Bragging Rights !!!!!!!
Discussion in 'Prime Main Forum (2017-2022)' started by huskers, Nov 1, 2016.
  1. lroki
    lroki Member
    83
    103
    Sacramento, CA
    I don't notice it anymore.....
  2. lroki
    lroki Member
    83
    103
    Sacramento, CA
    You could estimate the cost. The battery is about 8kW. Mine has been requiring less than 7kW to recharge, even though it had been "fully" depleted. So you can estimate on the higher side: Cost to charge per month = 8kW × number of charges per month × cost per kW.
    52,843
    notice what?
    lroki likes this.
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Could an owner please measure the vertical depth of the underfloor slot in the back of the cargo area please?
    Thanks.
  5. WimN
    WimN Junior Member
    37
    36
    Netherlands
    About loading the battery, keep in mind you cannot use the full 8.8kWh capacity. With my PIP which has a battery of 4.4 kWh the maximum I can load is 2.6 kWh. That is about 60%, so for the 8,8 kWh battery it is about 5.2 kWh. To prolong the battery life it is not discharged lower than 20% and charged more than 80%. So when you display shows 'empty' there is still 20% charge left and when the display shows 'Full' it is actually charged to 80%.
  6. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Anyone have an aftermarket gauge to see the Prius Prime values, beyond those basic rules for lithium?
    The thresholds for Prius PHV are 18% and 85%.
  7. surfinjoe
    surfinjoe Member
    58
    39
    san clemente
    Picked her up....Titanium Glow.....on a tech high at the moment.......
    Dianne at Carson was awesome!
  8. Edward.Howard
    Edward.Howard Junior Member
    Charleston, SC
    Could you let me know how long the charging cable is that comes with the car? I can't find it in the digital manual or on the website. Beautiful Car!!
  9. Lee Jay
    5,850
    4,036
    I thought the cable was 24 feet, but that could be for the previous generation.
    A properly specified extension cord is perfectly fine regardless of what the manual says.
  10. lroki
    lroki Member
    83
    103
    Sacramento, CA
    I just thought about something that I need to share with California owners of the Prime: On applying for the California rebate, I haven't been able to progress past the page that requires the VIN. I receive this error:
    The VIN entered on your application does not indicate the vehicle is a Toyota Prius Prime. Please verify your VIN, selected vehicle model and trim. If issues persist, please contact CVRP staff at 866.984.2532 to continue.
    I've sent an email to "CRVP" and received a reply indicating that:
    Our website is currently experiencing issues with applications for the Toyota Prius Prime. As soon as this issue has been resolved we will notify you. We apologize for the inconvenience.
    iwdwebman likes this.
  11. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    Is this the state $1500?
  12. ArtVanDelay23
    ArtVanDelay23 Member
    61
    62
    ny
    I've been noticing that blind spot monitoring is not accurate at identifying motorcycles
  13. lroki
    lroki Member
    83
    103
    Sacramento, CA
    Yes.
  14. ttait
    ttait Active Member
    273
    163
    Southern California
    I had the same problem today, left a voicemail. We'll see what happens.
  15. huskers
    huskers Senior Member
    2,549
    2,488
    Nebraska
  16. lroki
    lroki Member
    83
    103
    Sacramento, CA
    When I asked whether I should retry periodically to resubmit my application, I received the following:
    If you would like to do so, you can. But to save you time, I would suggest waiting until you hear from us. We are still waiting to hear back on this issue and will be emailing all Prius Prime customers.
  17. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    No need to get all fancy like that, I just held it in front of the display and punched it. LOL.
    On another hybrid that has had this start up feature for years, you can turn the volume dial while it's playing to adjust the level to your preference for future starts/stops.
  18. Trollbait
    12,822
    The manual says that because many don't know what a proper extension cord should be, and would just grab whatever they have at hand.:eek:
    surfinjoe likes this.
  19. bisco
    52,843
    we've been using extension cords with the pip for 5 years, without issue. okay, i'm not counting the house that burned down, because the cause was never determined.:cool:
    surfinjoe, Insirt and lroki like this.
  20. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    What, you don't like fires?
    Funny, typed it while Bisco was posting and only read his after I posted. Carma.
