Brake, ABS, and skid lights all came on
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by bobbintb, Aug 10, 2024.
  1. rjparker
    rjparker Tu Humilde Sirviente
    11,031
    6,919
    Texas Hill Country
    You or a shop need to find the leak
    #21 rjparker, Sep 22, 2024
  2. ChapmanF
    18,970
    How much lower is "much lower"? I'm seeing a lot of posts going with the thought that there must be an external leak, probably all because of this sentence. But the fluid level does normally look different depending on whether the system is zeroed down or not at the time that you check, and sometimes people don't take that into account.
  3. pairoPriuii
    pairoPriuii Junior Member
    lower Alabama
    There are two different types of leaks when it comes to a 3rd gen Prius, external and internal. External is generally easy to find by virtual of a wet spot in the vicinity of the leak. The second, less obvious kind is internal where the booster system leaks pressure inside the sealed system. The fluid level in the reservoir doesn’t go down but the electric pump can be heard running more and more frequently and for longer and longer periods of time. This is the more expensive kind to fix. It can be a DIY proposition but that requires investment in a decent OBD2 reader compatible with hybrids and capable of two-way communication for the bleeding process.
    Tim Jones likes this.
  4. Tim Jones
    Tim Jones Senior Member
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    Head Gasket, Water Pump and Inverter next.
  5. bobbintb
    bobbintb Junior Member
    30
    Lol, weirdly the lights randomly went off a while ago and stayed that way for a few days. The brakes were much more sensitive at that point, then the lights eventually came back on.
