Bluetooth won't turn on
Discussion in 'Gen 3 Prius Audio and Electronics' started by Anya, Jul 23, 2018.
Tags:
  1. Anya
    Anya New Member
    Austin, Texas
    2013 Prius Plug-in
    I've had my Prius for almost 2 years now, and I've never had a problem with the bluetooth. About a week ago my bluetooth turned off and now I can't get it to turn back on. When I press the "Bluetooth off" button, nothing happens.
    Has anyone else had this problem? And is there a way to fix it?
  2. Erniel
    Erniel New Member
    New Jersey
    2014 Prius v wagon
    same issue on our Prius V. we have also had it for about 2 years. Bluetooth will not turn on. Stuck in off mode. cannot make or receive calls. phone shows in paired list. with Bluetooth off cannot remove and re-pair phones.
    let me know if there is a way to reboot without having to go back to dealer.
  3. Sue Mc
    Sue Mc New Member
    Los Osos CA
    I recently had the same problem on my Prius Four, it was working fine for over 5 years and suddenly it turned off a couple weeks ago. No update available for the Entune software. Stuck in the off mode.
  4. Fyretuck
    Fyretuck Junior Member
    Lyons, OR
    My 2013 has has the same problem and I have had the radio replaced twice, under warranty. Now the warranty is expired. I am thinking about replacing the Bluetooth module on the radio, as the radio works just fine otherwise.
  5. duckbutter
    duckbutter Junior Member
    New to app. My Bluetooth disappeared on 2013 prius c 2. No longer an option on radio screen. Is there a thread for replacing the Bluetooth module only? IMG_20181211_170234.jpeg
  6. n23
    n23 Junior Member
    28
    Tampa, FL
    Mine recently did the same thing, Bluetooth Off (2015). It started working again like normal at the next restart. Not sure what the issue is but it did coincide with my phone switching from bluetooth audio streaming to picking up a call. I don't know if maybe the change in protocol borked the radio. I've tested it a few times since and can't reproduce it. Sorry I can't help more.
  7. liskipper
    liskipper Member
    373
    79
    Long Island, NY
    My 2013 has the same problem. Bluetooth drops in the middle of a call or just running entune traffic app. Restarting car brings it back, but only for a few minutes. Just started doing this.
