Body Control CAN bus tap?
Discussion in 'Gen 3 Prius Technical Discussion' started by Carpetfuzz, Aug 15, 2025.
  1. Carpetfuzz
    Carpetfuzz New Member
    Ohio
    2016 Prius v wagon
    Hello, I am working on a project for adding custom controls to my Prius. The first step of this is being able to sniff the body control CAN bus. I have found out the location of the body control module, but I need help in knowing what wires go to the body control bus. I have found a gateway on the main bus at 0x631 that through random fuzzing I found can control the windows, but I need to know what traffic to send to the gateway, which means I need a tap into the body control bus.
    If anyone has any info on this, please let me know! Thanks.
  2. Tombukt2
    Tombukt2 Senior Member
    13,765
    2,491
    Durham NC
    I'm pretty sure that's Toyota proprietary information you be hunting a site . That would be reverse engineering these systems . I'm sure they few n far between n
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,878
    6,829
    Texas Hill Country
    There are controls you can do through the obd2 access to the can bus and you could probably sniff those. Many bidirectional scanners do control, read and write things in that manner.
    Some specialized obd2 tools like Dr Prius have decoded battery fan speed controls. In that case it requires continuous writes to override the hybrid system's speed control.
    We have heard of one guy who believes he has decoded the battery ecu traffic in an effort to allow the first safe nimh to lithium battery replacement battery controller. That is not yet a thing but may be on the horizon.
    No one to my knowledge has cracked Toyota ecu coding for "tuning" or any other reason. Toyota keeps their code and most of the logic well locked down. Same goes for their network traffic.
    52,694
  5. Carpetfuzz
    Ohio
    2016 Prius v wagon
    Hi everyone, thanks for the replies. I managed to create a warning light that wont go away, and I think i found the gateway to the body control bus. I will make sure to look into finding service information.
    to clarify, I have already made myself very familiar with everything I can see passively on the OBD port. My "custom controls" are going to be for the battery fan, hopefully making window preset buttons, and adding a foot switch for EV mode. I believe that all of these controls are on the body control CAN bus, which I need to find a place to tap into so I can look for the traffic from these controls.
  6. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    410
    2013 Prius Plug-in
  7. Carpetfuzz
    Ohio
    2016 Prius v wagon
    Figured I should upload the finished project, this was after a lot of hard work but I finally have my custom "gauge cluster" along with an LED strip to see the energy bar without having to glance over. The display and LEDs dim with the other displays in the dashboard too!
