body side moldings - oops
Discussion in 'Gen 2 Prius Accessories & Modifications' started by randyb359, May 9, 2008.
  1. randyb359
    randyb359 Member
    430
    38
    Pittsburgh
    I installed body side molding. Carefully measuring to be sure they were in the proper place. Used the crushstick. When I was finished I realized I never used the alcohol pad on the one side:( I did wash the car before I started so hopefully that will be good enough. I would hate to have them come off in the car wash (I get free car washes for life from the car dealer) I tried pulling on them and they sure seem stuck on. Do you think I have anything to worry about?
  2. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    I think you're OK because you washed your car first, and you've tested it.
    That 3M tape on the back is incredibly sticky.
  3. PriusFan808
    PriusFan808 New Member
    35
    Pensacola, Florida
    I would keep an eye on them periodically. The alcohol is included to also dissolve any wax on the paint that might interfere with adhesion. Is the carwash touchless? The weight of the "curtains" and "wraparounds" inside an older carwash can wreak havoc on mouldings that are loose. The ends of the mouldings is what you want to watch closely. If an end pops up even a little, the carwash could probably snag it. Please don't think I am trying to make you worry but I did work at a car wash and I have seen just about everything pop off from mirrors, mouldings, and antennas. Hopefully it is a touchless or newer carwash without the heavy components I mentioned above.
  4. tbirdhs
    tbirdhs Tbirdhs
    77
    River Edge. NJ
    I also used mineral spirits first to remove wax. More important is the air and metal temp and using a hair dryer to get the chill off the metal.. I installed hundreds of stick on moulding, being in auto body
