Bought a center console organizer tray
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Mambo Dave, Jan 20, 2020.
  1. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    52,534
    where? i like it!(y)
  3. Mambo Dave
    641
    307
    2019 Prius
    L Eco
  4. Mambo Dave
    641
    307
    2019 Prius
    L Eco
    I think I got it off of ebay. Import from Japan I believe.
  5. krmcg
    2,592
    2,393
    Whittier, CA
  6. Mambo Dave
    641
    307
    2019 Prius
    L Eco
    krmcg likes this.
  7. Hidyho
    Hidyho Senior Member
    2,699
    531
    2018 Prius
  8. krmcg
    2,592
    2,393
    Whittier, CA
  9. blane
    blane Carmudgeon
    98
    56
    NJ Suburb of NYC
    2019 Prius
    The link on that website indicates that the tray is NOT compatible with 2019 Prius hatchbacks. So it would probably might not have worked with Mambo Dave's (the OP's) 2019 vehicle.
    Should work with your 2016.
    krmcg likes this.
  10. bisco
    52,534
    i wonder what changed
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Does that replace the tray that comes with the car or does it fit inside it ?
    Looks like a job for the 3d printer to me (y)
  12. Mambo Dave
    641
    307
    2019 Prius
    L Eco
    So the one I ordered seemed to indicate 2016 through 2018 as well, IIRC. Little things don't usually change, but sellers often forget to update or researching listings from initial releases. I took the chance, and it works.
    I could not use the one with the red-outlined inserts only because I need that space underneath the tray for larger items. The best thing would be if the trays had molded-in little grab-handles, as I'm in and out of it often, and want to be able to lift the tray up, evenly and in some way level, to get to whatever I have stored underneath it.
    Perhaps I'll look into creating some center-grab-piece and try to super-glue it to the divider between the trays.
  13. krmcg
    2,592
    2,393
    Whittier, CA
    Took delivery of this tray today. Exceeded expectations! Not only does it fit pretty well into the center console, but it leaves plenty of room underneath it to store a couple of large items (glasses case and pen/pencil case). In addition, when the new deep tray is in place, the original small shallow tray fits directly on top of it and the lid closes without issue. So three layers of storage!
    #13 krmcg, Jan 23, 2020
