Bottle
Discussion in 'Gen 2 Prius Technical Discussion' started by John Clark, Jul 11, 2019.
  1. John Clark
    John Clark Junior Member
    Victorville
    I know this is going to sound silly, I have a Gen 2 and behind the passenger front fender, is a water bottle or wiper bottle or some type of bottle. Does anybody know what this is
  2. Tideland Prius
    16,681
    Behind the fender? like... inboard of the fender? If it's high up and large, it's probably the engine/inverter coolant. If it's low down and in front of the wheels, it might be the washer fluid. If it's high up but small, that's the brake fluid.
  3. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    That white plastic can and all the weird bent black hoses in the pictures are part of the throttle body air intake system. Not sure if its for sound deadening or part of the atkisson cycle mode weirdness where the intake valve closing is delayed in the compression stroke thereby back feeding some gases.
    That back feeding is quenched by the big plenum tank in the bottom of the intake manifold. There's a big bulbous tank under the throttle body that absorbs the pushed back gases from the compression stroke.
    In picture 2714 the big black intake hose with the bellows connects to the white can under it.
    Its like some sort of holding tank for intake air. I suspect its to quiet down the intake air.
    Lots of cars have intake anti resonator.
    #4 edthefox5, Jul 12, 2019
    SFO likes this.
  5. ChapmanF
    19,027
    The words for today are "Helmholtz resonator".
    In addition to quieting the intake, it reduces the impedance of the intake ducting, at chosen RPMs. It is a good way to win bets with people who sell mods to "reduce intake restrictions", some of whom may not have taken Waves.
  6. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    Or if you are talking lower, just behind the bumper, it would be the thermos for the coolant.
  7. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    A picture of it would be helpful.
    Tideland Prius likes this.
  8. PA Prius
    762
    251
    SE Pennsylvania
    I found this pic of the thermos. I was thinking it was on the passenger side, but not according to this pic.
  9. ChapmanF
    19,027
    Thermos is on the driver's side (maybe different, in right-hand-drive countries).
    No room for it on the passenger side, 'cause the Helmholtz resonator is there.
