Bolt
Discussion in 'Gen 2 Prius Main Forum' started by lexidium, Feb 17, 2025.
  1. lexidium
    lexidium Active Member
    303
    144
    manchester
    Dropped one of the bolts that holds the coil in.
    I know the head's 10mm but what's the thread?
  2. PriusCamper
    PriusCamper Senior Member
    13,417
    5,416
    Pacific Northwest, USA
    It's a weird bolt, but if you take one to a hardware store and use their thread & size gauge you'll be able to find one that will work.
  3. pasadena_commut
    pasadena_commut Senior Member
    3,028
    939
    Southern California
    Or go to the pick your part yard and pull one from a wreck. Will be kind of expensive for one - the local LKQ charges $0.50 for one, pluse $5 to get in. I have not had all that much success at Home Depot when looking for metric bolts. The OP could order one from Toyota, these are cheap even there, but they may not have it in stock:
    https://parts.longotoyota.com/oem-parts/toyota-ignition-coil-bolt-90105a0103
  4. RRxing
    RRxing Senior Member
    2,562
    1,839
    NEPA
  5. Mendel Leisk
    42,293
    Our walking-distance Rona (lumber and hardware retailer chain store) has loose bolts and nuts, including a decent selection of metric. With that set up you can bring along one of the remaining bolts, test fit it on the metric nuts, then get the corresponding metric bolt.
    do keep in mind: the original-but-missing bolt IS close at hand; persevere at finding that “lost sheep”?
    I’m compelled to also note, just in case: Toyota specs the torque for those bolts in inch/pounds, not foot/pounds. Which are less by a factor of 12. A small but regular parade of priuschatters have attempted to torque those to that number of ft/lb’s, and snapped the heads off partway through the process.
    It’s simplest to appreciate they’re merely a light-duty hold-down bolt, snug them down gently.
    #5 Mendel Leisk, Feb 18, 2025
    MAX2 likes this.
  6. MCCOHENS
    MCCOHENS Active Member
    252
    101
    Chalfont, PA
    If you dropped it, a magnet on a flex might find it. Or it might bounce somewhere and do some damage. Finding a replacement should be pretty easy. Take the other one out and go to the hardware store. They may have a thread checker or just use a nut to identify the thread pitch. Probably 1 or 1.5 It is probably a M6 bolt. I struggled with this stuff for years then bought a thread checker for metric and fractional on amazon for a couple bucks. Now my biggest problem is find where I put it!
  7. ETC(SS)
    7,514
    OEM Part Number: 91551-80625 according to the Googles....
  8. Mendel Leisk
    42,293
    Looks to be about a buck apiece, say through dealership parts department. (y)
  9. lexidium
    303
    144
    manchester
    Thanks for the input guys.
    t's an M6 25mm. They have them on Amazon and they delivered on the same day. (Amazon UK are wonderful)
    They were a fiver for ten.
  10. pasadena_commut
    3,028
    939
    Southern California
    Most of the failures to find a matching bolt at a hardware store, in my experience, are because either they just don't have that size, or the ones that they do have are only threaded on a region near the tip, where the application needs threads much farther up along the shaft of the bolt.
