bought an 05 prius and found out the miles were rolled back
Discussion in 'Gen 2 Prius Technical Discussion' started by fullylaced1, Jun 8, 2020.
  1. fullylaced1
    fullylaced1 Junior Member
    31
    Los angeles
    As the title says, bought an '05 prius in pretty good shape with what I thought had 120,000 miles. pulled service history and found out the mileage is incorrect and probably has 230-250 thousand miles. I bought it for $3500 and I'm really down about it and there's nothing I can do because the seller won't answer my calls. I'm nervous to drive the car with that many miles on it. Do Prius's last longer than 250 thousand normally? what should I look out for? does drive well so far.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    I have a 2006 in my driveway with 349k miles. I'm currently driving a 2007 with 196k, my son's 2005 has 216k, my previous 2005 that was sold to my sons best friend has 299,999+. The baby of the group has 133k miles and feels new, lol.
    And they all drive great. I'm a DIY kinds guy and have the tools, equipment and manuals needed to maintain the cars. That can make a big difference, but I've been fortunate. They are reliable and rarely need any work.
    Meg&Bear and Aaron Vitolins like this.
  3. AzusaPrius
    AzusaPrius Senior Member
    2,137
    900
    All you need to do is go to the DMV and report the false odometer reading. Once they take notice then you have something to use in court to get compensation.
    Meg&Bear and Mendel Leisk like this.
  4. fullylaced1
    31
    Los angeles
    Car is considered “curbstoned.”
    I did get in touch with the original owner and confirmed that when he sold it to his mechanic it had 230,000 on the odometer. He sold it because the hybrid battery went out. So I’m assuming the hybrid battery was replaced along with a cluster that has low miles and then sold to me. Car has been running good but I do have a code P0852. Probably something happened when that cluster was changed? Hmm
  5. dolj
    dolj Senior Member
    8,194
    4,175
    Wellington, New Zealand
    That stinks, I hope at least the original CM (combination meter) failed and it had to be replaced.
    Possibly. Check:
    • Wire harness or connector to the switch
    • P position switch itself.
    If those check out it could be a fault in the HV control ECU but before rushing into replacing that, work through the inspection procedure for the fault.
    Inspection Procedure | DTC P0852 | Park/Neutral Switch Input Circuit High
    I hope that helps somewhat.
    Meg&Bear likes this.
  6. ydpplqbd
    ydpplqbd Active Member
    551
    253
    Get a small claims complaint for your local jurisdiction. Fillout the complaint and demand that the seller reimburse you for all your costs including: purchase price, sales tax, title fee, registration fee. Obviously, briefly explain that due to the fraud that you want your money back and return car to seller. File the complaint with the court.
    PS Also get form from your local police for citizens complaint for automotive odometer fraud (in some jurisdications this may be handled by the DMV). Complete the criminal complaint form but DO NOT file it yet. Instead, present this document when you are asked to mediate when the court case is being litigated as one more issue on the table to be resolved. Your POV should be: the two of you have multiple issues civil and criminal which all need to be resolved at the same time.
    PPS NEVER say to seller that he is going to jail (or that you are going file a criminal complaint) unless he gives you your money back (a quid-pro-quo). The quid-pro-quo element can get YOU a charge of extortion (a very serious criminal charge). Instead, your POV is the two of you (Buyer and Seller) have multiple issues civil and criminal which all need to be resolved at the same time.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,830
    Clearwater, Florida
    yeah that's the big drawback for the combo meter replacement to used car buyer. You can buy an instrument cluster for $100 that has any mileage you want on it. I bought one that was significantly lower mileage then what the car really has.
    If I were to buy a used G2 and the mileage smells fishy I would check the dash board screws that you need to remove and replace the combo meter and see if they are loose or missing (all screws in a factory toyota are usually very tight) that would make me suspicious then i would join toyota.com/owners forum and join that forum with that cars vin (on your insurance card) and see every time it saw a dealer for any kind of service and what the mileage was at that time.
    Carfax would help too.
  8. fullylaced1
    31
    Los angeles
    You're absolutely right, I guess I learned the hard way unfortunately.
  9. bisco
    51,079
    what does curbstoned mean?
    edthefox5 likes this.
  10. fullylaced1
    31
    Los angeles
    It’s when one buys a car off someone and then flips it without registering it or paying DMV fees. That causes the new owner to go through troubles because the bill of sale and title are still under the original person who sold it.
    Meg&Bear and bisco like this.
  11. bisco
    51,079
    thank you! that's a new one on me (y)
  12. edthefox5
    10,096
    4,830
    Clearwater, Florida
    No that's called jumping the title.
    My uncle Tommy got arrested for it 2 times. Next time it was jail the judge said he moved on to bigger and better grift and became a race track tout. Which is you prey on people preferably women who have never been to the track there drunk there idiots having the time of there life. You sidle up to them offer yourself as a race track pro and tell them to bet the horse he picks with there money of course. If it wins hes gets a percentage if it loses he moves on. Lots of rich old lady grift down here in sunny old Florida.
    Like all grifters he had a way with the bullshit.
    He was thrown out of and banned at many tracks.
    Relatives lol,.....
  13. fullylaced1
    31
    Los angeles
    Which oil weight do you use for your high mileage 2nd gens? don't know which was used with my high mileage prius prior to me getting it.
  14. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    I initially used Mobil 1 in 5W-30. The last several oil changes I used NAPA full synthetic 5W-30 and I currently have (5) 5 quart jugs of Super Tech full synthetic 5W-30 sitting on the shelf that I'll be using in my (very soon) upcoming oil changes. None of these oils have been the high mileage variety. Although I have never looked into it myself, I have read in many discussions that the high mileage oils have additional chemicals to make seals swell to reduce leakage. It was also discussed that once you go HM, you should never go back, as it will cause more leaks to appear. None of my cars currently have any leaks, so I've decided to stay away from the HM oil.
    Meg&Bear and fullylaced1 like this.
  15. Skibob
    Skibob Senior Member
    2,912
    1,501
    Northern California
    And that was entirely your fault. You pretty much got what you deserved by not being careful. Don't beat yourself up about it, I hear it happens all the time with Craiglist buyers. A Carfax report would have told you the mileage of each smog check in California. Guess 99 dollars for 6 Carfax reports was too much for you.
    "A single Carfax report costs $39.99. Three will cost you $59.99, and six sell for $99.99. Despite being the most expensive service, the Carfax report is the benchmark for all other vehicle history reports".
  16. fullylaced1
    31
    Los angeles
    100 percent correct
    #16 fullylaced1, Jun 20, 2020
