Bought a 2012 For $700
Discussion in 'Gen 3 Prius Main Forum' started by Cosmo Tigato, Dec 2, 2019.
  1. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    Okay then... :)
    Well that is good for you! And you got a great deal!
    But your labor is not free. How much is YOUR time worth?
    It's just an expense you did not have to spend.
    Overall, you have a car that will last you a long time, and hopefully, trouble free.
    By the way, did you clean the egr circuit?
    Cosmo Tigato likes this.
  2. Cosmo Tigato
    Cosmo Tigato Active Member
    201
    363
    Oregon, USA
    Yes, I cleaned the EGR, it's fresh and happy.
    I did it in my free time that is why i said free labor :D
    Bay Stater and ASRDogman like this.
  3. ASRDogman
    8,066
    4,086
    Well, If you say $100 an hour for labor, that is at the least $1600 you didn't spend!
    You could get another Prius with a bad head gasket! :) Hopefully, with a good wind shield! :)
  4. Cosmo Tigato
    201
    363
    Oregon, USA
    Crazy....
    I drove it around a whole bunch. Then on Monday I drove it to work, and parked in my favorite spot.
    Was just sitting in my car, the engine started up and a bunch of white smoke poured out the exhaust.
    I was stunned...
    So I turned off the car and went in to work and talked with my co workers there at the Auto Parts Store
    and we were trying to figure out why it would do that...
    One guy suggested that the EGR cooler might be cracked and when it got hot enough and opened, it let some
    coolant in to the intake and the engine sucked it in and made sad steam.
    On the drive home there was NO vapor/white smoke.
    I pulled off the air intake, there was liquid under the throttle body.
    so I removed the EGR elbow pipe to the intake and there was a very small (about two drops) of liquid.
    Can the EGR leak coolant to the intake and cause this?
    #144 Cosmo Tigato, Jan 7, 2020
  5. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Is the coolant level stable? If you are not losing coolant, the smoke would not be antifreeze.
  6. Cosmo Tigato
    201
    363
    Oregon, USA
    What would it be?
    Hmmm. Beer?
    It's White Vapor out the tail pipe....
    Its NOT Blue Oil smoke
    The Oil was clean. No coolant in it this time.
    It only happened that one time and I turned off the engine
    so there was no measurable coolant loss.
    Has anyone else had or heard of a cracked EGR?
    #146 Cosmo Tigato, Jan 7, 2020
  7. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    How long did the cloud last? A few seconds, several minutes? At your parts store, do they have a coolant pressure test kit? If so, borrow it and pressurize the cooling system. If the pressure is steady, the cooling system is intact.
    After I put my engine back together, I drew a line in Sharpie on the coolant tank to indicate the level. I measured it every drive with a machinist scale. If temps and level are steady then it’s not coolant.
    I know this doesn't answer what it was, but it will show what it’s not.
    Johnny Cakes likes this.
  8. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    +1 on what cnc97 said. Knowing what its not helps determine what it is. Eliminating coolant as a factor would be a major clue.
    Also, like cnc97 says, how long did it last?
    Finally, are we talking thick white smoke or vapor like white smoke?
    With any luck (and you could use some luck!) its just condensation build-up within the exhaust system, which would be consistent with a slort lived event (burned out fairly quickly) and vapor like white smoke. Also, it is pretty cold in Oregon, which is prime condition for condensation build up.
    And it might be beer!
  9. Cosmo Tigato
    201
    363
    Oregon, USA
    Ha! :ROFLMAO: yeah ...
    The cloud was white and was constant.
    It lasted until I shut the car off. Then I restarted it and pressed the accelerator.
    and it bellowed out.
    After I left work. Drove home tried to recreate the scenario, But did not reoccur.
    There was a few drops of liquid in the EGR exit port Hmmmm
    So I know it was not Juice or beer or wine.:LOL::LOL::LOL:
    I just dumped out the liquid that was in the Intake manifold.
    It was about a 1/16 of a teaspoon
    It had a slight yellow hue witch leads me to believe its vaporized coolant that passed through the EGR
    and the steam lost the Pink color and picked up the the tarnish color of carbon from the EGR system.
    :eek:
    #149 Cosmo Tigato, Jan 7, 2020
  10. Cosmo Tigato
    201
    363
    Oregon, USA
    That is what I am now suspecting.
  11. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    When you put the head gasket on the motor you bought, did you pull the PCV plate off the side of the block and clean it out? If the engine only aspirated the junk caught in there, that would explain the short duration, and inability to recreate the episode. It also explains why your coolant and oil in the car now are clean and steady on level.
  12. Cosmo Tigato
    201
    363
    Oregon, USA
    Brilliant Idea!!!
    I will pop that plate of tomorrow morning. RTV's back on there right?
    Thanks
  13. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    This was my number one piston at 213k miles in July of 2018.
  14. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Not seeing a gasket listed on the Toyo parts website, so FIPG (sillycone)(deliberate misspelling)is a safe bet.
  15. Mendel Leisk
    42,343
    Yes, it's form-in-place type gasket. I believe Permatex Ultra Black* might sub for the spec. in attachement. Or Permatex Right Stuff? I think the latter cures quite fast though, pros and cons to that. For a small panel mostly pros?
    The technique the Gasket Master guys use for applying the fipg has been met with some derision here, but I 'm not so sure it's bad. The Repair Manual says to apply a continuous 3 mm diameter bead. Well good luck with that?
    The GM guy just goes along putting dabs, every 1/2" or so. Then he goes over it with a finger, and if he detects any thin spots, adds a little more.
    This I suspect is easier to do in practice, easier to get the right amount, uniformly, and ultimately just as effective.
    Maybe the main issue is: it's hard to describe such application technique, in the Repair Manual??
    * Permatex Ultra Black was recommended by Gasket Masters in their latest head gasket video, For use on the timing chain cover, fwiw.
    #155 Mendel Leisk, Jan 7, 2020
  16. Cosmo Tigato
    201
    363
    Oregon, USA
    Awesome!!!
    I have time in the morning before I go to work to play with Nautical car.
    I will be driving Barcelona tomorrow.
    Thanks
  17. Mendel Leisk
    42,343
    Guess I'm going overboard: I've never done ANY of this, and you've had the timing cover off umpteen times.
  18. Cosmo Tigato
    201
    363
    Oregon, USA
    I love working on Prius.... OMG it is so much fun!!!!!! :D
  19. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    The “stepped” thread on tip for the squeeze silicone starts with a .125” hole if you can get it to cut straight. That’s 3.175 mm bead. I think the “cheese whiz” can is a bit larger, .150. That’s a little over 4mm. But since it’s not 3mm, as the factory intended, it will never work right(heavy sarcasm intended). I’d rather have some excess, within reason, ooze out the side, then risk missing a spot.
    Cosmo Tigato and Mendel Leisk like this.
  20. Cosmo Tigato
    201
    363
    Oregon, USA
    Opened up the PCV Hatch
    Looks clean, just a little bit of 0w-20 in there.
