wouldn't connect so I went to Setup/Bluetooth and saw that bluetooth was off. I touched the screen to turn it on, but it wouldn't come on.
    I turned the car off then on again, and bluetooth turned on but then went off after about a minute and I still couldn't turn it on. I updated Entune to 5.2 (I was at 5.1) but that didn't help. For some reason my bluetooth in the car won't turn on and stay on. My phone still knows that it has paired with the car in the past (I can see the connection entry). Has anyone else had this happen??
    redcoral likes this.
  2. Air_Boss
    Air_Boss Senior Member
    4,243
    1,193
    New Yawk
    I've seen this once or twice on our 2012 v Five, associated with prior pairings.
    Delete the historical pairing, re-pair, re-connect and it works again.
  3. Brett121
    Brett121 Junior Member
    Brentwood, California
    That's assuming you can get to any devices that are paired to the car.
    My Bluetooth won't turn on at all (just says "Bluetooth Off" and wont turn on if i tap it) so I can't get to the paired device list (it's greyed out.)
    Alex Azar and radiocycle like this.
  4. radiocycle
    radiocycle Active Member
    550
    78
    Vallejo, CA
    Yes, same here....
  5. Brett121
    Glad I'm not alone! But I feel for ya. First time I've had Bluetooth in a car. It worked great for two months and then it turned off and won't turn back on. Frustrating.
    Friend of mine suggested updating the EnTune software via USB, but the update is elusive. I'll definitely update this thread if I find the fix!
  6. Brett121
    I think I found the fix. I can't post links yet because I haven't made enough posts, but if this works I'll PM you with the results and fix I used.
  7. Brett121
    I updated to 5.2.0 and that fixed the Bluetooth issue.
    We'll see if the fix holds
  8. Air_Boss
    4,243
    1,193
    New Yawk
    You refer to the USB stick 5.2 update?
    Brett121 likes this.
  9. Brett121
    Correct! Once I ran that my Bluetooth came alive again.
    redcoral and Air_Boss like this.
  10. eaststar
    eaststar New Member
    california
    I have 2013 prius 2 and having a same issue with bluetooth power won't turn on.. can anyone tell me how did u fix this problem? I have the audio system with 57031 model. thank you
