Bought a 2012 For $700
Discussion in 'Gen 3 Prius Main Forum' started by Cosmo Tigato, Dec 2, 2019.
  1. Cosmo Tigato
    Cosmo Tigato Active Member
    201
    363
    Oregon, USA
    The batteries seem to be in good condition
    Rebound and hyp3rmil3r like this.
  2. Mendel Leisk
    42,355
    I've heard drop the bus bars in vinegar (somewhat diluted?) but don't do that to the nuts, they'll turn black in an instant. Not sure if it hurts them, but who knows.
    Cosmo Tigato likes this.
  3. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    They all need to be within .20 volts of each other. Never can tell till you put a load on them. I used a car headlight.
    softdown and Cosmo Tigato like this.
  4. Cosmo Tigato
    201
    363
    Oregon, USA
    2- 7.61
    3- 7.61
    4- 7.61
    5- 7.61
    6- 7.61
    7- 7.62
    8- 7.61
    9- 7.61
    10- 7.60
    11- 7.61
    12- 7.61
    13- 7.61
    14- 7.62
    15- 7.62
    16- 7.62
    17- 7.62
    18- 7.62
    19- 7.62
    20- 7.62
    21- 7.61
    22- 7.61
    23- 7.61
    24- 7.59
    25-7.61
    26-7.61
    27-7.62
    28- 7.61
    Then I set them all up in Parallel and charged them up together to 7.80
    Letting them rest overnight....
    I will load them up with a few headlights tomorrow, Bring the parallel pack all down together to 7.60
    Disconnect the Parallel set up, let them rest for a few hrs and re-test them all.
    If they all test good i will put them back in parallel and charge them up to 7.85'ish
    The Rear main seal, intake and exhaust gaskets showed up today.
    The Valve cover gasket shows up tomorrow.
    So I get to start working on the engine tomorrow evening.
    Gaskets, seals, cleaning EGR and manifold.
    #24 Cosmo Tigato, Dec 9, 2019
  5. Cosmo Tigato
    201
    363
    Oregon, USA
    I use a steel brush attached to my drill to clean the bus bars.
    At about 16:20 it shows me cleaning bus bars.
    It's a old video, of a Gen 1 Battery
    A 5 part video series.
    #25 Cosmo Tigato, Dec 9, 2019
  6. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Good job.........!
    Mendel Leisk and Cosmo Tigato like this.
  7. Cosmo Tigato
    201
    363
    Oregon, USA
    Opened up the engine and it's SUPER clean on the inside!
    All new Gaskets
    New Rear Main Seal
    Fresh RTV
    I cleaned the EGR, Intake manifold and injectors.
    #27 Cosmo Tigato, Dec 14, 2019
  8. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Thanks!
  9. Cosmo Tigato
    201
    363
    Oregon, USA
    Here are some pictures of the old Engine.
    After I pulled the Intake Manifold
    Inside the old engine intake
    Look at all the nasty Milkshake in the Throttle body side of the intake manifold
    Yellow Jacket LOL
    The EGR pipe :(
    Coolant that came out of old Engine
    OMG Check out the PCV on the Intake manifold YUCK!!!
    Looks like the old owner tried to fix the head gasket with some kind of block sealer.... LAME!!!
    Definitely NOT going to reuse any of these parts LOL!!!
    Anyone want nasty engine parts? Ha!
  10. bisco
    52,863
    makes me want an ev even more :p
  11. Mendel Leisk
    42,355
    Flush the coolant passageways with 50/50 distilled water and white vinegar is supposed to dissolve away the stop-leak gunk. I guess do that when everything's back together, so you're getting the radiator, heater core, exhaust heat recovery and all the adjoining hoses flushed as well. Then I guess a straight water flush.
    And then, I would try to get some Toyota approved 100% coolant, even if it's the shorter life span stuff. You want to be able to fine-tune the mix to arrive at a 50% mix, which is pretty much impossible to do with residual water in the system and only 50/50 coolant mix.
    Experiment beforehand, get some of the globules, and drop them into a 50/50 water/vinegar mix, see what happens. It should dissolve them in short order.
    J1050, ETC(SS), dig4dirt and 2 others like this.
  12. Cosmo Tigato
    201
    363
    Oregon, USA
    Brilliant!!!!
    That is for sure the way to save the old radiator, heater core, exhaust recovery and hoses.
    Great advice
    Thanks a Bunch
    I think I am going to use my Electric pond water pump in a 5 gallon bucket with the above mix of distilled water and white vinegar, pump it in, in turn through all the hoses.
    Then Air blow all the passages Dry before adding the Super long life Toyota coolant that I bought.
    Thanks again Mendel.
    kc5dlo and Aaron Vitolins like this.
  13. Mendel Leisk
    42,355
    @cnc97 got that tip in an email from one of the stop-leak manufacturers. He tested it too, the globules in his test disolved within a minute. Do test it first with your gunk, hopefully the same result.
  14. Cosmo Tigato
    201
    363
    Oregon, USA
    This is the NASTY Juice that came out of the old engine drain plug.
    Got the Engine out.
    Much easier on a Gen 3 than a Gen 2
    Getting ready to clean the coolant passages.
    Clean Water at last.
    Yes it was gross
    Covered the Cat with a bag. :)
    Tomorrow I put in the New to me Engine.
    #34 Cosmo Tigato, Dec 20, 2019
  15. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    Was that the replacement engine that had that nasty stuff in it? Or the old one?
  16. Cosmo Tigato
    201
    363
    Oregon, USA
    The NASTY Stuff came out of the old engine that i just pulled out of the car.
    Scroll up a few posts back, to see pictures of the inside of the newer engine :)
  17. ASRDogman
    8,067
    4,089
    That's what I thought, just checking... :)
  18. Cosmo Tigato
    201
    363
    Oregon, USA
    Just drained the Trans Fluid YUCK!!!
    So Glad I got some new Juice to put in. "Toyota ATF WS"
    So much easier to do the trans with the engine out. Ha!
  19. ASRDogman
    8,067
    4,089
    I'll bet you didn't even have to rain the car did you? :)
  20. Cosmo Tigato
    201
    363
    Oregon, USA
    Adding the ATF WS
    Putting the Engine in
    Its so easy to work on Gen 3
