Bodywork
Discussion in 'Fred's House of Pancakes' started by futurist, Nov 13, 2025.
  1. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Sat 04 Apr 26:
    Chilly overnight (for us, of course). probably high 50s, which is indicative of high pressure -- so hopefully some nice weather for Wash Day tmw...
    Recently chg'd bedding from the prior setup (expensive memory foam atop cheaper dbl-layer foam) -- which was fine for some time... but had an inkling the way the supposedly higher-value mattress topper were made, were more for some almost-indistinguishable amt of cooling (wif a blended white-&-2-blues color scheme baked in from the factory, apparently to reassure buyers :rolleyes: )... plus a quickly deteriorating capacity to actually wake w/o pain.
    It's so compromised for add'l features rather than actual support -- which is the whole reason why you pay extra for memory foam, the support. What were actually happening... is my hips and torso'd sink into the stuff > 80% of its unloaded thickness (2"), and body warmth would degrade that to < ¼". Leaving the lighter bits of my body floating atop it, esp shoulders and arms. The cooling effect also would last about a min before feeling like slipping on a very oversized neoprene wetsuit over the contact half of my body :cautious:
    Comp'd that wif a pair of cooling fitted sheets... but needing allergy protection due to the ever-persistent dust issue downwind from miles of poorly-managed cropland, meant they had to be very poorly moisture-wicking -- resulting in only slightly less soaking during the month... plus 100% humidity bain-marie-baking us like Cinnabons in our beds, esp when power'd cut out.
    Procrastinated on the solution, since you can't test a mattress topper in the store before buying :p But finally tired of waking wif shoulder and thigh issues from wonky sleep support... so dove into the problem.
    In essence, simply dbl'd the dbl'd original cheaper memory foam, resulting in a luxurious-sounding 4" of topper. This cheaper stuff doesn't have all the claims-to-feature the pricey $50 one did... but significantly more supportive in a way I prefer (not waking w/ upper limb / joint issues). Also sh*tcanned the more impervious (and far more expensive) cooling allergy-barrier fitted sheet of the two, and replaced wif an identical flow-through cooling one, lower allergy rating. Weirdly like two layers of lycra, stretching around like women's leggings... but I'd not steam like a bao in a rainy week.
    Attached the somewhat-comical elastic suspenders underneath, to keep the show tucked and in-place*... and found the whole setup was about half inch less thick than before, hmm. A quick lie-down had me cheering tho, as this simpler setup was indeed far more like a $400 foam mattress -- much more supportive. A sleep would be the litmus test so reserved final judgment for it...
    Got up about 4am (fell asleep ~10pm). Obvi expected the body after using that wonked setup from last summer to now, would object a little bit... and did so, mostly in the neck (old setup allowed shoulders to sink whilst leaving the head suspended, stretching the neck and causing slight neck issues at first, then body adapted). However, turning the head to the other side 45º (an adaptation pre-CPAP to allow more airflow past my apparently fatso-gullet), resulted in 0 pain, which felt weird tbbh. Amazing how when forced we make friends with pain, Stockholm-syndrome-style :rolleyes:
    Moreso the longer hours I'd sleep the worse this issue got... so if rousing before 7 hrs, no problem for sleep length nor pain. And the protest this time were also in neck and L shoulder, but far less than even the best day on the old. So need to give the body a minute to adapt, as injured R knee -- which hated the merest fraction of a point off perfectly fluffed and positioned on the aging conventional mattress underneath -- popped up, no problem. The old setup let the heel sink further into itself than calf or thigh... so knee's bent under tension all night. Apparently this new setup chg'd that, hopefully indefinitely -- can get used to waking w/o needing to nurse both hams / quads a few secs on random days (a sign your knee joint's interior tissues are being held in a position damaging to it over long-term).
    So yeah. Realising and thus confirming, I didn't need to spend almost dbl the amt for the useless, all marketing-blather old topper, was a horse pill. But all fixed now, hopefully :cautious::coffee:
    * got them at Wally's in the search for toppers -- attach wif these odd silicone knobs which wire loops fasten around when sheets cover the knob. Seems like any movement'd sproing these things off in mins... but they've held onto the thicker bad topper + good dbl'd foam, so see no issue wif the thinner setup. Installed correctly, tho... looks like you're trying to hide the fact your topper has both suspenders and a G-string on :LOL:
    bodywork story after day's clients
    sorry, client work today was routine, not enough to remind of past stories. Hope Mon brings something more reportable ;)
    #181 futurist, Apr 4, 2026
  2. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Sun Wash Day, 05 Apr 26:
    Got the 5G finally cleaned thoroughly and ceramic laid down (now past 2wks since getting it back from the body shop). It was filthy...
    Something odd about this week's chore, which came from nowhere, really: I wasn't that sore. Still can't kneel down as in years past due to R knee but wasn't as bad as it has been. Have been on this med ~70d now... and a worrying trend is as I stay on it (haven't missed a dose since the start)... the weaker I feel esp during this once-per-week exertion. But the knee's actually better -- and dovetailing into bodywork... something also happened during the wash & wax, that improved it even more.
    Very strange to go about the tedious task of digging grit and road spray deposits out of every hiding place in the doors and jambs... but oddly, it didn't hurt. Exhausted and feeling a bit older due to it, but none of the wincing pain I normally had on caffeine.
    Given this was the first real wash in over a month... guess my body's compensating by releasing some tone, esp around the knee. Can almost get to a squat, but at the very end have to bail as pain quickly jumps to 9 and above. However today, just working around the fact I can't just drop to a sit on the pavement (to do end caps)... very strange not to have the usual groaning-uncle bleats getting up, or walking to the head after eating lunch (before the wax)...
    Also... reinforced what a waste of time and money it'd been, trying to orbitally-buff the vertical surfaces of the car, esp doors. I'd developed a routine that got max lustre and refined it over months... but ever since giving up on Griot's on those surfaces (leaves a white powdery residue it doesn't on horizontal surfaces), have been using the old trusty Hybrid Solutions Ceramic Spray Wax. But it too doesn't like the buffer... so out of pure frustration, bunged it on by hand, with a couple of microfibre cloths -- and f***ing voila, the best shine of all -- rivalling the Griot's on the roof, which is as flawless as a driveway ceramic wax can be. F***ing shake the bottle, set nozzle to ON and pump a few sprays onto the ground (clears the tube of old ceramic polymer which can affect the finish), and spray a bit on the door. Spread with one cloth, buff with the other, 45 secs max. Like a f***ing mirror, optically shiny :cry::rolleyes:
    So a job that used to take 45 secs per pass x 4 for final finish... now takes 45 per door, and blows the old buffer jobs out of the water. I give up :LOL:
    But was pretty happy the outer surfaces let go of the week's dirt, after just washing and not waxing lest week. Griot's on horizontal surfaces and layered many dozens of weekend's worth of ceramic, is the real deal. Loves the buffer moving even faster than I'd detailed here in a past post, so this is the current Griot's protocol: using the same microfibre towel you use to clear beaded water from the rinse... start on one side of the roof, and gently wipe away any grit and dust, until your fingernails don't catch on anything on random spots. Then shake the green stuff thoroughly, and 4 short brief pumps... immediately followed by the cordless orbital buffer on its lowest speed.
    Move the bonnet fast -- 1m/sec -- in 1m passes over the roof in tight formation, just to spread the liquid wax. When you can see the buffer making swirls on the paint vs. moving liquid around... change to figure-8s from the midline of the roof to the door opening, the entire roof half. Once you begin seeing lustre poke thru hazy areas, change to small circles in the opposite direction of the orbits of the buffer, and slowly move over the roof-half one buffer-diameter at a time, until the haze turns to a mirror lustre.
    The more layers you set down, the better this will look when properly done: that foot-deep shine that mirrors everything around it.
    Apparently... same with the layers of HS on the doors. Sure they'll collect spots and road grime thrown from the front wheels... but just a wash w/ a weak Meguiar's Gold Class wash solution, then a hand application of HS... can't be happier.
    Just blown out tho, with this liver-stunting, caffeine-depriving med still needing another 30d to do its job... need a nap but have other Sunday chores to do :oops:
    Epilogue: whilst reaching over some stuff to get to the back seat... lost footing and hyperextended my R knee slightly, which hurt a bit. But felt a loud but muffled 'pok' near my fibular head walking it off (where a bunch of scar tissue from the injury set in)... and now feels better. As if needed a bit of hyperextension to pull a bit of scar tissue free, or re-seat the knee on the damaged meniscus. We'll see how it feels tmw morning...
    Also: we're expecting more sloppy weather with yet another low-pressure system to our NW, drawing hot humid air across us from the SE. Great... at least I know the car's further protected in case I need to wash / no wax thru that :cautious::coffee:
  3. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Mon 06 Apr 26:
    Quite a pleasant day out there... so far.
    Found a bunch of gnats and mosquitos lying in state atop the 5G's dew-soaked roof... great, forgot many of these damn things got to breed with millions of gallons of muddy slop sitting around, waiting to evaporate. Haven't worried about mosquitos since moving here really (wif the exception of similar downpours... but rarely result in actual bites more than a day)... but with a month's goddamned rain and more on the way... may as well mentally think 'Seattle mode'...
    Tbf... Seattle (or at least where I lived) didn't have that many mosquitos, tho esp in hot weather you could still count on millions of them across your windshield / helmet visor / gear / radiator fins. But as far as getting piranha-frenzied like I grew up wif here in the sugar plantation days... Seattle was rather merciful (DC and AZ were actually far worse). Maybe more natural predators getting them in the larval phase, maybe standing water doesn't really last that long w/ the topography and glacial prehistory (unless of course, people / biz leave used tires out -- which have been vectors for several infectious disease outbreaks -- one I lived thru in AZ in Y2Ks, West Nile).
    The bugs needed watched for in WA I found, were roaches at home, and stinkbugs, and bees whilst riding -- let a big ripe stinkbug hit you in the partially-tipped-up crack of your helmet visor @std-freeway-pace 70mph, spraying its guts into your mouth... and see if you ever sport-tour at speed wif a cracked visor again. Bees, same reason, except barbed stinger in the cornea's another firm suggestion not to -- getting them under the chin of your helmet's bad enough (always toted around beesting ampules under the seat on any ride longer than a day trip).
    Wolfies were comically-bad in WA too... but harmless unless they crawl in bed with you seeking warmth and you roll onto them. Hand-sized furry spiders shared a couple of places I lived in, not a single bad incident if I also took the steps to keep them out of my spaces. Black widows exist in WA, but never saw one. When I lived in central CA, the place is literally infested with them, esp in properties near fields of whatever in the middle of the state. Used to work at a moto shop there, and the farmers would dump their carbs-gunked-from-sitting ATVs in our laps to get fixed for the harvest, sitting in sheds inert -- and several big widows wif grape-sized arses would be your job to discover -- often when they're crawling on your hand, illlch :cautious:
    Target were open after being shuttered over Easter Sunday... and noticed something diff again today. Shelves are haggard, many items gone like the cans of soup I sought. A worker mentioned they'd only gotten one shipment since re-opening, with few of the things they'd ordered... so the problem isn't just that the store were closed 3w... but their restarted shipments have been... selective. There's a main distro warehouse for the chain in Honolulu... so like many other biz have discovered working for big franchises on Maui wif warehouses on O'ahu... when other locations have physical access to the port your order's coming in at, and you do not... they have and will take what they need and dare you to do something about it. Just like O'ahu takes everything else and leaves the neighbor island counties to suck it, basically. Thought this'd be different in a big mainland chain like TGT... but seems Honolulu shens are still the standard.
    But in big news (for a party of one)... the TGT SB kiosk is finally getting compostable plastic cups, like the corp stores have had over a month. Not in my Trenta size tho :cry: But once the paper's spent there'll be leak-proof plastic preventing wiping tea out of my cupholders, hopefully for good :rolleyes:
    hopefully a table story after today's clients
    Okay got one...
    Resembles a case I got about 4y ago, and has moved off-island since.
    Were a bit tense wondering if the day's client -- both a regular and wif chronic issues -- would be more of same as yesterday... but had mixed feelings when their usual malady wasn't on display.
    I don't want clients to come in with different presentations to entertain you; you get what's on my table and the relationship should never be reciprocal, that's what grownups do, I hope. But it was interesting to see this regular with something more from left field: a numbness.
    Saw this client for about 6 - 7 mos at this time, and their regular checkup was to fix a hip issue. Re-align the pelvis, re-set the sacrum, balance thigh muscles attached so they don't regress, send them off. Avid runner but had taken up spinning as a way to get around a knee they'd effed up dancing at a wedding (not a rare story at all, believe it or not).
    Well all the usual hip issue signs were there... but none of the pain, Instead, their knee hurt so wrapped in a cuff... and their toes were going numb on the injury side.
    Hmm. Could look at this two different ways: 1) seek the signs the knee issue's accelerated whatever compensation's causing the original pelvic issue, and 2) the numbness is from the cuff causing tissue-to-tissue adhesion (my nerve work tqs had just begun, so wasn't confident enough to try it on clients yet. If this client appeared today, would've handled the problem slightly differently). Enough time to look at both simultaneously...
    When the pelvis twists... when laying down supine, the ASIS (anterior superior iliac spine) on one side will be low, and the other protruding higher from the table. This is caused by how the powerful thigh muscles attach to the pelvis: the adductor magnus, the huge inner thigh muscle used to guide the femur thus quad and glute forces correctly in aligned gait, originates on the ischium (that loop of bone on a Halloween cartoon pelvis) posterior to the coronal plane (cuts body into front and rear halves) and inserts on the femur anterior to it.
    So if you say, slip on a muddy puddle and have to forcefully contract this enormous muscle... it can not only yank pieces of the pelvis out on their very-mobile soft-tissue joints (the SI, or sacroiliac joints on either side of the posterior pelvis, and the pubic symphysis at the anterior pelvis where the two halves join each other)... but can also cause knots and tone increase which can pull these joints out slowly, over time. Client had both happen most likely and simply ignored them, letting pain compensation pass for solving the source of the problem -- which is how most men handle such an issue, esp in this client's generation. Trust me, it is a temporary band-aid... and we all know how good band-aids perform in the dirt...
    Asked them to remove the knee cuff, so I could inspect a very common cause of foot numbness, the common fibular nerve. Wouldn't be releasing the nerve this session, but could see if an adhered muscle were compressing it... and found the nerve was adhered to the long outer hamstring, called biceps femoris, the ham we all think about and what butchers called similar muscles on pigs. Asked about how long they were wearing the cuff.. and it coincided with the onset of the numbness.
    But gotta understand, with men of their era and their chosen sports esp... you cannot simply ask them to give up what they love doing, even if it's harming them wif full disclosure of risk. So rather than take off the cuff and let the pain of the knee injury keep them from running, even if for just a few weeks... they kept it on, so they could continue running their usual run, and have someone else deal with the numbness :p
    So wasn't hard to scold them :D You want not to feel the ground when you run, and trip into a ditch? Go ahead, keep running wif this tight-a$$ cuff (which wasn't adjustable). Or speed-walk rather than run cuff-free a few weeks to give your knee a break, after I stop these muscles sticking to each other. Hearing they didn't have to fully give up their jam, was a soft landing the probably would react more positively to than cold turkey (reminded them that was their choice, if they continued running wif this cuff. A concussion or broken wrist will defo make you cold turkey running for however long the doc says).
    Not surprisingly (cuff was on a couple of months, never in my sight but worn every morning for the run :rolleyes:), this was painful. Since I didn't use nerve release tqs, had to pull the nerve off the muscle by manually pulling other muscles off as best as could wif hands... then confirming full ROM by taking hip joint to full flexion, knee extended -- which they of course didn't appreciate. Solved much of their hypertonicity in the peroneal (outer) calf, as the common fibular got pulled free from being attached to the ham, whenever the hip was flexed and knee extended. But the numbness persisted.
    Okay -- asked if the numbness was more prevalent on top of foot or toe area. Said toes -- bam, know which area to work.
    Back then, just worked the muscles and fascia... but the issue was the tibial nerve, being compressed.
    So I used to just shear the large muscles of the calf, laying the client on the table prone... then applying forearm pressure headward and towards L-R centerline of the body (sagittal plane), right on the bulge of the calf we all know (gastrocnemius), which usually breaks any adhesion between sections of the tough rear compartment muscles, since the tibial nerve threads between and beneath them. Today, I'd target the route the nerve passes through, as that's much more surgically-precise and saves many HP of howling pain ;)
    The tibial nerve turns into the medial plantar nerve, which then splits into common branches that innervate the toes. When you feel numbness in them, them's the source, something along that path not in the right place / not acting normally.
    When their numbness subsided -- replaced wif a tenderness now, but full skin sensory resolution back -- they walked on it a few seconds, and kept walking slowly around, not making eye contact for a bit.
    That generation, tended to force anyone who wanted to forward a concept to them... to prove it, or it's the usual bullsh*t. Until that happened... I'll be polite, but you're not in my head until you do.
    That moment, was the first time in years they'd been coming to me... that the scolding I gave them, actually (and retroactively) had any teeth at all. Apparently I was just this guy getting lucky in a little run-down house in a run-down neighborhood, until that moment.
    I'll take it (y) Referred a lot more clients in the short time before he'd move away, and good ones I still have on the schedule (who have referred other great clients). Just starkly reminded me, in that moment... that the rigors I'd set myself to, getting into this gig... weren't for nothing. And all those morons in school who got into working bodies yet thought it was woo-woo theatre for an easy buck... this was as good a middle finger to those parasites as could be.
    Whatever you do, be into it, like be a f**ing geek about it. Less that, be a f***ing influencer talking sh*t, gets loads of money w/o any trust needed. But if you're in a vocation where people have to put their trust you, GTFOMF if you're not gonna be serious about it :cautious::coffee:
    #183 futurist, Apr 6, 2026
  4. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Tue 07 Apr 26:
    Clouds overhead look broken up, flotsam from something faraway causing their environs to stir. Supposed to drizzle a bit in both town and here by noon, and then persist the rest of the week :unsure:
    Nice morning otherwise, feels like a cosmic apology. Maybe I'm just projecting, as we just got dumped on a whole month ending last effing week. Or the heavens gave this respite to us, saying 'dry out, 'because more's coming'. Not as torrential as the Ides of March storm... at least 3d-out forecast says so... :cautious:
    The amt of f***ing mosquitos on the front of the car's frankly ridiculous, just as bad as in plantation days w\ hundreds of acres of standing water around 24/7. Didn't even look at my radiator grille, as know that's gotta be caked even worse w\ these little organic vampire drones. Good thing for 5G tho, is the Lamborghini windscreen rake does prevent these lighter vermin smearing their little corpses on the glass. Have switched to half-wiper-fluid in the reservoir, and doesn't seem like it affects durability of the ceramic layers on the roof... so can't be happier as that weird skipping and white-powdery smearing on tainted water, is finally gone, along w\ any bug slop. Durp, Fyooch :rolleyes:
    Have been shortening my driving commute since prices began skyrocketing on my staple 89-oct. Seems calmed a bit since things peaked about a week ago... now down to $4.99 for bathwater at Costco. If Costco sold 89 I'd be getting it there, as going to my usual place is significantly more effort and distance. But they don't and never will... so have to deal with substantially more for 89. But man, sure am glad am not needing to spend $30 every 4d, but typically triple that :whistle:
    Wanted to check out a movie called 'Good Luck, Have Fun, Don't Die' w\ Sam Rockwell since it went to streaming last month... but realised ScAmazon was the only place I could get it -- and they chg for rental, $20. GTFOMF w\ your $19.99-for-f***ing-rental. Let me know when it's $8 to rent, and I'll bite, m'kay? Jesus what a bunch of grifters at Blue Orifice (n)
    std wait for clients
    no stories today (n)
    #184 futurist, Apr 7, 2026
  5. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Thu 09 Apr 26:
    Rain's back -- sorry about not updating yesterday; had fires to put out (not literally).
    Loathe to coat my car in paint chips and non-mud-flapped knobbie-fling... got the day started. Water has an amazing hydraulic ability to pull aggregate from aging highway macadam, all it takes is a brodozer to run their lo-pro Mickey Thompsons on $1500@ chrome fecking wheels :rolleyes: over 3mm of water sitting in un-repaired low spots from 18-wheelers using the same highway as everyone else... and voila -- gritty sand in your brake calipers to pea gravel spider-cracking your windscreen.
    Luckily, am grateful none of that happened today :notworthy: Funny to see who hangs back w\ me behind slower traffic, the slice of society's getting bigger :p Sure, go ahead and do 30 over just so you're still late to work... but now you've reduced a whole day before you have to refuel your 24-mpg crossover, kiddos (and kiddos in adult bodies). But backing off the usual 2CL behind the car ahead, actually speeds up the right lane noticeably, as long as there aren't SoCA-raised transplants or 4-foot-6 octogenarians driving 10 below the SL in any visible moisture, at the front of the conga line. Young people are petty and stressed, and that's what works on road to maintain some semblance of calm, at least here -- appeal to the kids' guilt and insecurity, by remaining calm whilst they're flailing, coming off a toke into paranoia :rolleyes:
    TGT still doesn't have its shelves restocked... so the problem's worse than expected. There are pallets w\ things like bottled water and paper towels in certain front-half spots in the store... which next to no one's partaken; same amt as when they reopened. Was told those pallets are there to encourage buying things at discount, most likely due to being partially inundated... but more practically, to hide something underneath them. Didn't ask but going to assume that thing, is utilities damage, perhaps an electrical outlet in the floor (which are supposed to be weatherproof w\ watertight gasketed caps... but who checks things on the floor (which no doubt has been run over by any number of floor-sweep-machine operators) this fastidiously? Almost no one these days, even those normally on the ball...
    Wondering what's taking so long for restock, even taking into account the pilferage by other stores I'd mentioned on O'ahu being a factor. Even if they didn't rcv full shipments, they'd still get an order of pilfered pallets of stuff delivered... which hasn't happened as nearly all of the products I'd been following aren't restocked (probabliity of all items I personally check on being out, is too low for pilferage -- even slimy shens have diminishing returns). Only asked after worker bees on the floor rather than people who poke their heads out sometimes but work full-time in the warehouse section... so until getting a take from one of them... going to assume will be another week before those missing things gets restocked. Didn't know so many people liked lentil soup, geez :confused:
    So more-tangent bodywork tale here, as the issue yesterday was a subtler one...
    I only take cash, and that's for very good reasons. If you don't like getting cash out, see someone else for your bodywork. My rate, plus all pertinent need-to-knows are mentioned in text to every new client, so there's a record. So when you show up, you're ready. Worked fine the whole gig and don't plan to change it.
    But a few people want to be slick -- and feign the need to be worked, when they know they don't have cash. Give them one freebie... but next time they're in, have a note about them in the schedule, to have them pay in advance. And if it happens again, they're off the client list. Simple and straightforward -- I'm not a charity, you pay me what I'm worth, or go home unprocessed (and have two layers of defense for those wanting to resort to meatsac methods to get their way) :rolleyes:
    A regular client for a few years (about 10y ago) had been coming in, and begging for a few mins past the usual hour to 'get the last bit of kink' out of a shoulder. Which was fine, up to about 15 mins past the hour, where my policy is to ask for the full half-hour-extra amt. Fair enough -- you ask for free time up to 15 mins, past that, I ask for 30 mins. Worked then and still policy now.
    But when someone knows I dislike leaving someone halfway processed and try to get the work done in this 'buffer' 15 mins and end up going over, I don't normally ask for the extra since it was my call. But when I can sense the client weaponising this to their repeated advantage... it's time to set some boundaries.
    Not surprisingly, this client was in for the same problem, every session. Same issues, but seemed to stretch longer and longer each time. Realising this, asked for the extra time, and said we can't keep going, unless you pay in advance for 2 hrs (which is what used to take 1 hr).
    Client blanched... which rather pissed me off a bit, since there's no way anyone w\ any respect for my intelligence would feign disbelief. But there are those who prey on decency, thinking it's my fault they're losing money, I'm just doing what anyone would do. Nope, just you and your grifter upbringing, buddy...
    So they stomped off in the usual petulant theatre, claiming they're no longer going to refer me clients. Oh, so you won't mind me letting the clients you did refer, to know what just happened, from my POV then. No answer, and slammed the f***ing door on the way out. Don't let it break your tailbone, slick :rolleyes:
    The fact my biz has suffered relatively few of these mincing parasites in 15+ yrs, speaks volumes for my approach to the work and client compensation. But every once, there they are -- and in these trying times on Maui, pain and exhaustion and fear makes people even less likely to default to decency -- 'too much work', 'not this again', 'wife wants a boat'. Boundaries in yesterday's session had been drawn as well -- I don't care who you are, you can be Oprah -- I'll demand proper compensation for my work, if you wear out your welcome. If you're a decent person, paying what I'm worth won't be a problem. But if you're not, I'll need to draw enforced boundaries around you, like a toddler :cautious::coffee:
    #185 futurist, Apr 9, 2026
  6. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Fri 10 Apr 26:
    Orion made it back in one piece, thank the stars -- which to those who've never known a world w/o 300Mbps+ internet... space is still hard; don't bet on practical Mars flights being even your grandchildren's jam...
    Mentioned the morning breakfast commute in another post... so won't rehash it here. But man, work is light today. Two and done -- must be tax time :unsure:
    Neither were that interesting -- one a regular and less than an hour to fix (foot / ankle problems from waiting tables, which is a beaten horse here) and a shoulder issue from too much pickle ball (and a refusal of the client to take advice to dial back activity until ligament involved shrinks down enough to keep it going out again... so will take their money as often as want :rolleyes: ). One and done doesn't make for good FyoochTV :p
    Was really weird about the issue mentioned in the Coincidences thread, tho; genuinely stopped me in my tracks. Live virtually silent at home, don't mutter to myself (yet :LOL: ). So how the hell YT knew to suggest a video pointing me to a lost key to LD (lucid dreaming), I'd been seeking since 2007 (tbf, had gone off LD since failing to get more than one true dive in a year of trying, tho still sometimes follow the MILD steps to see what dreams it brings to the surface) -- and that I'd talked about LD here mere hours before... was freaky. Thing is, we won't get anything w\ mugwort in it as foodstuff until Fall probably, so will have to get it online. But am curious how much of an effect it'll actually have.
    Strong cheeses like blues are colloquially know to increase dream intensity, but not necessarily promoting LD. Have months of testing using Stilton, and can confirm you will shoot up in the middle of the night drenched in sweat from what you saw / exp'd... but no improvement staying in the dream state. But heard exactly zero (0) abt mugwort's use in it -- how that happened, in a year of trying (and being defo online looking for ways to get me there)... seems a divine intervention of some kind :cautious: Apparently been known in Europe & East Asia for centuries :oops:
  7. ETC(SS)
    7,548
    Space is also EXPENSIVE.
    Almost as much as child care in the upper Midwest.......
    Or High Speed Rail out west.......
  8. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Sat 11 Apr 26:
    Standard commute today -- beads of water on the 5G, so rained last night. Mercifully were early enough the concerning road moisture'd mostly evap'd off. Found the 5G still a bit long to warm and a bit cranky about drinking fuel until more than a mile away from home (in past two yrs has gotten to temp -- meaning getting max efficiency from the ICE -- about twice as fast / half the distance). So can't use Power very often in that mile -- which has gone on long enough to become ingrained. Tbh, will only help in the long run and most ICE-onlys out there are slowing down noticeably anyway -- $5.80+ for bathwater's high even for here.
    Did notice something forgotten, trying to swim to breakfast the past month: how the 5G handles gearing based on throttle position.
    When it rains (and this is true for any air-breathing-engine'd vehicle), your air filter will collect water vapour w/ increased humidity to 100%. May not be apparent to someone 5' 9"... but the average passenger car's ICE air filter is about thigh-level or lower, including the intake which may be a bit lower to get cold air (makes sense). This all goes out the window, when it rains (which is why OEMs don't endorse cold-air-intakes -- they don't want to replace engines w\ bent connecting rods because you wanted +2.1bhp in the dry, but say 'f*** it, I'm driving thru this flood puddle, gotta get another $100 carton of cigarettes'. The 5G's is up by the hood latch above the radiator core.
    Depending on how much organic particulate is already collected in the filter (which here is immediately)... this water + organic soil, will grow things. Mostly mycelial life, which will infiltrate the matrix of the filter media... and not go away once enough air's pulled thru to dry the water out. Thus you now have a more restrictive media -- for example, take a dry kitchen roll square off the roll -- can easily hold to mouth and feel breath blown thru it. But wet the square, then dry it... and try the same thing. Still can, but not like before.
    Given I had to drive the 5G thru a month of this slop... probably time to replace the filter again. But may wait until clearer weather's more likely before spending the non-trivial dosh ($36 per, w\ no real substitute in the aftermarket). Want to use Toyota filters in the warranty period anyway.
    That tendency to hold back ICE output aside... did notice something that may or may not be related to this air filter condition, as the PCU will decide how fast to spin MG2 in order produce the correct amt of gearing to satisfy your commands (right foot)... and like alternator output on an Only (ICE-only vehicle)... how much depends on what's produced at the crank.
    I'd written in articles on forums before (another lifetime ago) about the effect of putting non-OEM regulator-rectifiers on motorcycle engines, such as used on my own commuter '00 Suzuki SV650 w\ a '04 Kawasaki ZX-10R MOSFET R/R). Had tried a few combos w\ Ebay-sourced R/Rs (such as GSX-R600, -750, and -1000) and arrived at the Kawi one as the best compromise that still boosted performance -- because the stator and rotor in a motorcycle battery charge maintenance system, is only as efficient and powerful, as the ICE spinning the crank -- it's just how much parasitic drag (magnets in rotor against mag fields in 3-phase-wound stator) you want to sacrifice. Meaning less drag on the crank and more power to the ground, for less charge being rectified and sent to the battery. Obvi want one that treads the limits on ICE power consumption, w/o letting your battery go flat and stranding you.
    Similarly... a 5G needs its ICE to work at near-100% of its rated efficiency (best ICEs only get to about 40% volumetric, and few are rated to be flexible enough for passenger vehicle duty) in order to produce the best mpg. The less time your foot is on the accelerator pedal to get you to speed, the more fuel you'll save, all else being the same. A weaker one will waste more fuel and force longer time ON.
    So my (re)discovery was... how much acceleration you still get ICE-ON, whilst pulling out throttle angle. If you get into Power mode taking off from a stop... about 40 - 45 mph can pull out a lot of angle, and still keep accelerating. Remember, what fuel you're using, depends on throttle angle in basic terms. What the 5G PCU does, is decrease mechanical advantage / make gearing numerically lower, if you take angle out.
    If you want to accelerate briskly in a 5G (and all Priuses, if they use the same eCVT drivetrain, which essentially's true)... you'll increase gearing / make transmission gearing numerically higher. If you persist in using a driving style that holds throttle at a fixed point, despite staying at higher numerical gearing (more revs per distance), the PCU will also hold that ratio for you indefinitely, until another condition forces a change. But if you ease out of angle past ~40 - 45, the PCU will drop gearing to a lower numerical, so the same revs will take you further down the road, still increasing speed. This effect will change, depending on what parameters (not sure exactly what they're programmed to be) are affected by a weaker Atkinson-cycle ICE (already 20 - 25% less output than an Otto-cycle of the same displacement). In this case, the PCU might keep lower gearing (higher numerical) for longer... which will be reflected in dropping avg mpg on the dash.
    So drove quite a bit differently today, remembering this about Priuses. And got a 12.1-mi avg, of 92.3 mpg. So the factors mentioned in the 20K Svc Exp thread, don't necessarily apply mpg-wise, but need to change my driving style, as last yr could get 80 - 90 mpg on that same stretch, w/o much care about pulling angle out of the pedal on accel. Luckily, that won't be too hard w/ midgrade fuel at $6.09 per.
    more after today's clients
    Pretty good day, if sessions were a bit long...
    First was 3 hrs, then second 2 -- two is about the limit for a normal session, as at depths worked the body can begin to interpret my hands as being invasive, and reject changes made. However neither client showed any signs of reaching pain or exhaustion limits -- which isn't unheard of in this gig. What is rare, is two of them in a row...
    Last client which regularly took 3 hr sessions, was an arborist way back in apprenticeship. Grips trees with knees, can't drop to the ground on a whim for hydration, and carries chainsaws at arm's length most of the day, in searing full tropical days, 8 - 9 hrs. Was wracked w\ giant TrPs in lower body, which took a minimum 3 hrs, sometimes twice a week for months (really taught the value of using less dictating and more listening and negotiating w\ hand tqs on client tissues). Both strengthened and very nearly injured hands, to force finding the alternative creating my first breakthrough.
    Today was very nearly the same... except 10y later know how to talk to a stranger's tissues w/o the people riding in the body, to reject the speed and depth of the work... but also how not to use force w\ my hands to get the job done. Was pleased at how little my hands seemed to protest, despite having worked them non-stop for the whole 3 hrs. Nice little update litmus test (y)
    What was becoming apparent tho... is the same exertion at bodywork rate of calories-spent, was at 3 hrs juuust beginning to do the same thing as 15 mins of walking / running: making it hard to stand, and needing sat down a min.
    But despite feeling the onset, wasn't actually tired enough to wave off the second 2 hr client... and after that one, still not enough to stop if a third appeared. So my PCP's theory that the med weakening my liver wasn't as likely as (suspected) HMPV symptoms persisting to stop working out, didn't hold water: if I was still being compromised by the virus, those two sessions would've faceplanted me, as a viral infection invades and inhibits function of multiple sources of healthy metabolism, like liver, heart, brain, lungs, gut, and general inflammation from tissue damage. Had I all those things, wouldn't selectively permit 5 hrs of near-constant bodywork, but reject and make impossible 5 laps of a mall level. I think the liver stress is limiting vigorous exercise, but not bodywork. Which is frustrating as workouts make bodywork feel easier (and stop me ballooning out like an Orion main chute :sick: ).
    But good day today -- generous tipping, and a new add'n by a gold star client (gold stars are defo sources of other gold stars on the table historically) + older gold. Can't ask for much more than that (y)
    #188 futurist, Apr 11, 2026
  9. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Sun No Wash Day, 12 Apr 26:
    Clouds sitting literally 75 ft off the ground over the isthmus -- yeah had bucket w/ warsh supplies ready to give benefit of doubt... but rejected (n)
    Had to run an errand in town besides get breks... and by the time were on-road back south, sun were breaking through in places. No thanks -- forecast says by 2pm will be dumping. May as well wait for a proper weekend -- the flakiness of the weather's rather hard to break thru stubborn adherence to decades of predictable weather. Better than 100-mph winds causing total destruction of multiple state heritage sites and my hometown... but f*** this Seattle-arity's a drag for someone who doesn't have a garage but likes to keep their vehicle non-ratchet :cautious:
    That errand: hoo boy was a chore trying to keep calm during that. Read on...
    So, get an unprompted call by my usual clinic, as a reminder for an appt last week. 'By the way...' were words that tensed the ring a bit, coming from these normally terse people...
    Have to take a test every year, over 50. Those in the know, you know what this test is, get it in the mail. Hate taking it, but better than the alternative (also, IYKYK)...
    Anyhow... the clinic droid were selling me on a new, more accurate version this test, that only need be done every 3y. Great I said, how much does it cost me? Covered by your insurance, they said. Okay send it. Wait 3d, get it yesterday plopped on my step (glad it wasn't raining yesterday, Jesus :cautious:)...
    So, as Clinic Droid intimated... it is a rather more involved test, but could see why it was more accurate :sick: Well Christ, let's get this over with and get it on its way...
    In the manual, says to drop off at any UPS store. Looked at the hours for the one nearest my breakfast commute, ah no problem. Plus if any issue w\ that store, have a CVS next door as an alternate -- and they tend to be much more lenient with hours, rules, etc.
    Just wanted this kit off my hands. Asked at the UPS store, which had to wait a half-hour to open (added ceramic to front and back caps just to kill time). Nope can't take it. What a f***ing surprise. So walk next door to the CVS...
    Pharmacy isn't open. Clearly says time I'm there, should be open. Ask after a floor worker, when's the pharmacy open. Oh, half hour from now...
    FFS :cautious: So sit in the car to wait, watch an EP of the old Cosmos series w\ Carl Sagan, which always calms me when things advertised aren't what a business does, and are too lazy or cheap to update the f***ing signage so am here w\ **** and this blasted kit in my hands.
    Walk in at the claimed time... and greet the pharmacist. Go to ask the same question I'd done the worker, and got cut off. Boy, that cheers me right up :cautious:
    'Nope, can't take that. Today's Sunday, come back Monday, that's when we can take it.'
    So my read of this f***ery, is the company making claims for how easy this test is to ship off, didn't take into account those said agencies responsible for handling these kits on the way to their labs, can just say nope, we're not doing that.
    Luckily, the manual for this test, says the sample remains viable 48hrs before 2-day shipping. Better be, because nothing was mentioned about inability for UPS / CVS to receive these things on a Sunday (wasn't a problem with the old test, since you just dropped it into the mailbox at the post office). So had to f*** around an hour, which could've been spend sitting at home reading my book (Pain Free, by Pete Egoscue). Half-arsed gatekeeping douchery :mad:
    Doesn't help the simple exertion of walking all over the creation chasing someone who'll take this f***ing kit off me, tires your scribe a lot faster than off this med (feel genuinely like I'd imagine I'd be like 20y from now... which is depressing :sick:). But FFS, if you claim something, makes sure the customer actually exps something close to it. 'Nah too hard, let 'em figure it out, we got kits to sell', says the mfr :rolleyes:
    Oh -- also did 5h in a row of bodywork yesterday -- which as mentioned earlier, tires the prac in a way just the physical exertion doesn't explain.
    Mentor, in the early-early days... said I needed to watch out for 'emissions' from the clients I work... which were met by a 'Wth is this old man talking about?', as had to get my cert in massage therapy before even coming to them for apprenticeship -- worked 750+ people in school to be minted, and didn't have any ill effects then? So was a bit skep for what was to come...
    In this modality... you work soft tissue all the way to bone. And like a steak or chicken breast, when it's marinated in toxic metabolites and salt and excess sugar, causing inflammation and its own poisons like cytokines and p factor... the flesh can cling to it. Proper and deep work in such tissues, can 'knock free' a lot of these deposits, temporarily held due to insufficient exercise, dehydration, and adhesions. So the protocol for us, Mentor punctuated with an index finger... is to tell them to
    • drink plenty of water,
    • avoid exertion and heavy muscle loading for 48h (walking and doing household chores is okay, as long as doesn't make you sweat)
    Next... if you encounter these conditions working a client, take measures:
    • a foul but unfamiliar odour suddenly, esp after releasing a resistant knot
    • sudden light-headedness after sensing such an odour
    • tingling or weakness in hands / arms, w\ no common cause
    • sudden non-responsiveness in client (catatonia)
    All of this was a bit much to take for me, having just leaned into this gig for the first time. What the hell was I getting into...?
    Mind, I'd already exp'd the dojo long before this apprenticeship, so knew weird, non-empirically-acknowledged things like paranormal events, clairvoyance, communication via telepathy :confused: and other freaky shite weren't something I could just dismiss as nonsense, since had direct exp with all of them. So a door of non-prejudice were always open when it came to things pioneered at the dojo (which this modality was, and is still taught there).
    Session after session, even into being able to take my own clients alongside Mentor's, yielded no real exercise in using these mantras... until probably 3rd year of a'ship...
    Had a client referred to me by Mentor, and uncharacteristically they stayed alongside, apparently very familiar w\ them. Not sure if the cling was due to seeing how I applied the mantras, or just to reassure their regular I weren't going to eff them up... but they said nothing as I began to work their issue: a tight neck and shoulders.
    Turns out client was a recovering addict (as mentioned by Mentor) as I worked their upper traps... but hadn't mentioned on what. Told the client where I were going and what I were doing, as instructed. Got to large knot in the upper trap -- not at all unique, were taught -- but this one was different from the dozens I'd worked to that point...
    Most TrP knots (which this was, but didn't yet possess the tools to work as one) are resistant to work -- in the early days of a'ship, protocol was to compress the tissue of the knot, until it yielded -- client's nervous system will react to the pain and release any tone the nerves control. Which was easy for Mentor, as their hands were powerful from a tough upbringing doing heavy manual labour in the '50s & '60s. But my upbringing weathered no such gauntlet, so hands struggled to follow their lead. 'Well just going to have to figure out your own way, then' was their pat reply when I couldn't accomplish in 10 mins, what they could in seconds.
    I'd be 3y easy away from being able to even approach knot release using this method... so took a smol break and massaged fingers (pull and twist gently but firmly several times, anytime they ache-- still a method I use today to prevent osteo from all the squeezing)... then returned to the client...
    Something was... off about this client's traps, tho. Felt... weird. Hard to describe succinctly... like, their flesh were somehow cooked, but still alive, obvi. A strange yielding that gave me chills down the spine. Asked Mentor about it offhand... and the client perked up, as if knowing what they were going to say...
    '____ here, they're a recovering addict, as I said before. Heroin.' Which braced me a bit, as if something in my head knew why that connected to what was in my hands.
    'We were taught at the dojo... whenever someone becomes addicted to hard drugs like coke and heroin and meth... it causes radical changes in brain chemistry'. Which today makes perfect sense, given what I know about the subject now. But back then, seemed a dark new world. 'Heroin esp, causes the tissues to feel spongy.' Which were exactly what I were feeling, but couldn't find the words. 'Applies even if the addict's been clean for years -- their tissues are reacting to chemical changes in the brain, the hard drugs rewire permanently'.
    Looking down at the client, they began to chime in: '<Mentor>'s been working me years, bud... and their's is the only massage that actually does anything about this knotting in my shoulders.' Obvi not your garden-variety heroin addict, they were 20y in recovery at the time. Having smelled the stench coming off cocaine and meth users in business blazers working for AMEX in the '90s, knew addicts weren't just junkies in rags screaming obscenities & throwing used syringes at passers-by... nor all Patrick Batemans fully-grifter-functional, wiping their noses a bit too often. Lots actually want to get clean, but their brains in recovery exist to react to temptation 10000x more strongly than we do after a McD french fry. Mentor waved their hand and got me back on task. 'See what you can do about this knot'...
    I'd tried stroking bloodflow thru it (which is how triggerpoint therapy does it, I'd find out years later)... and felt something like a tiny med capsule deep in the golf-ball-sized knot. Squeeeeeze, rest hands, squeeeze...
    And then, the stench...
    It wasn't the burnt-plastic-&-roasted-flesh from coke addicts in Phoenix, nor the weird electric-discharge-in-BO-&-halitosis from meth junkies. But a crackling, acrid, thick artificial odour that immediately filled my sinuses (must've been on an inhale) and burned slightly, causing a gag. Mentor were already at my side, lifting me up by the upper arm to the restroom whilst I gagged and raggedly struggled for an inhale. 'Hey, wash your face w\ soap, that was a bad one'...
    'What the f*** have I gotten into?' asked myself in gasps, as Dial burned my eyes but seemed to deter the creeping, soaking feeling of whatever hit me, into the skin of my face and hands. Drying out, Mentor waved me over... 'you still have a client to process, hurry up'.
    Apologized to Client, but they just grinned and shook their head 'np'. Back into the trap knot... and it was gone. Probed around a bit more, but hard to misplace a golf-ball-sized TrP...
    'It's gone', I perked up to Mentor, expecting something like praise. But they just reminded me of the rest of the work, which I'd not completed yet. Half an hour later as Client were paying me and I'd begun prep for the next client, Mentor introduced me.
    They spoke first: '<Mentor>'s been taking that knot out since 2004. Been following their diet advice but always comes back. They take it out a lot faster tho'. Which were intended as a gentle rib, which I was game for. After all, did just remove my first 'spraying' knot.
    'When that happens again,' Mentor mumbled, as Client disappeared behind the locked front door, 'just go wash your face and hands real good. Won't hurt you unless you don't get it off immediately. And don't. take. it. to. bed. with. you', they punctuated with their usual rigour on point.
    Still do this, when the odd client w\ stubborn TrPs comes to me. TrPs aren't usually unreasonable, unless you've not addressed the reasons it has to be unreasonable. When they exhibit this trait, several ways to get the knot to release, w\ long strokes of heavy pressure at the bottom of the list. But when they don't respond, that one always gets out any stench dammed up behind it.
    Stories about the rest of the mantras, another time, another novel :coffee:
    #189 futurist, Apr 12, 2026
  10. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Mon 13 Apr 26:
    Whew -- almost Tax Day, meaning almost time for clients to come back w\ their returns (if any) :unsure: At least this idiotic tariff grift is a thing of the past (unless you're owed recompense for that illegal taxation)... this persistent Seattle-arity + people using their returns for Vegas :rolleyes: really dent the revenue stream... but am happy it wasn't worse (which given how many people got flooded out wholesale or even just a carpet being soaked... defo something to be grateful for. But gratitude's a poor sub at the grocery store :()
    Welp, got to OOPS on time this AM, leisurely salad in the car, in the door. 'Don't place your package on that pile of boxes' was the first thing said to me. Was reaching into a paper bag to fish my box out, and hadn't set it anywhere.
    Oh... so, you mean the one left in the middle of the lobby floor, asking for customers to lean on, place totes on, and kids to climb on? If you're that concerned, move the f***ing boxes out of the lobby area, you yourselves cordoned off for customers to form the line. Wth is it doing there anyway, wasn't there yesterday? You're UPS -- isn't this your thing, moving and stacking packages all day? Check yourself, FFS :cautious:
    Took the box off my hands, got receipt. Handle that biohazard box w\ care, Brown -- all yours now, see you again in 3y :rolleyes:
    Am a bit concerned about the weight gain off caffeine (read, whilst on this style-cramping but admittedly-super-effective med)... but frustrated its liver effects keep me from doing much more than walk around a bit -- so that's what's g otta be done, walking until feeling light-headed and have to sit a min... then get up and walk again, rinse repeat until feel chest symptoms, either shortness of breath, or tightness -- which means the glycogen the liver usually stores for exertion, is finally exhausted from both muscle and liver tissue (including from heart tissue, which never has to happen unless the liver's fully spent, or unable to do the metabolic work to store it) :eek:
    Sounds scarier than it is... but having idiopathic VVS before (vasovagal syncope, a tendency to suddenly lose blood pressure to the brain and fall), am very familiar with the point in the river to get out, before going over the waterfall...
    Will probably all go away after getting off the med... but cor, gaining 6 - 7 lbs since end of Feb's alarming -- haven't gained that much, that fast, in the previous 10y o_O
    Recent client txt'd me yesterday, saying how much the work changed their running. Vast majority cease contact until they're hurting, but those on my gold star short list usually update me post-session -- which is a highly-valuable source of feedback to refine the work. Not surprisingly, Client is a GSC (gold star client), referred by a GSC, whom also were referred by a GSC (y)
  11. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Tue 14 Apr 26:
    Had to run an early (0600) errand this morning, one done roughly every anniversary. Bit of touch-and-go this time... but came out relieved and grateful :notworthy: But nice to go get a (very) late breakfast, worked up w\ a helluvan appetite...
    Watched Andy Weir interviewed on NdGT's 'StarTalk'... and was proud another geek around my age got into writing science fiction (and producing movies / TV sci-fi from the books -- the others being William Gibson, Neal Stephenson and partnership nom de plume James S.A. Corey (Daniel Abraham and Ty Franck). In that respective order, sci-fi becomes less floridly inventive w\ plot and more letting 'hard' details and attn to it, create the bones of the story... which I both love, and can compartmentalise (still love Star Trek, still one of the most flagrant deus-ex-machinising IPs out there). Project Hail Mary looks like a winner, tho... so much science to geek out on.
    Can't wait for PHM to make it onto streaming platforms, tho -- audiences since ~2010 are such reliable arseblossoms about checking themselves in the cinema here... iow, shutting the f*** up. Shant pay nearly a Jackson to sit with douchery a seat away...
    Just got a neat little dealy in the mail -- a Chik-Fil-A set of coupons for several sandwiches. Gave them to my mom, who does like a good chicken sandwich -- indulging will break the 'once-a-month' rule I've hard-set for myself. Went to an appreciative recipient tho...
    Had a client back in apprenticing days, who gave me an exp I don't think will be matched anytime soon. Now, you may be thinking 'that's any number of your clients'. Trust me when I say, this client was in a class of their own, even amongst the short list...
    One of the hardest skills to learn in this gig (and cannot be rushed)... is the ability to accomplish your goals of changing tissue, without causing undue discomfort or trauma to the client. 'Trauma,' you may recoil, 'that sounds a bit offside, dunnit?' Well, there are two kinds, and two levels of difficulty in avoiding your client leaving worse off than they arrived.
    The easy part, is of course avoiding the physical trauma. If a massage prac / bodyworker 1) leaves bruises all over, w\ no history of pathology making the client susceptible, or 2) ever breaks the skin, you need to re-evaluate your decision to stay with them.
    In my case of course, was simple inexperience -- just because you were top of class in massage therapy school in A/B/C/Z modalities, doesn't automatically mint you for this one -- very, very much deeper (goes all the way to the surface of bone) and needs far more intimate exp with the whole anatomy of an area, not just skin and muscle. Whilst was a steep ramp to get competent, did eventually develop the map and 'road feel' of how not to injure the client by heart, and how far one can take the tissue whilst helping and not hurting.
    The difficult part, is where the marquee'd client comes in...
    Just like soft skills in people mgmt any middle mgr will need to arm themselves w\ for a banal job steering mobile phone kiosks for example... being able to quickly sense and calmly react to threats to the session's balance and progress in the client, cannot be overstated. People are people... and people have shades and layers, shades and layers :p
    The broad, 10km plan-view of this, is obvious stuff drilled in massage school -- service authority figure vs. customer, and male / female. These are dynamics hard-wired into any healthy (or unhealthy) person seeking relief w\ a service provider, in the environments common to our work. Such environments in places w\ no intent or respect for the good of diligent work, will leverage them to seedy and lascivious ends... which taint those struggling for respect in this industry (whilst rich ne'er-do-goods w\ parents buying their medical credentials hurt patients and clients routinely, in incompetence and low-effort grift). So the buyer should beware coming to a stranger's office alone 1-on-1, w/ skin contact unavoidable. The job (and yoke) of We The Legitimate Bodyworkers, is to proactively prevent misunderstandings, educate the client w/o proselytising, gaslighting, or condescension. Because there are teeming countless charlatans in our midst who'll do exactly that, to shortsighted, selfish, insecure bridge-torching goals.
    So knowing and supporting all of that since graduating massage school (luckily had a quite-high-quality education at this outfit, tho unfortunately connected to a mothership that went under and took this team with it to the bottom)... here's this client on my table.
    Older middle-age, obese, visibly agitated -- client of Mentor's they're giving to me. Mentor had a poorly-masked habit of cherry-picking and giving me the hard cases -- which being ex-mil can defo see the wisdom in doing. But believe in this case, was just 'I'm tired of dealing, pls take over'. Which doesn't instill confidence in the client when you want to jettison them for greener pastures... but in this case (which meeting them didn't realise yet)... understandable :cautious:
    Client was garrulous and cheerful laying on my table... but soon that rather brusquely-forced platter dissolved under some introductory caveats of being worked: 1) you will never work my neck, 2) avoid my sides, as I'm deathly ticklish, and 3) my pain tolerance is low, so take it easy on me. Oookay... so sanitised hands and began the work.
    Became pretty obvious within ~ a min, that this was going to be a long session...
    Most clients, given the amt of pressure required to get say, a TrP in the trap to release, need abt a 5 - 6 / 10 pain scale (individual and subjective to each client) to get the release response. Wise pracs going past that to do same, will apply it in short bursts, so as not to be read as trauma by the brain and spinal cord.
    Client had massive TrPs in the upper traps. Also exhibited mild signs of hyperthyroidism: thinning hair, bags under bulging eyes, constant fidgeting and low PT. Had to review the symptoms later, as obesity wasn't on that list... but just kept it in mind, as tried to avoid the neck whilst still working trapezius...
    So found the middle TrP on the R side, felt for its core (where the actual malfing tissue is), and began to apply the usual 5 - 6 / 10 for most people.
    They screamed at the top of their lungs -- which no doubt startled the hell out of me. 'You're killing me', they mumbled, as I looked down to apologise... but saw their eyes were filling w\ tears, corners of mouth making the shape of one we all recognise when a child is about to bawl in your arms. O...kay :confused:
    Their complaint was upper back and shoulder pain. These TrPs were defo the reason. But realised at this moment... ah, this is the spectrum of client personalities and mental pathologies, I'm expected to handle w\ skill in this gig. Also knowing Mentor's personality, this type of thing was defo cramping their Vietnam-honed expectations. Welp tee up, kid -- you're in the hot seat.
    Every prac has a duty to conform the session to the expectations of the client, whilst using your tools to accomplish relief for them... up to a hard point, where progress is impossible due to client's demands (exp level and talent will vary where this hard point is). At this time the professional thing to do, is to refuse service, and wish the client all the best in finding a prac willing to satisfy these demands. Nothing unpro about it, no prac's a miracle worker, and no prac's a mind reader. But wasn't there yet w\ this one...
    Tried to introduce breathing techniques, which broadly work across many demographics on the table. Nothing, or just didn't try, just complained about the pain. By this point, the thought had creeped in, this client isn't willing to do their part in their own release of this issue... which always leads to more pain and less progress. Even at this early stage in apprenticeship, that much was apparent (I mean, you learn a lot, watching how things are done in the military -- and if there's one thing I've learned about making good on the shite sandwiches fed you, is your part in its success anyway -- which the military will demand, and immediately punish for not doing).
    Well how about some rest. Nope -- only had an hour, not much time to constantly kowtow to 3% of the work by resting 5 mins. And that's just one TrP :rolleyes:
    So, reached the hard point :p Offered the client a choice: persist and try a bit more to learn how to breathe and accept the work, or try to find someone else offering what we do, for the price we do. Wasn't trying to be an arse, just the facts. It were 40 mins into the session, and I were still on the same TrP. Educated the client on teamwork needed by prac and client, to gain them the relief they craved -- cannot just expect us to do all the work. Which of course tightened their face a bit. Hard to hear the truth, I imagine, But also imagine, we weren't the first pracs to deal them this gauntlet.
    A bit more noodling around, and the hour was over. Got up and said they'd be back, maybe not feeling well enough to help today; had this months now. Okay np -- when you're ready, give us a call so we can schedule another session. Smiles -- at least outwardly -- as they headed out the door to their car.
    As the door shut, Mentor turned to me and said 'not to bad, kiddo. That one's been a pain to work on since February (was December). Impressed how you handled that'. Replied, that's the standard taught in massage school back in WA. Can't do anything, without the client's effort matching yours. Nodded and began to prep for the next client, already knocking on the door. I'd see this client several more times, always the same result... then fell off at least my map...
    Much later (abt 3y later)... Mentor's ready to mint me, off to be an independent prac. As we talked over sushi... mentioned that obese client from years ago. They'd stopped scheduling, figured they'd found a massage prac or something that just rubbed on them. No, Mentor said thru a belly laugh... they'd basically burned bridges all over the island w\ massage pracs, osteopaths, and other bodyworkers, with this top-of-lungs pony show -- some elders to Mentor had mentioned they'd shown them the door after offering the same ultimatum. No one who feels they're entitled to screaming bloody murder in a session as routine, is going to find many pracs willing to work them... lay the fact they're unwilling to help in any capacity, over that... and the only recourse, is out the door to another prac. Which obvi has diminishing returns on an island :p
    Never saw that client, probably left Maui for some other pool of unwitting pracs. Their risk in a darker sense, is that it all may've been an act to sense where the weak points of a prac's practice are... and exploit them legally later (tho tbh didn't think was case this time -- my intuition biased them actually being that sensitive to pain, perhaps by some early trauma). The canny elder members of the comm'y probably begged off for that reason; much more common today than 20y ago, probably. Because in 15+ yrs at this gig, no one else's acted like that -- exactly one, in thousands of clients.
    Sure, there've been unique clients -- one with liver cancer felt and intuitively warned about, by suggesting they get a scan to make sure. One who couldn't walk but for one TrP -- and was able to golf again after it were resolved. The client whose belly pain for 30+ yrs, was a simple mis-twist of the small intestine, called a huli-stomach by Locals, resolved within mins of getting it sorted.
    Unique, sure. But only one who despite being in competent hands, would literally not allow someone else to do the work needed, face the pain needed, to free them from it. And those will always be shown the door -- because even otherwise nice people can be on the short list out; only ask you do your part in your recovery like I trained to -- nothing more, nothing less :coffee:
    #191 futurist, Apr 14, 2026
  12. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Wed 15 Apr 26:
    Tax Day. Taxes are long-over for me this year... pays to do them early before the stampede of desperates... and not stating such w/o some modicum of dumbarse-punishing exp :p
    Enough about that... dare I say the weather here's finally beginning to stabilise, if the island as a whole certainly isn't giving the same signs. Have a 'normal' morning commute, no wet patches, no drizzle, no sprays of grit, the whole shebang... which feels oddly nostalgic. Funny how little time has to go by w/o a stim, to get you to wax-nos about it :oops:
    Weird phenom over the past week, has been the torrents dumped on us over a month ending only yesterday... probably saturated ground aquifers and all other paths of rain to the sea (if such exist in the isthmus 'bedrock') all the way up to the surface... and that moisture has done two things out of bounds: 1) produced natural breeding grounds for billions of mosquitos and gnats, and 2) made eerie super-low-hanging fog, much like after heavy rains in Dark Days around Puget Sound. As before, some layers were below 30m off the ground whilst others hovered only a thousand feet above it -- which was surreal to witness on the commute, like being inside a NF sci-fi / horror doc. Were figuratively looking around for the kaiju to stamp a foot thru it :eek::D
    Of course, that kind of cloud formation here, means the already high-humidity of 80 - 100%, stays pegged at 100%, for weeks... and combined w\ the storm system's constant wind direction either WNW- or NW-erly (brings moisture-laden air from equatorial latitudes -- our feared 'Kona' winds)... means horrid, door-jamb-swelling slop in the air. Much like how 45F-Thanksgiving-Seattle is, just 30F warmer :confused: Have been running A/C almost all day, just to keep the swelling from creating an actual light-passing gap in the front door seal :sick: Much more uncomfy to sleep as well; only that little respite of a weekend 2w ago, where Spring temps below 65F at sunrise were suddenly back (slept like a rock).
    Biz here still seems wobbly on its feet, like a prizefighter hit by a Naoya-Inoue liver shot of a storm. History dictated what permanent parts of infrastructure were and how they were built here (drainage, sewage, all things designed to limit or eliminate risk to life and property).. and back in the dark days of the plantations, no one planned for trillions of gallons extra water in atmo. So many, many thousands of hectares of property immediately adjacent to the mountains (where control mechanisms must exist), have ailing and wholly-insufficient means of controlling storm runoff, slide formation, and mudslides.
    Maui County has been starved of its own tax revenue by archaic Ariyoshi-era statutes deeming Honolulu w\ its greater population should take priority over Maui for pooled tax access... but when it serves their needs to let MC fester whilst Honolulu prospers w/ pork (I mean, how long did the H-3 project take? And how many billions? And how many actual users of the highway, despite massive maintenance for the terrain it cuts thru? :mad:). So our infrastructure's sat 1950s-era for generations... until of course the collective greed of humanity for greenhouse gases (mostly the US, should be emphasised -- the very country in which FreeDumb is espoused and enabled) created the conditions for all manner of natural mayhem globally.
    Here we were spared the worst effect mainlanders were dealing with about a decade... until the Hurricane-Dora-the-Destroya-enabled 2023 Hawai'i fires which incinerated Lahaina; since records have been kept, 100-mph winds over the WMM, even in a hurricane, was unprecedented. None of our then-current safeguards against natural disasters were even close to being able to save what was lost... and fearing political fallout, polits cowardly, reliably pushed the issue onto succeeding ones, like a game of hot potato.,, until like all procrastinators, their diminishing-returns, short-term strategy made it all worthless... just as generations of taxpayers and utility-consumers had been saying since the '80s. 'Prove it', indeed...
    bodywork stories for later
    Today's installment isn't something that happens nearly as often as most ignorants think... but isn't unheard of, including in my own exp.
    Talked earlier about a woman who were ahem, getting too much relief out of the session... and someone who may've been fishing for a way to entrap the unwitting novice bodyworker into an extortionist corner (thank goodness I'm somewhat paranoid by nature -- Dog Year after all :p). But about once every thousand new-client sessions turn out to be quite uncomfortable, demanding boundaries be drawn.
    Gotta be careful around this issue. Clinical and professional are the gold standard, and protect oneself legally (tho already mentioned, have countermeasures already in place if ever becomes necessary). Faced with something threatening legitimacy of the session... one must conduct themselves in quite specific, ordered and controlled ways -- including drawing boundaries.
    Ime, doing this full-bull accusatorially, will often open you up to more trouble than you want (esp if they have a s/m acct to gaslight on). So what's worked historically, is to educate and be firm w\ what you will and won't do when unacceptable behaviour appears... but also in a way allowing plenty of escape routes to voluntarily abandon it. Learn and read non-verbals and body language whilst doing this.
    Often when you state plainly you won't tolerate the behaviour under risk of being sent home, the decent if perhaps just clueless client if not in complete contempt of everything you stand for, will slide out of their fantasy cosplay egos and be good -- so compassionately allowing their pride a bit of room to survive the flub of misreading you as less than legit, is and has proven the smart move.
    But having done so, if they then out of embarrassment, doubling down on contempt, or mental illness, decide to get abusive physically w\ you... have countermeasures for that as well, within easy reach for me and not for them. Blessed to never have had to deploy the second set in 15y+... but have come close enough, will never not have it there :cautious:
    This issue only seems to get to the latter point, when client's a male and obviously closeted -- w\ a heaping helping of self-loathing :rolleyes: Females are much more rare, but not 0 (even in my practice). Same way to defuse, and often keeps a paying client in the pool, who doesn't turn around and badmouth you to the world, behind your back (y):coffee:
    Epilogue -- something I'm not well-versed w\ handling in this situation, are psychopaths -- which even seasoned LEOs w\ hundreds of hours clocking criminal behaviour, struggle to even detect. Which does raise the temp in mind's eye w\ each new client, ngl... esp if not referred by a GSC. But can't live your life constantly pumping cortisol into your blood, fearing the appearance of a theoretical psychopath... so instead, look at the negative space -- iow, when a threat's detected, is it paired w\ the usual body language from clients? Any lack of match w\ known signs, whether of legit or errant behaviour, stay calm, but get ready. Works in a bar fight, works on the racetrack, and worked to now, on the table.
    Still, uneasy thinking about someone w\ zero conscience, therefore zero impediment and 100% conviction for what they want to do to you, only opposed by 1) acquiring the threat 2) taking calm and measured steps to avoid it, and 3) carrying a big stick :cautious::coffee:
    #192 futurist, Apr 15, 2026
  13. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Thu 16 Apr 26:
    Is it Stockholm syndrome, to find it odd the weather outside's this nostalgic, faraway paradigm of 'normal'...? :confused::rolleyes:
    Still not the '97 version as standard in my head for 'normal' -- since about 2010, cloud formations I'd never seen on Maui growing up (seen them plenty on mainland and in Europe) are now common enough to fatigue -- and that's when there's no recent storm system muddling the puddle (or is it, the brief calm between these brutal Kona-low-for-granted storm systems? :unsure:).
    Tried to just let that sentiment sliiiide out of the melon, with a bit of counter-reinforcement: pulling throttle angle after 40 mph :p
    It'd been a tickle back of mind a while now, since the ramp-up to learning how to drive my first hybrid has so many subtleties... but becoming somewhat meditative. Less the throngs of 30-overs in beat-up Altimas rushing to work every morning, as if they don't have a choice :rolleyes: ... +$2-per (and heading towards +3)'s really made driving lately, dare I say it... pleasurable (y)
    Have defo lived other places where both boring sane drivers and 100-mph-on-freeway-in-full-meth-tweak, coexist somewhat more gracefully*... but guess it's taken nearly $7 / gal bathwater, to get the worst offenders to slow the eff down here (ime: brodozers, junky cars driven by herb-paranoid urchins, and FedEx/OOPS). Of those, two out of three ain't so bad, when your jam is to drive super-smoothly (outlier's the f***ing urchins -- because of course they are :p).
    Take off from a light:
    • stay in R lane, exercising pulling throttle whilst still accelerating
    • let all Gonzales' pass in L lane, until clear behind (depending on time-of-day traffic). Wave them past 4 - 5x w\ 2 extended and joined fingers... then jink closer to the white line to physically signal they're fine to go
    • maintain 3 - 4 car lengths behind vehicle ahead, unless it drops < 45 mph, upon which pass / pull ahead until reaching clear R lane
    • repeat step 3. If the car you just passed wants to re-pass in spite, despite being below SL... let them, and maintain optimal cruise
    • corollary: if you do have to pass someone... give plenty of room (4 - 6 car lengths, or when their entire car's visible in the rearview... tap brakes then signal back to R lane, slow to cruise again)
    • try to maintain max time in EV mode, using minimum throttle ICE ON, whilst maintaining exactly the distance to car ahead, as they are to the car ahead of them. No one factor outranks any other... but when in doubt, maintain distance
    • This accomplishes two things: calms most drivers who are R-lane adherents anyway, into not f***ing off ahead by pulling out to pass, c**k-blocking what they perceive to be a speeder using them as a DRS windbreak. Triggering this creates a chain reaction where the dreaded red mist starts to spread over the board, and that's rarely calm to drive in. 2nd thing, is it prioritises current position on road over ultimate position on road... which is both easier to drive in, nets better 5G mpg, and encourages others to join the conga line. Sounds a bit twee... but at least on Maui where douchiness in $3.80-per days is San-Diego-rampant... it works -- and even moreso, $6.40-per...
    Driving calmly like this, letting the mist I used to inhale like John Anderton huffing clarity, wash above and past me... replaced with -- tbh, du nno exactly :censored: But there's this tangible space my mind slips into, rejecting all the harm and inflexibility of decades of driving aggression, like deciding not to kill today (as Anderton chose in Room 1006). Have mentioned my driving habits have calmed a lot since turning 40... and suppose it then took this long again, for the mind to actually change into something where it didn't need that flash. Du n no tho, never been here before :p
    Mind you... have been doing most of the above since moving back to Maui... just letting myself get triggered and reverting to that kid what learned how to act in the chaos of 1991 D.C. traffic on a sportbike. Tbh East Coast drivers are just as aggressive as West Coast... just much harder to read, and obeying different social contract. Lacking this, the easiest way to foil it (at least in early '90s) was to be unpredictable -- 180º-polar to what's working in the 5G now. Almost as if my subconscious suddenly perked up w\ 'what if you did the exact opposite of what you're used to? How do you know it doesn't work?' And for years, didn't actually know... but finding out was a waste of time, impossible, illogical. Delusion's just as smart and capable as you are, for making and justifying dumbarse, glandular decisions :rolleyes:
    (popped out to get meals for the next two days)
    Back, tested this all again -- and big whoop, no one blasted past, as is outside rush hour and pau hana (Hawaiian for 'end of work day'). In fact, trolling along at conga-line speed down the main vein home, cars in L lane were piling up behind two ¼-mi back, which I'd been steadily yarding gently at current pace (they were going at or slightly below speed limit). Those in front causing this congestion, were two small ICE-only cars, not hybrids btw.
    In any other timeline where fuel was cheaper, they'd have been honked at and swerved around, procession of 20-somethings hammering past. But nope -- the whole distance, the backup maintained what cars in front did -- no driving on the shoulder, no contact / cars flipping in the median... which sounds cartoonish and fentanyl-flyover-state-caught-on-dashcam fodder, but has happened here more than once in recollection, just not in eyeline. 'Ice' has been a problem here long before the ICEstapo meatsacs :unsure:
    None of that. Just... calm and orderly. How about that indeed o_O
    So yeah. There're defo real issues in this world to be proactive w\ great prejudice about... but tbh, the wisdom of just minding my own Ps & Qs first, seems scalable to any problem. Doing what I'm doing in traffic, doesn't mean I'm a doormat... and esp if it produces fewer solutions than problems, naturally I'll choose to do something else. But in traffic -- my blind and weak spot -- I know it seems dumb to yammer on about but feels significant to me, in a quite characteristically-Me very-late-bloomer way :p:coffee:
    * Phoenix's super-option'd grid of surface streets tend to soak most of these up, as a recovering addict workmate clued me in back in '90s: 'you'll eventually just die in a ball of flame, trying to speed on the freeway tweaking. At least on the grid it's 45 mph, and you can just run the reds you want'. Which for most of these dying-candles-at-32, was all of them :sick:
  14. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Fri 17 Apr 26:
    Whoops forgot to include bodywork stories yesterday. As we go forward there'll be fewer and fewer cases that remind of earlier notable ones, so don't hold your breath for constant stories :p Will pivot to a journal mostly, w\ bodywork stories as they're appropo...
    With the news this AM of the Straitjacket of Whore-Moves reopening, announced by the caliphate side... oil futures are in freefall, meaning should be reflected in pump prices by next week (depending on how strapped the station you frequent was, just after oil shot thru the roof a la Operation Epstein Deflection :cautious: ). probably not going to pre-deflection prices, but cheaper than $6.xx+ at our pumps :whistle:
    Which of course means, the brodozer swarm had to rub it in our now-sooty, non-urea-treated faces :rolleyes: Two full-throttle pulls in town, lingering clouds of graphite-coloured cynicism and petulance hanging over the scene of the grime several seconds. Well, if anything they're consistent (n)
    Also reflected in people's behaviour on-road. Much more traffic in L lane swooping +30 mph past, me waving them by... none of this +10 mph thrifty nonsense :p Boy wasn't that a stroke of luck for your 24-mpg crossovers / 10-mpg lifted pickups. Guess it's back to the usual douchery :oops:
    Which oddly... didn't really give a rip about. Gained another tenth on the dash... and that's w/o zeroing out the readings to reflect only my driving, not the bodyshop or dealership techs (who could give a rat's about what I've accomplished). Not bad -- certainly wouldn't have happened had I not gotten a f***ing clue, about who I'm actually driving for, and why...
    Craving something different in my diet -- which is über-strange, as been known to eat the same diet for years. Current one isn't that rigid tbh... but coming up on summer, something's changed. Still can't put a finger on exactly what, but feel like some exploring'll be in order come May Day (01 May -- Hawai'i holiday since the '20s, also known as Lei Day. Rarely get laid on that day, but young people can dream :p )...
    Thing is... Maui isn't known for being amazing in many kinds of cuisine, as recipes for such tend to stay in families and not made into Local institutions. Some have, esp in the halcyon days of '50s - '80s when Locals were all plantation-worker descendents... but with the glut of least-effort, novelty-based garbage from food trucks here (if you're from L.A. or the boroughs and used to mind-blowing flavour if not value... you'll be disappointed with fare here, riding those coattails), hard to know where the sweet (savoury?) spots are betw. quality and price. If anything, on Maui you'll cave on price, as everything's at least on par w\ SoCA prices, middling or paradigm-shifting. So will have to carve out some time for deep dives...
    I don't need empty showmanship -- that squirt of triple-nozzle Cupie mayo atop things doesn't impress me at all; more like shorthand for 'lazy'. Usually a peek at the plancha, and hands of the line cook tell volumes... if it's on there after seeing that, than more likely to try it. Don't need much more than the basics, either -- not really my bag if you charge extra for the perceived work you put in (that defo isn't levied by better vendors). If you make shoyu chicken that brok' my mout'... I'll shell. If you want to hide your incompetence behind a fence of fancy toppings, or can't hire a line cook so your indifferent nephew has to stand over that hot plancha... save the effort, I'm down the road already.
    Honolulu and esp Waikiki have some of the best food in Hawai'i generations now. Well makes sense -- most immigrants move to where the work is, so those with traditions of great yet affordable street food will flourish on that demographic. Some of the best ethnic food I've had in my life, has been in Waikiki. Not behind giant, florid ads or street marquees... but where you see the line full of ethnic Locals. Korean food, can't go wrong seeking w\ that guiding you. Honolulu tends to attract immigrants who want to work cooking... whereas here, they tend to be fading scions who want to surf :rolleyes: You can see where that tends to favour profitable food, vs. amazing that sells from rep alone -- both which keep the lights on, but the latter takes much more grit to accomplish.
    Oh well -- w\ the bumper crop over since before the storm... pivoting back to canned food as a way to stay in the black. Frozen and canned veg tend to be quite good, just need to do more cooking vs. my usual but somewhat-expensive ready-made-bento-box meals. More salt and more dependent on my novice-at-best cooking skill... but that's life for an ascetic :coffee:
  15. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Sat 18 Apr 26:
    Well what a surprise -- the Strait's closed again. Guess this means fewer WOT pulls thru town by the brodozer contingent :love:
    Weather's... setting off alarms again, in my head anyway. Supposed to rain today a bit (must not be much, normally NWS posts a number on the rain bar graph itself, and lowest I've seen is 0.01") and then again in two days... but Warsh Sunday seems clear -- for now. The 5G needs a bit of a wash to get all those damned bug splats off the front clip, windscreen and wing mirrors :cautious:
    Clouds look a lot more like the dynamic weather surrounding that month-plus Kona-low storm freight train; much more speed in upper atmosphere ~20 - 40K ft. Last night was more humid than last as well, so that bodes either a cold front coming in (unlikely mid-April w\ summer just around the corner), or a warm one laden w\ deluge...
    Sure enough, looking at GOES-17 West images of our area... a big fat pawprint of high-level moisture's hovering over the state, rather wind-streaked southwesterly; seems parked for the time being. But more importantly more SW-erly to that, is a system of tropical storms around 10N pumping higher altitudes w\ c'nimbus moisture. Not sure if they're related but does seem odd their weather's moving in exactly the same direction, overlapping one another. There's also a big high-pressure wave coming down from the north, so may keep the pawprint from shifting towards the mainland -- not good for less rain in two days.
    Looking at earlier footage, ~0800Z (2200 HST last night) the pawprint itself busted off proper abt half a grid square southwest of us (15N), so must be a localised low drawing in the slop. Hope I'm just overanalysing this and all blows over -- was just getting used to not driving in gritty spray :unsure:
    In more terrestrial news... morning salad spot ran out of kale, wut :unsure:
    Of all the supposed health food stores on the island, this one seemed to have its act together most when comes to the only ingredients I cannot skip in a salad: cruciferous veg. Luckily purple cabbage & broc to the rescue, tho significantly heavier than kale, curly or flat-leaf -- matters when a pound of this stuff is $16 :cry: Sorry y'all -- subbing the usual lovely kale salad I've been coming here literally 10 yrs for, for spinach...? Which isn't that healthy to eat raw? (tonnes of oxalates vs. kale, which for me and my kidney warnings of late, is a showstopper. One can easily get the Mg, Fe, and folate spinach has over kale from other tasty foods like chickpeas or nuts, already in daily diet*). If they bothered to par-boil then chill the spinach and discord the water I'd be more apt to try... but just bunging bagged spinach w\ some almond slices and a thrown-together soy sauce dressing...? 404, won't be found in my system :sick:
    * just make sure, if you're getting Fe from non-animal sources (non-heme), that you pair it w\ Vit C like tomatoes to help the body absorb it -- generally easy and cheap esp if you grow your own (peppers incl'g boring ol' bells, rose hips / acerola and mangoes are also loaded with it) (y) If you're not vegan like myself and indulge in mostly non-hooved meats for health: clams, oysters, shellfish are great for Fe too, if not exactly affordable w\ the best provenance these days. Tend to skip it if I don't know the waters they're filtering are reasonably free of pollution (many overseas sources are filled w\ industrial runoff).
    no clients of note from yesterday as well, hmm. Tho schedule wasn't packed either. Stay tuned...
  16. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Sun Warshin' Day, 19 Apr 26:
    Phew -- finally, a proper wash day again. Which oddly it didn't turn out technically to be, per what was considered normal prior to the Month of Seattle Slop...
    Nice well-rested wake-up, rather easy getting going this AM -- traffic light and a bit faster due to the throngs who think fuel prices have come down for good. Not while that nutcase is CiC, it won't :cautious: Got the usual stall at the presshawarsh place, got it done in a tidy time. Drove to the first wax spot and got nice glossy ceramic coats on the hood and roof. Nothing untoward so far (y)
    After finishing the orbital buffer tasks... looked up and noticed a thickening of cloud layer in the notorious-of-late Kona-low direction (southeasterly). Tidied up and immediately took off to get ahead of any squalls, as they'd cross the main vein connecting north and south coasts in the isthmus. Got a drink and a lunch salad and headed south to Wax Spot 2...
    Two things sort of deflated me about completing arguably the more tedious and squat-demanding part of the job: monkeypod pods were filling the driveway to WS2 (these pods are like tamarind in a way -- solid 5 - 6" pods of seeds surrounded by a bitter resin that hardens like amber when dried -- when these things get run over, they splat all over the inside of your wheel wells... and if unlucky, your rear fenders and doors). So parking at the Spot, getting out had to peer in the wheel wells, as this resin if left to its own devices, will slowly drip like grease onto vital components like your brake calipers... then harden in response to the heat. Also smells like a distilled version of a swamp.
    No monkeypod resin, thank goodness... but the weeks driving in muddy water had stained the fender liners permanently dull brown (tried scrubbing it off to no avail and plenty of R knee pain). Also, the f***ing infestation of gnats, mosquitos and other small, splat-able vermin all over the front of the 5G, even prior to cleaning them off, was depressing... as their little acidic f***ing bodies not only degrade the ceramic coat... but the hard parts like mandibles will crater the soft plastic Toyota uses for end caps... meaning a 4mm f***ing fly can bring the value of my car down, right after spending hours caring for the paint. How the f*** did it come to 100 of them per day? For almost 2y, was maybe 1 - 2 a day, and many days zero. Don't even want to think about what the A/C condenser looks like :unsure:
    So groaned and winced getting the ceramic on... when realised something: the Griot's Garage formula used on roof and bonnet, can also be applied to the vertical surfaces, w/o forming that dusty white residue. How? A method that didn't work, last summer: applying it by hand :rolleyes:
    But my meeellions of words panning Griot's all this time, thankfully weren't in vain: in order to get the same kind of shine on doors I'd been relying correctly on Hybrid Solutions spray for... you must start with a clean, fresh microfibre cloth, and it'll only last for the same area of paint, as two car doors :cautious: Past that, the residue of the Griot's itself on the cloth will prevent the kind of fast, long-wearing shine it's given easily w\ orbital buffer on horizontal surfaces. Glad I'd toted along a roll of buffing cloth (basically supersoft detailing microfibre, in a roll like kitchen roll)...
    So W TF is this Micky Mouse horseshite? Literally 10F difference, and you can't buff this stuff on by hand? That's really the only difference betw. conditions last summer, and now. HS doesn't care if you use a dry microfibre, or one almost sopping with it (tho is a bit better buffing w\ a fresher one, but not a showstopper like Griot's). Sooo much more forgiving... but you give up ultimate protection. Thanks so much Griot's for being amazingly effective on horizontal surfaces w\ cordless buffing, but a PITA on vertical ones... plus being picky about how you're handled. Slightly better for me, as feel better about putting this stuff onto more near-horizontal surfaces (for its superior UV protection and beading vs. HS), just need a good supply of clean microfibres, at the ready :cautious:
    Yep... soon as back home in the driveway, looked at the 5G's front clip -- loaded with bug splat, faaaack. Guess we're back to the days of mosquito-filled canefields, when this was the standard (car paint was much more toxic but much more durable than now, so could handle harsh chemicals to strip off their acidic little sugary bodies). Can't let this go uncleaned a week for sure... probably gonna have to devote some time to cleaning them off after breakfast daily, and just not drive as much. What a PITA for someone w\ bad knees :sick:
    #196 futurist, Apr 19, 2026
  17. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Addendum, Sun 19 Apr 26:
    Resting a bit after finishing the weekend chores. Mum called me to tell me she'd made me something; come pick it up. Jumped into the car... to find she'd wanted some shredded cabbage for a meal but didn't want to let the part she didn't eat sit in the fridge... so shredded and gave it to me in a ziploc bag. Uh, thanks :sick:
    Not that I'd turn down shredded cabbage, love it as much as kale... just didn't think I needed to drive ten mins to get some, right effing now :rolleyes:
    Humidity's been over 90% all week... and normally this'd keep the smaller insects from flying as the moisture weighs them down. Nope -- apparently whatever population boom's happened after all that ground-saturating slop, has fruit-fly-rapid-evolved to fly when it's nearly 100%, dammit.
    But that moisture-bad-for-flying does make sense, as those vermin what do hit my car on-road, splat the clip and not the windscreen (those tend to be from settling on the dew parked overnight and drowning... then clearing w\ wipers first-thing, smear into this adult-proof smegma that dries so hard, you need a fingernail to scrape it off -- dozens of little smears all over my line of sight). Doesn't matter if the screen's filled with dew, nor does it matter if I spray w\ washer fluid prior to sweeping the wipers, those little drowned f***ers cannot be moved w\o an arc of yellow schmutz, to beyond-the-grave-middle-finger my commute :cautious:
    Since the rains stopped tho the 5G's not hated life so much -- gaining tenths is still harder than before the body shop and 20K... but isn't as hard as driving thru spray. Really should make the ICE air filter about twice the area it is. Just found a NAPA Gold filter yesterday about half the price of the Toyota OEM part, good filters, been using them in other cars for decades. May give that a try to swap it out more often w\o taking a note to pay for it :oops:
    Oh -- found an old laptop cleaning out my office bureau (jesus the crap I'd thought needed saved back in apprenticing daze, in the bin w\ maximum prejudice :LOL: ). But its SSD was something worth saving, if just as an external drive (512G isn't giant storage but is in effect another laptop's worth), so looked up some enclosures to get its files added to my current machine.
    My music svc has a really bad habit of changing the metadata for songs owned since the late Y2Ks... so have to buy them again, as the svc'll say it doesn't exist. This came to a head w\ the last model of my laptop mfr's to use a type of processor it no longer uses... and lost a bunch of music trying to get the files migrated from this dumpster-fire model onto the utterly-reliable machine which replaced it.
    Took it to a worthless 'specialist' in town... who held my machine a week, then handled it back to me in a box, with the SSD in a little static-proof bag. 'Sorry, couldn't get all the files but you can buy an enclosure for it and migrate it yourself'. Isn't that what I gave it to you to do? :cautious: Good lesson about trusting a fly-by-night outfit w\ no provenance... even so, do they treat all customers this way? Pissed but couldn't do anything about it at the time, had to tend to clients.
    So 300G+ of my shite has sat on this SSD, inert in my bureau... probably since the first Cheetolini reign? Just got on w\ life, forgot about it.
    Man -- current laptops are a damned sight lighter than they used to be. Can't believe I used to consider this old thing portable -- 17", 5 lbs -- current one is almost 3 lbs lighter and way slimmer despite being easily twice as fast at everything & a waaay better screen, consuming a quarter of the power o_O
    Just pulled the trigger on an enclosure, hope can get my machine to stop telling me music recorded as purchased, doesn't exist :rolleyes:
  18. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Mon 20 Apr 26:
    Yep, the gnat / midge / mosquito problem's still the same -- probably moreso now that that month's rain's created add'l habitat in the medians and shoulder, w\ knee-high grass. Old saying by white people who moved here in the '70s and '80s... was red-dirt-based soil was so fertile you can stand a broomstick in it and it'd take root -- welp, guess that still applies, just add a month of water :cautious:
    What's more frustrating... is I'd already upgraded the screen door & window screens to a smaller-pitch 'mosquito-proof' type last year -- and slowly over the course of intervening months... would stop skeeters but more and more of these midges would easily fly thru at night, attracted by the light of my laptop (keep most lights off at night except security ones, and they're sensing so aren't on all the time. If something or someone were to waltz in, would immediately be picked up by my setup, energise lights and warn me -- a tangent story I'll tell later in the Coincidence thread). Now post-super-slop event, the midges are sieging the casa, dozens buzzing around to meet my clapped hands every night.
    Outside, even worse, as those vermin which can't negotiate the screens are waiting for your exhaled CO₂ and an easy blood meal. Literally since the '90s have not been outside at night w\ more mosquitos, which are swarming even during the day, all day (worse around large bodies of water, like Kanaha Pond and every f***ing low spot in the isthmus). The long dry spell we've had several years now, probably made insects as in the Southwest, adapt to be super-aggressive during times of plenty... and over a month of rain (still not done pissing down) is plenty.
    Gonna wax on Chinese zodiac stuff for a min (free to read on at the *)...
    2014 was a weird year for me... and 12y later as Year of the Horse wheels around again... it does feel rather tumultuous.
    Old enough now to look back on quite a bit of formative events in life... and seeing how the zodiac animal year may match some key moments or trends (don't just apply to myself, but celebs as well, esp those w\ zero investment in East Asian traditional beliefs.
    Horse years were 2026, 2014, 2002, 1990, 1978 -- going backwards, Fire Horse, Wood Horse, Water Horse, Metal Horse, Earth Horse.
    The Horse is known as a highly-perceptive animal, as well as social. Shorthand, nutshell version, is people born in this year are like a wild horse you catch and corral on your farm to tame and do work. At first, it cannot be handled, refuses any commands and even jumps the fencing if it can. But if you feed it well, treat it well, and stay gentle and patient... you can open the corral gate, and it'll take off, not to be seen all day. But at night when you're ready for bed... there it'll be at the gate waiting to be let in :p
    That was the ersatz dojo story I were told, a Japanese version. Later I'd find the Horse to have qualities I'd later clock well with actual experience w\ people of that year, from Chinese accounts.
    A source I trust implicitly since doing more digging on the roots of this belief system... eloquently describes the Horse:
    I'm the kaleidoscope of the mind.
    I impart light, color, and perpetual motion.
    I think, I see, I am moved by electric fluidity.
    Constant only in my inconstancy,
    I'm unshackled by mundane holds, unchecked by sturdy, binding goals.
    I run unimpeded through virgin paths.
    My spirit unconquered— my soul forever free.
    I am the Horse.
    Theodora and Laura Lau -- The Handbook of Chinese Horoscopes
    "Constant only in my inconstancy'
    -- that seems to be the overarching theme this year so far... and as the element of my birth animal's susceptible to the Year's (Fire Horse)... it's been trying but not as bad as some years of the recent past. Unlike other years where themes can last months or even the whole year... here both victory and defeat are paid out in equal measure :unsure:
    Example would be the stupid, unnecessary car bash incident NYE -- happened in the cusp between the two years of Snake and Horse... and whilst the Snake was a rather uneventful year in hindsight save key moments of crisis (much like walking thru the tall grass is boring, up until the millisecond you're bitten in the arse by a black f***ing mamba to live the last 15 mins of your life); seemed it chose its dying moments, at the very end of its Year, to strike one last blow... arguably the worst of the whole 'chilada :rolleyes:
    That debacle went on 90d all winter of the NY, upon completion which could be said, the whole process could've been very much worse, based on experiences prior (must've gotten to antivenom on time :oops: ). This is what seemed to happen in '14 around the same time (Spring) -- came out of a nasty situation much better than it could've gone down (and tbh, should've). Into Summer was rather reeling from the close shave, which would result in making exhausting decisions, but handled it all okay and came into the new fall & winter somewhat ready for the unforgiving nature of the Goat Year (and boy would I be working then -- and not necessarily on clients).
    My lessons from 12y ago: even back then, do NOT buy a used 2001 - 2005 Honda Civic of any trim (7th generation -- oddly enough, around the Horse Year, starting with the Snake :eek:). They're easily the '80s Cavaliers of the Honda lineup, and are designed to be made cheaply, which Honda was not used to at this point. So they just made them poorly, as bad or worse than a GM vehicle of the same era... just to see how far the market would tolerate it. They'd release a snazzy new and risky cab-forward 8th-gen in 2006 -- still with major drivetrain problems like block cracking on the R18 motor -- so owners would stay with the company, 7th-gen warranty problems were so bad. Their customers would be betrayed multiple times like this to today, me included... thus the 5G under my butt today, for the AM breakfast run (y)
    All
    Hondas of that era -- esp Odyssey, Accord, and several Acuras -- had annoying to showstopper problems (like the Odyssey's transmission failures at 80K) too much for me to handle even as a certified mechanic w\ a top box and rollaway 12y ago... so defo carrus non grata today -- anyone driving one, either has no choice, or willingly waiting for it to empty their wallets -- glad they're finally almost all in the landfill (whilst its predecessor 6th-gen, w\ '90s-old-school, real Honda dbl-wishbone suspension and bulletproof drivetrains, are still driving around getting 36 mpg at 200K+) :rolleyes:
    1990... lessee, how about Operation Effing Desert Shield, the biggest mobilisation of regular military personnel and materiel, not operators or Marine units, since Vietnam. If anything in my recollection was a roller coaster of ups and defo humbling downs... the buildup to Desert Storm and the Spring of My Discontent, was a big one. I were overseas in the most decorated division in the Army on the old Soviet Frontier... so yep, were involved. Wouldn't give up those memories and exps for anything, but f*** me... would not want to live them again in my 50s. Or 30s o_O
    1978 -- may've already talked about upbringing in late '70s in Hawai'i... and that year in particular's full of very formative moments to stain the rest of my life -- but as the Horse year tends to do at least ime... is it sort of tough-loves you into being ready for the Goat year -- which as anyone who raises goats knows, will give you zero warning before burying its forehead in your nads, in max vindictive destructive prejudice. Also a good year to get stuff done (following Goat, 1980 being Year of the Monkey, which for me is an even worse Year historically) but Goat years will demand your full attention and commitment... or risk more scrotum-bursting reminders :p
    *In all, hasn't been that bad -- truly's late Winter / Spring's been a journey of trial so far vs. past years in last 12... but not as bad as many on-island. Re: work -- have been hitting the books as clients hold back during tax season... but the drought still isn't as bad as the really bad years around covid. But plenty to read signs for, and plenty of threats to acquire before things do get bad :coffee:
  19. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Tue 21 Apr 26:
    Weird night's sleep: restful, in that sleep was one and done and felt rested. Often feel tired on wake-up, when eating a bit too many calories for dinner, last meal of the day (6pm), or something about knee or back doesn't like the way the bedding's laid out for some reason. Fix that, and sleep the rest of the night thru to 5am... but it's still fractured (thus inferior) sleep. Last night was diff. however, as felt rested... but got up at 4am vs 5. Tried to nod off but unlike most attempts this one just wouldn't take. So got up and took the hit on the CPAP score, then got a head start on the usual rigamarole (cleaning CPAP for next use is longest and most tedious one, as learned there's exactly one order for it to be done to best results) :cry:
    Had those Chik-Fil-A coupons, so decided to spend time after breakfast getting a chicken biscuit for my mother. Delighted as she loves chicken sandwiches and hadn't tasted CFA before, so convinced her to try it, if only once (her generation of postwar Japanese immigrants isn't used to doing things for themselves, that was a man's job :rolleyes:... but had to scold her to balking at taking a coupon she only has to walk into the restaurant to redeem, for zero outlay. Wait, you go to several courses to golf twice a week just fine... but going to a CFA ten minutes nearer, to redeem a chicken biscuit coupon in person, is too much for you to handle?).
    So yes had to go get it for her, a naturalised American f***ing citizen :cautious:
    Anyhow, in the process of getting that done... realised I had an eye appt :confused:
    Not to worry -- set alarms an hour ahead, just to give margin of error in the vast majority of pinches to meet appts on-time. However, chicken biscuit will have to sit an extra hour. Think you can figure out how I felt about that :p
    Very interesting re-introduction to this doc's eye exam. We're both of the opinion one should not let the body become too dependent on corrective measures -- or things start to accelerate over time (over age 50) towards a point where reversing course is impossible. My eye scrip is exactly the same as last visit, in 2024 -- which hasn't happened since leaving Lenscrafters for this doc, but was basically the rule for 20y up until using those fly-by-night revolving-door optos at LC Ka'ahumanu Center.
    Current doc says my time using them, probably forced a too-strong scrip in one eye, which weakened and accustomed both lens focus mechanisms and brain, into that power -- and one cannot go backwards, all one can do (passive correction) is to keep the eye working to focus, until growing physical dimensions of the eye, force a scrip change. Otherwise, LC basically ruined my correction symmetry, eye-to-eye. Very glad I got out of that hole when I did :cautious:
    Also found my insurance requires dilation now -- which is new. Warnings abound for getting a ride to and from the office when doing this... but doc also says they can take steps to minimise the risks of dilation re: driving myself home, but cannot be skipped, as insurance requires proof to underwrite.
    Since I refused the dilation today on grounds didn't have a driver (of course doc was busy w\ other patients so could only go on what the receptionist stated)... exam would only be good one year, not 2. But next year could get the dilation and simply drive home, as doc would take those minimising steps... and no cost to me.
    Nothing like this has ever been offered any other time I'd needed dilation on exam -- perhaps due to risk of litigation? But if can see fine to drive (last full-strength dilation ~covid time, at my family clinic opto for contact scrip + exam prior to LC, was wondering what all the fuss was about, under those silly disposable plastic shades). If this doc can reduce dazzle, still get the exam done and minted by insurance... and still let me drive home alone... why not? So a bit of a tangent today but turned out just fine (y)
  20. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Thu 23 Apr 26:
    Sorry about the lack of entry on Wed -- just couldn't be arsed, had a tough new client but turned out fine, and had to take a nap, as my liver's about as spry as a deflated American football :rolleyes:
    Day of some rather stiff pushback today -- which is odd, as that dovetails w\ the notion I've been forming... that days when things don't go my way, usually aren't rainy days. Which belief-wise is rather twee, as I were born during a storm :p
    No matter. Was mostly running errands to rarely-visited spots like Costco, for sundries coincidentally all lining up to need done to-day :unsure:
    My bedding during the storm, had this aggravating tendency to trap moisture, meaning my perspiration. Arrange it slightly different, doesn't do it. Arrange it again, and wake up with a soaked back :cautious: So tried something to fix this, in my usual miserly-but-common-sense way.
    Figured most of the problem was the hygienic fitted sheet over the padding, over the sunken but filled old mattress... which doesn't wick water like a normal linen sheet. Instead it forms a barrier... and overnight, moisture builds to the point it can't escape up or down... so stays where it is, clammy against my skin :sick: Hate that... so looked at the problem.
    Need the hygienic barrier, has to stay given the inability to completely seal the room from windblown dust and who knows what being forced in thru countless leaks in this place... therefore who knows what's crawling up from floor to see what smells so bite-able two feet up (read: centipedes and cane spiders). Can't be attracted if they can't smell you, so that barrier's a non-negosh.
    The issue is perspiration not being able to escape being under me... but the towel serves that purpose, to wick anything I give off into itself and to the sides to atmo. Helps to have the fan run slowly all night to help this process along. Humidity in the room is never to the saturation point, as space under door provides a path for new air to enter and circulate, along w\ tonnes of moisture (windows have never sweat in the bedroom). Used to work just fine towel-only, but something's changed. But what?
    Save buying a new $1300 mattress in 2026 (so anything below that would defo not be worth the bag it comes in) and jettisoning all this compensatory stuff to avoid wasting that money... only way to solve this is to somehow provide an alternate path for moisture to wick away.
    So bought a simple, $10 bedsheet set from TGT, brushed microfiber. Use only the fitted sheet, slipped over the hygienic sheet, then the towel atop it as usual.
    Did this right after the storms broke and went intermittent... and holy f***, it worked.
    Only thing I can figure, is having that tiny margin of xtra wicking, has a big effect on how fast that gross clammy feeling develops -- and for a while was every night, unless miraculously arranging the bedding exactly right. Haven't had this problem since -- and weird thing is, the extra cheapie fitted sheet, doesn't even feel like it's wicking anything, dry as a bone. Just literally half a mil of extra cloth, and no more waking up like I'm going thru male menopause or some sh*t :LOL:
    Had to refuel -- 89 at my Texaco's holding steady at $6.09 per, little over $30 a 5.4x-gal fillup... meaning 62 mpg today, a nice little upgrade from last fillup two weeks ago. 'Fill up every two weeks', still boggles my mind, spending $25 in less-Orange-Julius-Caesar times, every 3 - 4 days in the Honda. People seem a bit less light on the throttle but the faction I hang with still seems fine with our miserly pace, and we tend to reinforce each other's decisions to keep right and relaxed. Hey this is 'Murrka... if you can afford the fuel, do what you want. But don't keep me from saving it, driving how I want ;)
    Costco has run out of f***ing masks. Of all the goddamned places for me to decide to-day to visit for things I don't shop very often for (last visit was 2025), chose today to be out, great. Not only do I have to wait for you people to open at f***ing 10am... but don't have the only thing I come here for besides nitrile gloves and olive oil (had gloves and don't need oil, thank effing God :cautious: ). Ended up getting a smol box at Wally's... but usually not my stop for masks, as Equate products are generally PRC-shite, including packaging. No chg in opinion based on this box of masks :rolleyes: But didn't want to drive around town looking either; will just get them online.
    no bodywork stories, as nothing interesting today (only one client anyhow :cry: )
    #200 futurist, Apr 23, 2026
