Bought a 2012 For $700
Discussion in 'Gen 3 Prius Main Forum' started by Cosmo Tigato, Dec 2, 2019.
  1. Cosmo Tigato
    Cosmo Tigato Active Member
    201
    363
    Oregon, USA
    Cleaning the Pistons, before I but on the new Head Gasket.
    Before and After
    Bay Stater and mikey_t like this.
  2. ASRDogman
    ASRDogman Senior Member
    8,053
    4,083
    Be careful you don't scratch up the cylinder while cleaning.
    Piston looks good. How are you cleaning it?
    Cosmo Tigato likes this.
  3. Cosmo Tigato
    201
    363
    Oregon, USA
    Bring the piston to the top, not touching the cylinder, Brake Clean and a Brass Brush and a paper towel. ;)
    Bay Stater and ASRDogman like this.
  4. Mendel Leisk
    42,300
    This is the first replacement engine, the one with massive coolant leak, and pristine looking head gasket? Did you somehow confirm it was a head gasket failure?
  5. Cosmo Tigato
    201
    363
    Oregon, USA
    This is the replacement engine that I got from the parts yard that made milk shake.
    Was it the head gasket........
    I will find out soon,
    Put the head on the gasket
    Torque it down to 36 foot lbs
    then 90 degrees
    then 45 degrees
    Now the cams
    And now the new PCV Valve
    Valve cover
    The Clean EGR
    Putting on the intake
    The throttle body
    Wiring harness stuffs
    And all the hoses and wires etc...
    #105 Cosmo Tigato, Jan 1, 2020
  6. Cosmo Tigato
    201
    363
    Oregon, USA
    Just Turned it on!!!!
    So far, so good...
    I let it run till the engine warmed up and shut off.
    then i floored the accelerator pedal and let it run for a couple minutes.
    I checked the oil for contamination, none!
    I will drive it around a few miles tomorrow, and keep checking the oil.
    --- I will put the wipers on in the morning.---
    #106 Cosmo Tigato, Jan 1, 2020
    RMB, Johnny Cakes, Bay Stater and 7 others like this.
  7. J1050
    J1050 New Member
    Georgia, USA
    I just read this entire thread and it's so inspiring - I hope everything works out for you tomorrow and thank you for all of your detailed progress posts! (y)
  8. douglasjre
    douglasjre Senior Member
    2,249
    751
    Null, NL
    How did it go w the yard?
  9. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I wished I was in the USA. That would have being what I'd be doing, seeing that I rebuilt almost these engines(gasoline, and the rest). Nice idea
  10. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Pls does JB welds have NY effect on the top gaskets, for instance, you want to removed the gasket someday, when you have such problems?
  11. ASRDogman
    8,053
    4,083
    I didn't use JB Weld on the head gasket. I used it on the head, by the valve on the valve cover side.
    I hope you've fixed the problem with the engine and that it will give you hundreds of thousands of good mileage!
    What country are you in?
  12. Cosmo Tigato
    201
    363
    Oregon, USA
    The guy at the Yard Finally sent me a eMail telling me his boss was going to look at the video I sent to them.
    So no good news yet
    mikey_t and The Critic like this.
  13. Cosmo Tigato
    201
    363
    Oregon, USA
    This morning I put on the Wipers
    And NOW to drive it around the town. :cool:
    #113 Cosmo Tigato, Jan 2, 2020
  14. Cosmo Tigato
    201
    363
    Oregon, USA
    Okay, So I drove 2012 Blue Car around.
    Various streets of 25, 30, 35, 45 and the Freeway at 70 MPH
    Drove for about 36 miles
    I put in power mode for the last 15 miles of that.
    So far so good.
    I checked the oil and it's happy!!! :rolleyes:
    RMB, Raytheeagle, J1050 and 6 others like this.
  15. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Lagos, Nigeria
  16. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Looks like it was your head gasket after all. Glad that your head gasket rebuild worked out. Hopefully the junk yard will compensate you. Thanks again for sharing your inspiring pictures. ;)
    Please keep us updated with your rebuilt replacement engine endeavors. :cool:
  17. ASRDogman
    8,053
    4,083
    I'm glad you have it running, and it's running like it should!
    A lot of work, but it always feels good when everything works correctly afterwards...
  18. Cosmo Tigato
    201
    363
    Oregon, USA
    Kind of funny.
    I bought the car with 208,XXX miles and a bad head gasket :eek: then decided (instead of doing a head gasket job:confused:) to put a engine in with less miles.:LOL:
    Well... Ended up doing a head gasket job on the new to me engine with 93.000 miles.o_O
    But, Hey I cleaned the Pistons, Valves (Combustion Chamber), Intake Manifold and EGR, Flushed out all the cooler lines, Radiator and Heater core and Changed the Transmission fluid with new Toyota ATF WS.(y)
    New Head Gasket, New Head Bolts, New Valve Cover Gasket, New Intake Manifold Gasket, New Exhaust Manifold Gasket,
    New rear main Seal and a partridge in a pear tree.
    #118 Cosmo Tigato, Jan 2, 2020
    RMB, Bay Stater, dig4dirt and 6 others like this.
  19. ASRDogman
    8,053
    4,083
    Did you by any chance reseat the valves and/or replace the valve guide seals?
  20. douglasjre
    2,249
    751
    Null, NL
    What did Toyota do to prevent head gasket failures going fwd
