BRAKE- ABS- VSC- warning lights on-NO CODES on code reader-What could be the problem?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Sep 13, 2024.
  1. ski.dive
    ski.dive Active Member
    967
    247
    Hutchinson Island,FL. Mt. Snow,VT
  2. Tombukt2
    Tombukt2 Senior Member
    13,859
    2,517
    Durham NC
    Your code reader is not capable of reading the ABS codes that you need to be seeing more than likely just my guess here funny thing is though my old junkie and over 3100 something the base model $40 scanner reads ABS codes and codes that it can't even identify It puts the number up and says something about it can identify the code The code was written after the scanner but yet the scanner knew it was coming so it's programmed to read the code it just doesn't know what it is completely weird.
    rogerdpack likes this.
    52,854
    autel maxi 200, say no more
  4. ChapmanF
    19,020
    Brian1954 likes this.
  5. Brian1954
    Brian1954 Senior Member
    2,679
    1,071
    South Central PA, USA
    Your odds of guessing the problem is 1 in 200 or more, so you need to read the trouble codes associated with the warning lights. Like others have already mentioned, your scan tool is not good enough to read your car's trouble codes. Read the first few posts in this thread and them jump down to post #37: https://priuschat.com/index.php?posts/3246758
