Bore scope pictures of my engine
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by msg4life, Mar 4, 2017.
  1. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    I added a catch can... Now that start knock has pretty much stopped but after 300 miles. There was alot of water and gas. In the catch can. I'll post the pictures in my media folder.
    mjoo likes this.
  2. Air_Boss
    Air_Boss Senior Member
    4,199
    1,184
    New Yawk
    Catch can required for volume? Water in the catch can? Have you checked radiator coolant level? Internally-leaking head gasket or cracked head?
  3. Former Member 68813
    3,524
    983
    US
    Folks, this is NORMAL. I boroscoped 3 of my cars at 50,000-80,000 miles and they all look like that. I didn't do it on my 2010 prius due to difficult spark plug access.
    That_Prius_Car and Mendel Leisk like this.
  4. Mendel Leisk
    41,463
    Good to know.
  5. Air_Boss
    4,199
    1,184
    New Yawk
    Enough blowby liquids to require a catch can is not normal.
  6. Former Member 68813
    3,524
    983
    US
    i was referring to boroscop pictures.
    as for that oil in catch can, some cars do it more than others. when i removed intake manifold from my prius (for cleaning and PCV valve replacement) there were fair amounts of oil inside. Same in corolla. I don't know why. Have you checked yours?
  7. Air_Boss
    4,199
    1,184
    New Yawk
    Dry, as it should be. If you see oil, check the PCV. If you see water, check for quantity loss, head gasket, and do a cylinder leakdown test.
  8. bisco
    51,944
    all this, and no dash light?
  9. mikefocke
    3,998
    1,807
    Sanford, NC
    You get blow by, you get mist in the crankcase, the PCV valve is used to allow the needed pressure relief but there is oil that passes through the valve in small quantities. Some cars use an Air Oil Separator (AOS), even that sometimes fails and isn't 100% effective.,
  10. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    I think the condensation in the intake with the oil blowby is what causes start knock.. After putting in my catch can.. I do not get start up knock anymore.
    mjoo likes this.
  11. Mendel Leisk
    41,463
    What does this "catch can" actually look llike? (n) Any pictures?
    Ok found this:
  12. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    I don't want to post any particular version I bought to try and sell one but I bought 2...cheap ebay one for 15 bucks... Wasn't very robust then paid for another eBay 1 for 55 this had a baffle.
  13. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    This is the closest one I bought. [​IMG]
  14. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    You can see the condensation. That causes the start knock. And oil gas mix. 20170306_004339.jpg
  15. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    When I get back in town I'll post my set up and the road blocks when adding a catch can due to the fact there are two different hose sizes.
    mjoo, Aaron Vitolins and Mendel Leisk like this.
  16. tf4624
    tf4624 Active Member
    527
    51
    Re rout it the blow by. That's what I do. Less issues then with oil
  17. Former Member 68813
    3,524
    983
    US
    PCV was fine (they don't fail in toyotas based on my experience). I wish it was that simple.
    sorry, what exactly are we looking at? Not sure of that glistening disk. is it a petri dish?
  18. Air_Boss
    4,199
    1,184
    New Yawk
    So from where does this oil, fuel, water mixture originate and how is it entering/pooling in the throttle body?
  19. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Ughh...
    That's the attitude of most car manufacturers.
    The computer diagnostic systems in cars are great. But they also can be used as excuses to NOT do anything, when something should be done.
    IMO that amount of carbon build up and muck in an engine within a 2015 with 50K miles is un-acceptable, even if it hasn't reached a tipping point where the operation of the vehicle is triggering codes.
    Years back, I was rear ended in a new Honda Fit. I just wanted the dealership to put it up on the rack and check to see if they could see any visible damage.
    All I got from the dealership service department was the same mantra...No Lights...No Problem.
    I kept telling them I was SITTING IN THE VEHICLE when it was rear ended...
    And just because it wasn't "yet" throwing codes didn't necessarily mean there wasn't damage.
    I literally had to BEG them to just put it up on the rack and do a visual.
    They eventually took the vehicle back and SUPPOSEDLY looked at it. But to this day, I don't know if they actually did, or if they were just humoring me.
    So anyway, best of luck.
    Maybe with the aid of those pictures you can convince a dealership/Toyota that there is indeed a problem.
  20. mjoo
    mjoo Senior Member
    1,156
    1,328
    Michigan
    I'm interested in viewing your catch can install. Any updates?
