Bought a 2017 today
Discussion in 'Chevrolet Volt' started by billnchristy, Jul 16, 2016.
  1. bisco
    52,784
    sweeeeet!(y)
  2. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    I set up the charge schedule last night. It lets you tell it when you are leaving and will determine how to charge based on that. I like that it has a 7 day week schedule too so on weekends I have it ready by 10am while M-F it has to be by 6:30.
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    You'll want to check into pre-conditioning in the winter; a wonderful feature. Electrical heater use can use a lot of energy especially if the driver habitually "cranks the temp up" in the morning like my wife does. Pre-heating the cabin with wall power and using electric seats during the drive are much more efficient and more comfortable too but you'll need 240v to supply enough power to keep the battery full otherwise the car will draw on the battery to make up for using slower 120v.
  4. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    That sounds cool. We will put a 240v in soon, probably when my wife gets her bonus in September. Should be plenty of time in GA before it gets cold enough to pre-heat. We have the comfort package heated seats which supposedly work with the climate control to back off as things warm up, so that should help too.
  5. Ashlem
    Ashlem Senior Member
    754
    503
    WI
    2017 Chevy Volt
    The heated seats do work pretty nice in the Gen 1 Volt if you had that option in it. A heated steering wheel would've helped immensely too, so that'll come in very handy when it gets colder.
    On some days where it wasn't bitterly cold, I'd just crack the driver window and rear passenger window to create a little airflow to prevent the windshield from fogging up if I was going to attempt to drive without heat.
    Then I concluded that burning some gas in winter and using the heat is a much better option than freezing.
    m.wynn likes this.
  6. bisco
    52,784
    pip has the charge schedule thing too, very handy.
  7. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    Wife got her tint done today, she is UV allergic so it is a necessity. It looks nice.
    Ashlem likes this.
  8. bisco
    52,784
    love it! really looks sharp. i dislike the uv myself.(y)
  9. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    Now to get the front windshield and windows on mine done so she can cruise comfortably.
  10. bisco
    52,784
    what's the tint law there? did you get 3m?
  11. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    28% 3m Carbon
  12. bisco
    52,784
    nice. i should look into that.
  13. bwilson4web
    16,513
    Thumbs up on a 50 amp service line into an external, NEMA 14-50 plug. Just I went with a JuiceBox Pro 40, box on the right, which comes with a WiFi link, the small antenna, that reaches back to their service through my home WiFi:
    The picture reminds me I need to dress the cable. I needed a new utility service line so we upgraded from 100A to 200A service and added a transfer switch for a natural gas fired generator.
    Their server allows web and smart phone access to historical records. On July 21-22, 4.76 kWh was used which in Huntsville costing $0.476. After the initial charge, around 5 AM, pre-conditioning cooled down the cabin. The BMW i3-REx has a liquid cooled battery and actively maintains the battery temperature for optimum performance. This "overhead" is part of the price of an EV and separate from the miles per kilowatt hour or MPGe:
    Here is another web interface report: [​IMG]
    Again showing the normal recharging at the end of the day and on the right, pre-conditioning.
    One other aspect is called the I**R losses:
    Again from the web interface:
    • 30.1 amps
    • 7.224 kW rate of charge
    • 41 C (104 F) - North Alabama
    • 240 VAC - 50 A wiring minimizes the voltage drop
    There will always be electrical losses that an undersized wiring will increase. Traditional circuit breakers use a heating element to trip. The thickness of the wire also defines the running resistance. We pay for these losses, small as they may be, but a cost never the less.
    #33 bwilson4web, Aug 2, 2016
  14. bisco
    52,784
    you need to clean that up bob, looks a little like india.:p
  15. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    Our first fill up today because we drove to Greenville for a concert and their gas is about 20c per gallon cheaper. We didn't need it but even with only 3.5 gallons needed, that's a candy bar in savings!
    Ashlem and bisco like this.
  16. bisco
    52,784
    we always fill up in jersey and s.c.(y)
  17. El Dobro
    El Dobro A Member
    7,102
    3,282
    I fill up in NJ now and then, too. ;)
  18. bisco
    52,784
    if i lived there, i'd be driving a gas guzzler. you go, chris christy!(y)
    m.wynn likes this.
  19. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    Got our first report from the car/onstar today.
    588 electric miles using 233kw/hr. In Georgia that is about $21 bucks to run for a month. We used about 6 gallons of gas going up to Greenville SC, but haven't used a drop since and my wife will not use any for her daily commutes and various evening activities.
    Our Prius used to average about 44mpg with the traffic and stop and go here so by that account at $2.09 a gallon it would be $25.
    Switching to the electric car plan for our power company would drop that price to just over $3 a month. I have to investigate whether it is worth the increase in cost of peak time.
  20. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    This month we went 658 miles on 223 kwh. About $21 in electricity would be around $31 in gas for our previous Prius or $68 in my BMW.
    0 gas usage this entire month and the only weekend we took my X1 was to the shooting range because the volt cannot carry my arsenal.
    Ashlem and markabele like this.
