Bosch Introduces <$450 L2 EVSE (Power Max Series)
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Francos, May 10, 2013.
  1. Francos
    Francos Member
    118
  2. Francos
    Francos Member
    118
    Around $320 after 30% Fedex Tax credit. Cheaper than DIY
    52,914
    great price, but 12' cable is weak. 30amp w/ 18' cable is also a good price.
  4. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Well it's ABOUT TIME!!!
  5. Jim Gallagher
    Jim Gallagher New Member
    2013 Prius Plug-in
    I filled out the Bosch survey and I guess they will be contacting me. Do they need to install it or can my master electrician friend do this? Also for the tax credits, does anyone know if it is a 30% federal and 50% NYS for the cost of the unit, the install, or both?
  6. Rebound
    3,996
    2,645
    Portland, OR
    Any licensed electrician can install one of these. It's an ordinary 240V line with GFCI, at the Amperage rating of the unit (20A for a 15A unit and 40 A for a 30A unit, but electricians know that.
    Honestly, it's all very straightforward for them, no different than running electricity for central AC, electric dryer, hot tub, etc.
  7. Mark in Colorado
    Mark in Colorado Junior Member
    Is anyone successfully using the Bosch Power Max 30A / 25'?
  8. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :) I've never seen a Bosch Level 2 charger advertised. Wouldn't waste my money on a Level 2 charger with only a 12' charge cable, unless you have a ideal location right next to where you'll park and charge.
  9. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Thus far I think they are all over priced. The price will come down.
  10. Francos
    Francos Member
    118
    Anyone has this installed?
  11. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    I just ordered one and expect delivery next week. I'll keep you posted. You can use your own electrician, but the warranty will only be for 1 year. If you use a Bosch certified installer, the warranty is 3 years....but I am finding that the price is considerably higher. I am leaning towards using a local electrician and going with the 1 year.
  12. Francos
    Francos Member
    118
    Make sure to use a credit card with double-warranty if you use your own electrician.
