Bought 2009 Prius from Dealer, recall work not done?
Discussion in 'Gen 2 Prius Main Forum' started by dmm, May 1, 2013.
  1. dmm
    dmm Junior Member
    I just bought a 2009 Prius from a Toyota dealer. When researching the vehicle I saw there were a few recalls but I assumed the dealer would have fixed them.
    When I bought it I looked at the carfax which showed all of the standard maint. had been performed on schedule.
    I signed up on the Toyota owners site to see the maintenance record and I see a red "Safety Recall Alert". I click on it and see these recalls: Safety Recall C0U and Safety Recall C0T. Apparently affecting the inverter coolant pump and the steering shaft?
    Looking through the records on that site I don't see any evidence that the dealer handled the recall problems. They had the car since December 2012.
    Is it possible they fixed the problem and it show up in the records? Do these recalls actually affect my prius?
  2. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    any dealer should be able to look up the VIN and see what has been done.
  3. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    Yes both recalls are required for your Prius.
    John (Britprius)
  4. PLSPUSH
    PLSPUSH Active Member
    359
    132
    Tulsa, Okla.
    just ask them
  5. boppo
    boppo Active Member
    799
    138
    Owego, NY
    I saw a thing on tv that it was illegal for a dealer to sell a car that was in their fleet of sales and not perform those up dates.
  6. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Simply take the Prius to any Toyota dealer and ask them to perform the recall repairs for you. It is clear that your Prius is affected by the recall as it is VIN specific.
    There should be NO charge unless you authorize additional work/repairs at the time of the service. You can expect the dealer to take a minimum of three hours to complete the work. I would suggest you make an appointment.
    Good luck to you dmm and welcome to Prius Chat!
    Ron
  7. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    It is the owner's responsibility to bring the car in for recalls, not the dealer because the recall notices are sent to the owner only.
    I know because I bought a new car and received a recall notice within two months and the recall had been out 8 months ago. The manufacturer still building and shipping the cars with the defective parts after the recall let the owner takes it in for replacement.
  8. boppo
    boppo Active Member
    799
    138
    Owego, NY
    But the dealer own it before they bought it so it's on the dealer to fix All the recalls before they sell it.
  9. bedrock8x
    1,483
    137
    The dealer does not own the cars on the lot and they are not the registered owner. You don't want them to be otherwise you will be buying a pre-owned car.
  10. toyotechwv
    toyotechwv Toyota Technician
    474
    251
    Princeton, WV
    Was it sold as a Toyota Certified used car? If so, completing any open campaigns (recalls) is part of the certification checklist.
    SPH-D710 ? 2
  11. dmm
    dmm Junior Member
    Thanks everyone for your replies. It was not a certified used car. I'll call tomorrow and find out what's up.
    Also I'd like to take this time to comment on how awesome this community is. You take a vehicle which is almost zero maintainance and you find all kinds of fun stuff to do to it. I'm definitely picking up some transaxle fluid while I'm at the dealer. It looks easy enough to change. And the recall on the coolant pump means I get a free inverter coolant change too.
  12. boppo
    boppo Active Member
    799
    138
    Owego, NY
    Don't forget to pick up the two washers when u change the tranny fluid.
  13. Scallywag
    Scallywag Member
    107
    22
    Columbus, OH
    I believe in some states it is illegal to sell a car with outstanding recalls. You should look into this, and bring it up with the dealer.
  14. dorunron
    3,318
    1,103
    Houston, TX
    If you do drain and refill the transaxle, it would be a good idea to open the top plug first. If for some reason you drain the fluid and then discover you can't get the plug loose to refill the transaxle you will be in a tight spot.
    Good luck to you.
    Ron
