Bought a 2012 For $700
Discussion in 'Gen 3 Prius Main Forum' started by Cosmo Tigato, Dec 2, 2019.
  1. Cosmo Tigato
    Cosmo Tigato Active Member
    201
    363
    Oregon, USA
    Meet up with the guy
    Before I got it, I pulled the dip stick and Milk Shake. LOL
    So yeah, Head Gasket is toast.
    The body is Straight and the Title is Clean, No Accidents. 208,784 miles
    Just some small dents that I will fix.
    He told me the he plugged in a code reader and it showed Water pump (that is all he remembered)
    So I gave him some Cash and hauled it home.
    11/30/2019 Hooked up the Tech Stream:
    Engine and ECT
    P0300 Random misfire
    p0301 misfire
    p0302
    p0303
    p0304
    p261c ENGINE coolantPump"B" Control Circuit Low
    Hybrid Control
    P0A0F Engine Faild to Start
    ABC/VSC/TRAC
    C1259 HV Control System Regenerative Malfunction
    Air Conditioner
    B1442 Air inlet Damper ControlServo Motor
    Combination Meter
    B1503 Exhaust Heat Management warning Detected
    Looks like the Engine water pump stopped and the guy kept driving.
    I thought of doing a head gasket job, but it almost has 209,000 miles
    So I decided to just put in a engine with lower miles...
    12/2/2019
    I ordered a Engine with 93,000 miles for $1200
    That's all for now.
    I should get the engine delivered on 12/6/2019
    I will keep you updated as the project continues
  2. Fifen
    Fifen Member
    77
    33
    Utah
    Looks like aftermarket wheels too. So you might be able to make money off those if the engine doesn't work out.
    SM-G965U ?
    TheeWood likes this.
  3. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Once you get it going get inverter firmware updated...... free at Toyota
    Probably needs a new traction battery....
    Cosmo Tigato likes this.
  4. orenji
    orenji Senior Member
    5,887
    3,488
    Make sure you clean the EGR before installing the new motor.
  5. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    What is a running 2012 with 209k worth? You’ll have 2K+ invested into this one in order to get it running, which is probably not much less than what the car is worth. Hopefully the HV battery is still good.
    iPhone ? Pro
  6. Cosmo Tigato
    201
    363
    Oregon, USA
    That is with 209,000 Miles But I didn't tell KBB that the swap motor only has 93,000mi
    tvpierce, hill, Threej and 1 other person like this.
  7. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    You're doing great, especially if you just want to drive the car, not sell it.
    landspeed, Threej, TheeWood and 2 others like this.
  8. Mendel Leisk
    42,346
    Engine transplant does not roll back the miles on a lot of other potential headaches, but yeah I think if this is just going to be a personal vehicle, not a quick resale, you're good.
    In a addition to all the stuff mentioned above: clean the intake manifold (special attention to the EGR passages), drain and fill the transaxle, change the brake fluid, full brake inspection.
    Consider an Oil Catch Can too.
  9. The Critic
    3,193
    2,333
    CA
    Those numbers seem a bit high. In my area, any running Prius (regardless of model year) with 150K+ seem to fetch between 4-6K depending on condition and luck.
    I would just be careful about how much you put into this car. You’re going to need more than just the engine to complete the swap properly - water pump, plugs, thermostat, egr cleaning, etc. Plus the rest of the car may have other maintenance or wear/tear items that need addressing.
    iPhone ? Pro
  10. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    This would have been a steal to just part out.
  11. Cosmo Tigato
    201
    363
    Oregon, USA
    I have a 2005 that I am parting out.
    After I fix this 2012, I will sell my 2011
    TheeWood and hill like this.
  12. Cosmo Tigato
    201
    363
    Oregon, USA
    Update:
    The Engine Showed up Today.
    I ordered Rear Main Seal, Intake & Exhaust Manifold Gaskets Plus the Valve Cover gasket.
    Next I will order the Water pump w/gasket,
    and buy the Spark plugs, oil filter, thermostat w/gasket, Fresh Coolant, trans Fluid etc.......
    -I have a shelf full of 0-20 so no need to buy more of that!-
    It's going to be easy to remove the EGR and intake manifold with the engine out.
    I will go over the EGR, Manifold and throttle body with a fine tooth comb.
    I will pull the hybrid Battery and test and check individual cell voltage and load test.
    The Tech Stream did NOT show any issues with any cells, so that's a plus.
    So nice that I work at an Auto Parts Store. Ha!
    kc5dlo, Bay Stater, dig4dirt and 7 others like this.
  13. Mendel Leisk
    42,346
    That's cool that it arrived with The EGR system intact. Oh, and intake manifold.
    Hopefully the oil pan isn't squished. I think that's a thing: they plunk them on a pallet with little thought to the weight bearing on the oil pan. Judging from the pic that's not the case with yours though.
  14. Cosmo Tigato
    201
    363
    Oregon, USA
    Yeah, The engine harness is also intact.
    The Exhaust manifold is also included.
    as well as the throttle body, flex/fly wheel. LOL
    Oil pan is not even dented.
    #14 Cosmo Tigato, Dec 4, 2019
  15. Cosmo Tigato
    201
    363
    Oregon, USA
    So Dirty.
    YUK!!!
  16. Mendel Leisk
    42,346
    Rear-ended?
    Also, not sure: been flooded?
  17. Cosmo Tigato
    201
    363
    Oregon, USA
    No flood, Just Yukky SodaPop.
    The Under side.
  18. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    #18 Tim Jones, Dec 6, 2019
    Aaron Vitolins and Cosmo Tigato like this.
  19. Cosmo Tigato
    201
    363
    Oregon, USA
    There was so much Soda and melted candy under the back seat and trunk.
    found over $5 in change under the back seat and carpet. LOL
    The Carpet was so gross, I pulled it out an Steam cleaned it.
    Looks so much better.
    Rebound, J1050, Bay Stater and 2 others like this.
  20. Cosmo Tigato
    201
    363
    Oregon, USA
    Looks like I will be cleaning the Bus Bars
