Bought salvage 2005 Prius with 35,000 miles
Discussion in 'Gen 2 Prius Main Forum' started by Wingding, Jan 27, 2011.
  1. bikr357
    bikr357 Plugged in Member
    63
    23
    16
    Houston, Texas
    Navigation is easy to determine just by visual inspection. Look at the MFD, 4 buttons on the left and 3 on the right = navigation. The other tip off is the DVD navigation unit located under the drivers seat.
    The the light assemblies are interchangeable, I know this because my car is also rebuilt and when it was first put together, halogens were put in until I asked them to be changed out to the original HID configuration. You could also choose to not reinstall the fog lights as a way to reduce the cost of the rebuild. Personally I like them and added mine back in myself. My rebuilder (Steve Woodruff, autobeyours.com) gave me the fog light units and I bought the lower grill trim and contributed an afternoon of labor (mostly for wiring trouble shooting and repairs and trim removal for access). You might consider using Steve as a resource for parts and advice as most of his rebuilds start out looking far worse than yours (like mine was… http://www.autobeyours.com/gifs/06 Prius Green 132/green 06 just in 005.jpg). However I think you will find front end parts hard to come by and new replacement parts will be the way to go.
    Good luck with your rebuild.
  2. Wingding
    Wingding Junior Member
    Montana/Michigan/Pennsylvania
    Uart,
    Ok.... I was a little concerned about heat build up but I have the Scan gauge hooked up and it was monitoring the water temperature. I only ran it for a minute or two....maybe 3 at most... But I was so concerned of overheating, I really never monitored any of the car gauges.. other than keeping my eye on the water temperature an the scan gauge. I think I shut her down between 130-140F... {3minutes} Im guessing the main monitor is in the middle of the dash... I'll have to read the "bentley" and see where exactly that reading is and if I need to navigate any to get to it... All new to the Prius here.... But I'll catch on..I got some basic understanding... I can/have pull diesel engine's apart and put it back together.. understand the entire system.... There is just a few "extra" things with the Prius... I pulled a Honda civic hybrid engine apart and back together..
    Going to be quite interesting.... I mean ... the Honda is not truly a "Hybrid" .... what I mean to say is it does not have 2 separate functions as in electric drive and gas drive mode... what it is ..is a "electrically assisted" vehicle.... The Prius on the other hand has 2 separate- electric and gas drives.
    The one thing For sure.... {And we will see} but I dont think the Prius can get the highway mileage the civic does.... Now in the city it's a whole different ballgame.... That honda civic is geared for long interstate highway mileage...The Prius should be superior in any stop and go traffic. This is all just a guess on my part as the way I see each of these cars hybrid functions...
    Hopefully I will be able to put these theories to a test SOON!
  3. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Hi wingding, the SOC monitor is part of the "Energy Monitor" screen on the multifunction display (see attachment).
    The attached image shows what this display should look like when the battery is being charged from the engine (engine idling and transmission in park).
    Notice the battery icon which is showing just two purple bars, this indicates a somewhat low state of charge. It's an 8 bar display. When it show only one or two bars (low charge level) it's purple, with 3 through to 6 bars it displays in blue (normal charge level), with 7 or 8 bars it displays in green (high charge level).
    If yours shows purple bars (or even worse no bars at all) then I'd definitely try running it, even if just a few minutes at a time, to build it up to at least 4 bars.
    BTW. It is important that the transmission has to be in "P" for it to charge while the car is stationary.
  4. Wingding
    Bilk357...
    hmmmmm.... Im in the house right now but I did notice a large "box like" unit under the passenger seat.. at quick glance I thought it looked like some audio amplifier.. Geeze I need to walk out there and just see if i got the double row {seven total buttons on the MFD.. I'll be back in a minute...
  5. Wingding
    Thanks so much Uart !
    I will "Bundle up" and try a start also while checking out if I have the navigation option. It's snowing pretty good out there... Well at least when I start it without antifeeze, it's pretty darn cold out there.
    I will say that the coolant line to the radiator {Im guessing Inverter} is functional and has no leaks through whatever part of the radiator it goes.. Im guessing it's a separate tank within the radiator... does not look like it's been breached...
    Ok, before I go... Is there ANY REASON I should NOT start a prius and run it for a short while without any COOLANT in the system?
    Anyone out there think that is a bad IDEA?
    And If it's ok for a short while, at what temp reading off the scan gauge should I shut her down??
    180? 190? 170? Thanks!
  6. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    I don't think it is a good to run without coolant? May be hard on the pump? ICE will heat up within sec.. I can under-stand were your coming from with your rad. having to be replaced. Is there a chance of the water freezing this time of year. You could put a heat lamp under there if it gets cold? Hal
  7. Patrick Wong
    18,210
    6,510
    Yes, I think that is a bad idea because the engine head and block are made of aluminum and probably won't withstand abuse of that sort. Since no engine coolant is circulating, it will take a considerable while for the engine temp sensor mounted in the head to register increased temp. The heat produced by the engine block will not be dissipated and circulated via the flow of coolant.
  8. bikr357
    63
    23
    16
    Houston, Texas
    Very bad idea. Coolant is why you have little if any mechanical damage, without it you will likely damage the inverter before you do damage to the ICE. They are equally costly to replace. Patrick is also correct, with out the coolant the temp reading will likely be incorrect.
  9. M8s
    M8s Retired and Lovin' It
    614
    113
    33
    Colorado and Arizona
    Couldn't you just add water and run the engine, then drain it when your done? After all, (a) you can drain the water into the ground, and (b) you only need to charge the traction battery once every two months or so.
    Edited to add:
    If the radiator leaks, you could just bypass the radiator, fill it with water and run it until the engine gets warm. Then dump the water out until you are need to charge the battery again.
  10. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Ok, from this post I assumed that you had water in it, even though the entire cooling system wasn't completely functional. If there's not any water at all in it then that's a different thing, don't run it like that! (though btw, I don't think the 2 minutes that you did already run it would have hurt it, the metal parts will easily absorb 2 minutes heat from a cold start).
    But you should try to get some water into it so that you can at least run it for 3 to 4 minutes at a time to get some charge on the traction battery. It will only take 10 minutes running (at idle) to get a safe charge level on that battery (not a full charge but enough to keep it out of danger). So even if you have to do it in a number of stages it's worth doing. (BTW it will take a bit longer in stages because for about the first minute it wont do much charging, but after about a minute, with the car in park, it will start giving the battery a nice charge).
    If it's been sitting for two years then it could be critically low. It wouldn't be the first case of a perfectly good battery ruined by allowing it to stand too long uncharged.
  11. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    38
    Santa Fe, NM
    I recovered a Honda IMA battery (NiMH cylindrical like NWH10) that had sat for 10 years. Just took the usual cyclical reconditioning.
    I will be very interested to see if Wingding has any problems. Definitely it would be advisable to get the battery up to 6 bars or so before trying drive the car. If only at 1 or 2 bars, I think there is risk of taking the weakest cell to zero under moderate to heavy assist.
  12. Wingding
    Well.... Im chomping at the bit to start it up and see where that HV battery charge is at. After 2 and a half years.... it probably cannot be very good...
    But it did start the car.
    However, with a radiator coming.. and patience being a key here..... I will heed well the advice and wait till I have it installed...
    I understand there will be a issue with the Coolant for the inverter.. Apparently you just dont 'fill and go"..... It seems the air will mix and possibly cause a non-flow situation unless it is bleed out... There is a procedure for it but I only briefly skimmed over that section...
    Anybody been there with adding and bleeding the air from the inverter Coolant?
    Can that Coolant for the Inverter be bought at a local auto shop. Or is this a "STRICTLY TOYOTA COOLANT ONLY" ...... Im not sure quite what this pink liquid is.... almost looks like Pink RV antifreeze you place in the traps and inject in the diesel furnaces that heat water to keep them from freezing and breaking ... Anyone know exactly what to call that stuff... The "Bentley" is not doing a very good job of describing exactly what that is.
    OH. and to answer a question from above, I have a # 7 package. I can see that there is navigation in this car. HAD NO IDEA..Must be a pretty cool thing! Do you need some sort of annual subscription to make that work? Or is that kinda like my "Co-Pilot" {a software you download on your laptop} and a USB plug in tracker... The only thing is a big laptop is difficult to setup in a small car.This will be a treat if it works the same!
  13. seilerts
    3,326
    1,518
    38
    Santa Fe, NM
    Coolant fill is a piece of cake with an AirLift. The inverter cooling loop takes less than a minute; the engine loop will take longer due to the thermos. My guess is that it will save you two hours by having the AirLift tool. The coolant you need is Toyota Super Long Life Coolant (SLLC). You can only get that from a dealer parts counter, unfortunately. Perhaps by calling around and saying that you need 3 gallons, you might be able to get a discount.
  14. Hal W
    Hal W New Member
    872
    53
    Hi seilerts:
    What is a AirLift thing. Are they expensive? Is it a automotive item?
    Cheers,
    Hal
  15. Wingding
    Guess I'll have to check up that "Air lift" tool.
    Boy.... Im probably over 150 miles from the nearest Toyota dealer... Maybe a internet sale is in order here.
    Im telling you a Prius in a Auto Salvage yard is about as rare as hen's teeth....
    I'll find one though......
  16. Wingding
    Uart,
    I have a unusual situation. I have 6 bars !!!! BUT they are all Purple, Not Blue.They were the same color as your example of 2 purple bars but there are 6 of them.
    Whats up with that?
    Is it possible to have 6 bars after the car has been out of commission for 2 1/2 years?
  17. donalmilligan089
    239
    22
    virginia usa
    I can help. I also rebuilt a 2005 with front end damage. The traction battery was still good but I depleted it beyond repair by trying to start it when the mass air thingy was damaged. Don't keep trying to start it until all else is repaired,. If you find that you need a traction (hv) replacement There are many available through ebay . I had AUYOBEYOURS from southern Indiana repair my air mass thingy and put in a salvage battery as well as put on front bumper guard( mine) and straighten front frame. Total cost $1,950 I had hood fenders rad. grill headlights and much damage. My total repair was c.4,000 $
  18. Wingding
    Well.... I got a lead ...... But I'd be going a different direction. I found a Auto Salvage yard with a 2005 Prius but they want to sell me the whole front clip.. This includes both Fenders and all the Liners - Hood - Radiator- Complete Radiator support frame- Condensor- Fan Shroud- Both HID Lights complete- The complete Bumper Assembly- all the Splash Shields and Guards- About the only thing missing is the Entire air assembly {Ait filter box and the entire resonator assembly.}
    Now the kicker ... same color as mine... Now the killer... $2600 How bad is that ?
    I was originally going to just make it "road worthy" and not concentrate to much on Cosmetic's... If i do this it would be like restoring it and it would be unrecognizable as a one time salvage wreck....
    How does somewhere around $7800 to $8300 sound to put a 2005 Prius #7 with 35,000 miles on it back on the road again...... BUT looking like a new car? Instead of a beater??
    Beater probably comes in at $6400 to $6900 to make it road worthy...
  19. seilerts
    3,326
    1,518
    38
    Santa Fe, NM
    AirLift by UView http://www.amazon.com/UView-550000-Airlift-Cooling-Checker/dp/B0002SRH5G
    $2600 and it is the same color? You might be hard pressed to beat that by buying components separately. Paint is expensive.
  20. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Wow I've never heard of that happening before. :eek:
    Are you certain that they're not blue? Some people describe their colors slightly differently depending on light they're viewing it in. Also, perhaps you were expecting the bottom two bars to be a different color to the next four? It doesn't work like that, all bars are the same color. That is, they're either all purple, or all blue, or all green, depending on how many are showing. Take a look at the attached images to see blue and green SOC examples.
    I don't know, but if it is six then you're going really well. Six bars is the "nominal" charge level that the car tries to maintain.
