Bragging Rights !!!!!!!
Discussion in 'Prime Main Forum (2017-2022)' started by huskers, Nov 1, 2016.
  1. Prodigyplace
    12,708
    11,847
    Central Virginia
    On my 2017 Prius, the DRCC seems to be overly sensitive to brake lights, braking harder than is needs to if it just sees brake lights, sometimes in the next lane!
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Sounds like anecdotal evidence. I hadn't heard of any visual aspect to DRCC. In fact, the "R" stands for radar.
  3. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    With DRCC on, it'll stop on its own but it won't restart without hitting resume.
    "When the vehicle ahead of you stops, your vehicle will also stop (vehicle is stopped by system control). After the vehicle ahead starts off, pushing the cruise control lever up or depressing the accelerator pedal will resume follow-up cruising." - OM Page 395
    Insirt and iwdwebman like this.
  4. iwdwebman
    iwdwebman Junior Member
    28
    67
    US
    According to toyota's site it uses both a radar and a camera.
    Toyota Global Site | Technology File
    john1701a likes this.
  5. john1701a
    12,840
    5,312
    58
    Nice info! Thanks for the link.
    It only refers to the camera for acceleration though.
  6. iwdwebman
    28
    67
    US
    True. But I would bet its used for deceleration as well. It would need to know if what the radar sees is in front or to the side. Not sure what kind of radar it uses but I'm thinking it's a point source which would need camera input to know enough data for which lane is occupied.
  7. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    The description of -actual- operation sounds just like the way the GIII DRCC works. The radar can get reflections from the next lane, though it's rare. While it may seem overly conservative, that is "a good thing" (tm) when on the road. ;)
  8. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    Does the new gas injected heat pump deliver instant heat ?
  9. Jasonheng15
    Jasonheng15 Lowered Prime
    65
    77
    Heater works without the engine as long as the battery has sufficient charge. It works almost as fast as a regular heater. Been parked outside in these mid 30 degree mornings no problem. Heated seats are also a plus
  10. Lee Jay
    5,850
    4,036
    What does that mean? My conventional cars can take 3-10 minutes to start producing heat while my 2004 does it in 30 seconds because of the thermos. I would expect a heat pump to start producing heat within 20-30 seconds.
  11. Jasonheng15
    65
    77
    My 07 took at least 4 to 5 minutes to produce any real heat from a cold start and i live in Cali. The Prime produces a good amount a heat within the same amount of time but without the engine kicking on. It prioritizes battery consumption in most situations. The point is it doesnt need the engine to produce heat unlike the regular hatchbacks. I love it.
  12. Lee Jay
    5,850
    4,036
    The only way my 04 takes that long is if it hasn't been run in several days. I get heat from the vents before the Ev-dominated warm up period ends, and that's in Colorado.
  13. civicdriver06
    797
    324
    Germany
    So would I !
    10 min of pre-heat will not do the job if it takes 4-5 min to get the heat pump producing warm air !
    A bit disappointing.
    I was expecting better performance than that .
    Merged. Use multi quote
    That's interesting!
    I didn't know that .
    I wounder why they took it away in gen 3. .
    Sounds great to get warm air within 30 seconds .
    We didn't get that for gen. 2 in Germany.
  14. Jasonheng15
    65
    77
    Dragon Rider likes this.
  15. Lee Jay
    5,850
    4,036
    40 degrees isn't even heater weather. That's light jacket weather. It's commonly in the teens when I leave for work.
    Trollbait and Prius Maximus like this.
  16. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    I was out riding my bicycle in that weather this morning. Felt fine except for my hands that turned into painful popsicles.
    I want either warmer handlebars or better gloves.
  17. Eric Maple
    Eric Maple Junior Member
    27
    28
    Mattoon IL
    Mine came to the dealership last night. What a great time to show up on the day before Thanksgiving!! So I guess this is the 306th one to be made. 20161124_163137.jpg 20161124_163137.jpg
    ruby, Dragon Rider, Insirt and 7 others like this.
  18. bisco
    52,703
    congrats!(y)
  19. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    I like the white. Congrats
  20. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    Yes, CONGRATS !!!!! Why is there is blue cloth over the display panel?
