Bolt fell out onto my feet. Where does it go?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JonHakim, Sep 23, 2021.
  1. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Whatever umpa lumpa you gave it hopefully is fixed with the Loctite/thread sealant.
    Thank you for sharing your solution!
  2. hill
    8,803
    that can be remedied easily enough w/ either a thread file or a die nut. Either can remedy threads that are (no more than moderately) dinged up. What's surprising is that there's no evidence of thread locking compound on the application. That being the case, it may be that the welded-on nut is a 'stover' type, which are not recommended for re-use.
  3. Air_Boss
    Air_Boss Senior Member
    4,197
    1,183
    New Yawk
    As the retaining bolt worked its way out, the (rotating) steering shaft moved from no contact with the smaller diameter, unthreaded portion of the bolt, more and more into contact with the larger diameter, inner ~3/4 " of the threaded portion, rolling them over, until the bolt worked its way completely out. Clearly no blue thread locker compound on that bolt, but should have been.
