BMS Bottom Balancing HV Battery?
Discussion in 'Gen 2 Prius Technical Discussion' started by offib, Dec 24, 2017.
  1. offib
    offib Member
    162
    96
    Dublin
    Four Touring
    Firstly, Happy Christmas!
    Secondly. I'm aware of the typical rate of discharge for NiMH cells. The rate of which being steep from 100% - 80%, then stable, then steep again from 40% and below. I presume this is why (when using an OBD adapter and app) the time to increase or decrease the SOC is far quicker at 70% - 80% or 6 green bars.
    I got a bit of a scare. I was rolling in EV mode (not the button) towards home, it got to 48% and when parked, the SOC shown on the app kept diving and diving. Engine started at 43% but - possibly to my demise - I interrupted it and rebooted the car into ACC mode. The draw was only -0.07 amps but the SOC kept dropping, as fast as 0.5% every 2 seconds. 40%, 35%, then 30% for one purple bar and the dip started to slow down at 28%.
    Then after the SOC dropped at a normal, long, patient pace as it would ~60%. I thinks it's just the BMS updating itself to the HV's parameters?
    I kept an eye on everything. Delta voltage was still at most under 0.2V and kept inline with eachother, temps were 23 - 27 degrees celsius. Average block voltage wsa still low ~15 volts and the total HV voltage was still hovering at 209.something volts.
    Nothing appeared wrong other than the SOC. Is the car doing something its supposed to- which I think it is, or should I start to cry? Maybe I can recreate this with the EV button and get a pic of it?
    Averaging 60mpg ~240 miles. Busy city driving at this week of the year.
    #1 offib, Dec 24, 2017
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Others will correct me if I'm wrong, but I don't think the car does anything to balance the battery for a combination of reasons.
    One reason is that it keeps the state of charge between 23% and 80% (if I remember the numbers correctly - something like that, anyway).
    Combine that with the fact that all the terminals are tied together and it can't charge or discharge one cell without doing the same to all of them, and you come up with one reason for HV battery failures - the cells get too far out of balance and you eventually have one at 80% and one at 23%. That's why Hybrid Automotive sells so many grid chargers; to do what the car does not.
    As I understand it, the BMS just managed the overall SOC as your driving pulls power from the battery or replaces it.
    offib likes this.
  3. offib
    offib Member
    162
    96
    Dublin
    Four Touring
    Thanks for the reply. Yeah, I dream of having the HA kit when I need it. I should be more direct. Certainly the battery itself is not being balanced, but rather the computer's take on overall SOC? I do remember some folks here discussing that.
  4. jerrymildred
    11,517
    14,164
    Tampa, FL
    I can't really think of a good explanation for what you observed other than something was using power from the traction battery. Since you had been driving in EV and it was hot (I assume you also were running the air conditioner), the battery cooling fan would probably be running faster than usual.
    As far as I know, the car is always aware of the state of charge unless you change the SOC with the car off, such as when using the HA grid charger. I don't think the system was correcting its data; I think the data itself was changing, but don't know why.
    As for shutting it off and going to ACC mode, I agree that that was probably not a good thing to do, unless it was just for a moment to open or close windows or something, but I don't know what effect that could have had on the traction battery's SOC. Maybe someone else know more about that aspect.
    In the meantime, I would not be concerned unless you are seeing rapid changes in SOC such as swinging between green and purple bars in just a couple minutes. That would be bad. With a 2007, though, you should be maintaining it with a grid charger to try to ward off that eventuality.
    offib and Raytheeagle like this.
  5. offib
    offib Member
    162
    96
    Dublin
    Four Touring
    Cheers man! It was just mild this past week, like 10C, so heater more like. The temps in the HV battery were under 30 and as expected the fan didn't engage. Everything's fine really. I rarely see 3 bars unless I'm deliberately taking it gently for a while - for a change. Again, the only strange thing before this odd instance was how quickly the SOC raised after the 65% or 6-green bar mark.
    About the draw of power, in Ign-IOn mode it was ~1.3V as it would normally and <0.1V in ACC mode. What would
    I should mention that when seeing the SOC drop off the face of the earth, I did turn on the ignition and let it charge back up to 51%. It took a while actually at a constant 20 amps or so. After that, I drove it with 4 passengers and not a thing felt or looked wrong.
  6. jerrymildred
    11,517
    14,164
    Tampa, FL
    Ah! When I saw "temps were 23 - 27 degrees celsius," I misread that to be ambient temperature and thought you must be having quite a heat wave. :D
    Glad that it's working well.
    offib likes this.
  7. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Both of those things started happening to me after my old HV battery had lost a significant amount of capacity. It didn't spell a sudden death of the HV battery or anything, it kept going for quite a few more years after that, but it did eventually get worse and the HV battery die.
    What you are seeing is the Prius battery monitoring getting out of step with the actual battery charge level due to reduced battery capacity.
    When the battery SOC gets very high then the BMS will recognize that it's full by seeing the module voltages are relatively high, and the green bars will come up pretty quickly when that happens. Then as you use up that charge the BMS coulomb counts the charge out and the SOC only drops fairly gradually. If however the battery A-hr capacity is low, then it takes less coulombs (A-hrs) to discharge it than the BMS expects, so some time when it gets to about 4 bars it will suddenly figure it out (due to low module voltages) and the SOC will quickly recalibrate to about 1 or 2 bars.
    Conversely, when the battery is charging up after being very low, then the BMS will coulomb count the charge coming in and initially the SOC will only rise slowly. Again the BMS will over estimate the battery's A-hr capacity until it gets to about 6 (nearly 7) bars, when it will suddenly figure out that it's actually full (due to high module voltages) and those last two bars (7 and 8) will come up unexpectedly quickly.
    If you don't run the battery down to low SOC levels (4 bars or under) or regen to high levels (7 bars or more), but just stay in the middle SOC region, then you might not see this behavior and it might still coulomb count quite happily despite the reduced battery capacity. But when you get extremes of SOC (in either direction) then you will get a subsequent recalibration of SOC some time after that.
    With mine it stayed like that for a few years and gradually got worse. Eventually it would "max out" very soon after hitting 6 bars SOC on the way up, and bottom out soon after hitting 4 or 5 bars on the way down. Then one day it (the HV battery) died completely and I replaced it. As soon as I got the new HV battery all of that funny business with the SOC stopped happening.
    #7 uart, Dec 27, 2017
    m.wynn, jerrymildred and Raytheeagle like this.
  8. jerrymildred
    11,517
    14,164
    Tampa, FL
    Good word picture of a complex system, @uart. I like to picture vertical bars like in a bar chart, each one at a different level reflecting its own state of charge. They all move up and down together. If one cell is radically lower or higher than the other, it goofs up the whole system. If you could get all the cells showing individually that way on one screen on Torque or Engine Link I think it would be revealing. Maybe a little mind boggling, too.
  9. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Yeah Jerry, when there are cells out of balance like that then it definitely reduces the apparent capacity of the pack. The true capacity of the cells also reduces over time, and the weakest cells are the most likely to get punished when you get those large SOC excursions.
    The SOC bars on the energy display also vary in a non uniform way, with some representing larger amounts of charge than others as shown in the following chart. I suspect that this is mainly for the benefit of the driver, so that they see what they want to see - as in a display that mostly shows nice stable levels at around 6 or 7 bars. This is why people usually notice any anomalous drop in SOC at the low end, but it's not always noticed so much at the top end where the very "broad" 7th bar tends to hide it.
    offib, jerrymildred and Raytheeagle like this.
  10. jerrymildred
    11,517
    14,164
    Tampa, FL
    Nice graph!!! Really illustrates why the monitor spends so much time on bars 6 & 7 in a healthy battery.
  11. offib
    offib Member
    162
    96
    Dublin
    Four Touring
    Ah well, if it's the death of me (the battery), then at least I know it will. So, for you, was this because the HV's delta voltage was too far apart, or was it like internal resistance?
    No be the right time to get that HA charger. Like I want to drive this car as long as possible. I'm sure I can daily it until its well into its 20s without any accident.
  12. offib
    offib Member
    162
    96
    Dublin
    Four Touring
    I cheaped out and just got an OBD II Bluetooth- yoke-thingy-mabob and used Prius Doctor (??), I also have the Torque app but it fights with the other app. So it doesn't seem to connect when the other is at times, then visa versa.
    It shows the voltage of individual modules. You're talking about the cells man, right? Like the 7 prismatic ones in each module?
  13. jerrymildred
    11,517
    14,164
    Tampa, FL
    You lost me there. I don't know anything about the "Prius Doctor," but it's probably showing voltage in blocks. But there is more than one cell per block. Your Prius has 168 cells altogether. Since the cells are grouped, the BMS only knows the voltage for blocks, not individual modules or cells. And there is one positive and one negative wire going from the inverter to the battery, so they all get the same voltage when regeneration takes place.
    offib and uart like this.
  14. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Well I'm embarrassed to admit that I didn't do any monitoring or maintenance of the battery modules at all. We just drove it until the battery died (at 314,000 km) and then put a new one.
    When I first got the Prius I dreamed that the HV battery would go forever, but over time I accepted the reality that at some time I would probably need to replace it. Ah, dreams vs reality. :)
    offib likes this.
  15. offib
    offib Member
    162
    96
    Dublin
    Four Touring
    Lol! Nice to see another who knows Father Ted. Ha! And I bet you know how to ride a horse as well.
    I just hope it's not too late for the HA charger.
    Raytheeagle likes this.
