Bore scope pictures of my engine
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by msg4life, Mar 4, 2017.
  1. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    These are 2015 prius v 50k miles bore scope pictures. They are located in my media folder. Not sure hot to post them here.
    52,855
    yes, makes it tough to look at them. okay, pretty easy to find. looks terrible, but i'm no expert. what's your opinion?
  3. Mendel Leisk
    42,347
  4. Veliksam
    Veliksam Member
    108
    61
    Orlando
    2014 Prius c
    I think that looks pretty bad, perhaps bad piston rings?
    Is it burning a lot of oil?
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Reminds me of my '72 Kawasaki 350 triple 2-stroke. :eek:
  6. Mendel Leisk
    42,347
    I wanted one of those.
    jerrymildred likes this.
  7. jerrymildred
    11,517
    14,167
    Tampa, FL
    It was scary fast for a 350. But I had it during the Arab oil embargo and the gas tank only had about a 90 mile range. That part wasn't so fun when I ran out of gas at 1 AM on I-5 in Northern CA. LOL!
  8. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    What brand and grade of gasoline and oil do you use?
  9. jerrymildred
    11,517
    14,167
    Tampa, FL
    Indeed! And do you have pix on the spark plugs? Oily, Im guessing?
  10. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    So no oil burning. But the intake has alot of blowby oil. I put on a catch can just to see if it cleans things up. Sucks the dealer won't fix the engine. I use chevron 90 percent of the time. I use 0w20 Toyota brand. Also I change the oil every 5kAmazing for 50k plus miles. Right! . I'm still under 60k warrantyYes plugs were oily. I have been getting knock start. I'm thinking it's the oil from the blowby.
  11. bisco
    52,855
    how does your 2012 look?
  12. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    I don't own a 2012... I own a 2015. Prius v
  13. bisco
    52,855
    sorry, i was looking at the info under your user name. my bad.
  14. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    I wonder what others looks like and if this is something I can have the dealer fix.. And yes my spark plus were wet.
  15. bisco
    52,855
    i wonder what conditions the engine warranty covers?
  16. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    From working with Toyota... They work like this... No check engine light.. Car is fine.
  17. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    This is very surprising. Thank you for posting this. It makes me worry about my 2012 with 102k miles on it.
    Definitely keep us updated if you get anything out of them on this.
    That_Prius_Car likes this.
  18. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    What you need to show this to the Service Representative....and pinpoint the cause...Since you are not using any oil...there is something bad
    Fuel
    Suction for crank case
    Oil over filling
    This is not good for 50k engine.....
  19. Samprocat
    491
    297
    Lincoln, NE
    What also show on one of your pictures ....your spark plug torque spec are not right....some of them are way to loose
  20. Colin
    Colin Junior Member
    33
    How can you tell?
