Bragging Rights !!!!!!!
Discussion in 'Prime Main Forum (2017-2022)' started by huskers, Nov 1, 2016.
  1. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I just found something else that's interesting. My estimated peak power in Ev mode (includes mass, rolling friction and aero drag) is 56kW. That's suspiciously close to the 53kW of MG2 and suspiciously far from the 76kW of dual-motor mode.
    I wonder if it was operating in single-motor mode for some reason such as battery or motor temperature or traction. The video shows plenty of battery charge so that shouldn't be it.
  2. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    While the combined power of the two motors is 76 kW, the max power of the dual motor mode is limited by the battery power which is, according to Toyota publications, 68 kW.
    #402 giora, Nov 21, 2016
  3. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    Also remember that without changing gears, MG2 is not capable of delivering max power at every speed. MG1 obviously helps in the low speed region, but at higher speed it doesn't add any more power.
    Even if they limit the battery (inverter actually) output to around 50 kW, it still makes sense to couple MG1 and MG2 together, to get more power on the wheels at different speeds.
  4. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    Can anybody look into the technical data list of the manual what it says about max. speed ?
    According to Toyota.Netherlands it has gone down to just 100 mph opposed to the regular Prius which can go up to 112 mph !?
  5. Lee Jay
    5,850
    4,036
    Well, the chief engineer said that Ev mode could produce 76kW peak. This run produced an estimated 56kW peak, which isn't very close to either 76kW or 68kW.
  6. lroki
    lroki Member
    83
    103
    Sacramento, CA
    Sorry that I forgot to stop before starting the second run. I goes I was a little anxious around on an on ramp, despite there not being any traffic. There is reason forecast here off and on for the next few days. Ilk try to do this again when it's dry, if folks are interested.
  7. lroki
    lroki Member
    83
    103
    Sacramento, CA
    There are streets in SoCal with 60 mph limits, so the acceleration there is appreciated when getting into those streets.
    I don't know where you are, but here in California we have metered on ramps. But they are working only during traffic so even though you're stopped at a light, you don't need a lot of get-up-and-go.
    I do agree with you that the acceleration in the Prime is adequate. It's much better that my old Gen2 Prius and I never had an issue with that car.
  8. bisco
    52,843
    you can generally find someones location by looking below the avatar, unless they've opted not to include it.
  9. lroki
    lroki Member
    83
    103
    Sacramento, CA
    One of my favorite quotes is appropriate here: "If you don't look, you won't find it".
  10. civicdriver06
    797
    324
    Germany
    I went through the US manual of the Prime and either I missed it or i can't find a word about max. speed nor ground clearance !?
    Shouldn't that kind of info be in there ?
    #410 civicdriver06, Nov 21, 2016
  11. Lee Jay
    5,850
    4,036
    Maybe because it has no relevance to anything?
  12. Lee Jay
    5,850
    4,036
    Assuming the car weighed 1650kg with one person and a tank of gas, I get 57kW for Ev mode and 77kW for Hv mode. Considering the ratings are 76kW and 90kW, something isn't right.
    If I use 1950kg, I get 68kW in Ev mode (the supposed rating of the battery) and 90kW in Hv mode (the supposed rating of the combined gas/electric system).
    To Iroki (the person who generated the videos), did you have a fully-loaded car when these videos were taken?
  13. lroki
    lroki Member
    83
    103
    Sacramento, CA
    Lee Jay, conditions were as you've stated: Just me in the car, nothing else. The deviation though is that my gas tank was only 3/4 full, according to the gauge.
  14. lroki
    lroki Member
    83
    103
    Sacramento, CA
    I just received the following email regarding the California Clean Vehicle Rebate Program. I made an inquiry when I wasn't able to complete an application.
    Thank you for your interest in the Clean Vehicle Rebate Project (CVRP). I am happy to inform you that our website has been updated and you should now be able to submit an application for your Prius Prime. You can apply by going to cleanvehiclerebate.org.
  15. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Would be nice if someone can check and report the operation of the new Charge Mode feature as it is a new feature.
    If my PiP had this 'forced charge' feature I would have checked it as follows:
    Driving on a flat highway at constant speed (anything between 50 and 60 mph but constant) in HV mode after EV miles have depleted and engine is warmed-up completely.
    Resetting 'trip meter' and after a minute or so - noting the reported consumption (mpg) for this speed.
    Switching to Charge mode (in the Prime - pressing and holding the EV/HV button for 3 seconds or so?), and resetting the trip meter again.
    Keeping the same speed as above, waiting until some EV miles have accumulated, then checking the 'accumulation rate' (EV distance added per unit of time).
    Lastly, noting the new consumption (mpg).
    From these, charge rate (power), charge time (to 80%) and gallons of gas needed for charging can be calculated.
  16. Andrew May
    Andrew May New Member
    Orange County, CA
    Thanks. Found it. Settings > General > Begin/End sound > off
  17. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    Anyone get a blue one yet? Would love to see several photos of that chameleon color.
    ruby and priuscatprimeguy like this.
  18. lroki
    lroki Member
    83
    103
    Sacramento, CA
    I just found out that my electric utility (Sacramento Municipal Utility District) has a program for plug-in vehicles. They offer a $300 rebate as a "Charge FREE for a year" program and a "PEV Pricing Plan" that provides a 1.5 cent per kWh discount between midnight and 6 a.m. This means that my electric rate will be 7.17 cents per kWh during that period. I don't have records of the amount of current use at home to recharge, but I can calculate a cost for me to commute from work to home using the ChargePoint information I recieve from the chargers at work: Based on the charging records, I have averaged a usage of 6.35 kWh on 6 days of commuting over a distance that is almost exactly 25.5 miles each way. I have made it all the way on battery except for one morning when I made a short errand that added a couple of miles and fully depleted the battery. So, 6.35 kWh per charge x $0.0717 per kWh = a whopping $0.455 per charge. The discounted price saves me $0.10 per charge. The rebate actually compensates me for 659 full recharges at the discounted rate.
    Here's the SMUD website for Sacramento area folks: https://goo.gl/C4J8je
    priuscatprimeguy and bisco like this.
  19. Lee Jay
    5,850
    4,036
    I don't get it then. Your Prime either weighs about 700 pounds more than it should or it's producing a lot less power than it's rated to produce. I've checked my math (I found an error, but it was in the fourth decimal place) several times.
  20. lroki
    lroki Member
    83
    103
    Sacramento, CA
    I'll collect another dataset on dry pavement. But it may be a few days as we're forecast to get a series of storms over the next week or so. I'll try to get it as soon as it's dry enough.
    Could it be temperature related? I can't recall the exact temperature that morning, but the lows have been in the low 40s for awhile and it was at about 4:30 am or so during that run.
