Brake, ABS,VSC, (!) warning lights
Discussion in 'Gen 4 Prius Main Forum' started by Jason z, Mar 13, 2023.
  1. Jason z
    Jason z Junior Member
    Two Eco
    I changed my brakes on my 2016 prius. When I push in caliber it causes the Brake, ABS,VSC, (!) warning lights to come on when started. Last time I had to take it to dealer and they turned it off with laptop. Is there any way I can do this from home to save money?
  2. ChapmanF
    15,859
    You should find out why they're on before turning them off. (After, you can't find out.)
    If you don't have a scan tool to find out, you don't need one; see this page:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    Edit: hmm, wait, your profile says a Gen 2 but you seem to be talking about a Gen 4. The blink codes might have gone away in Gen 4. If so, it'll take a scan tool.
  3. Elektroingenieur
    2,515
    3,264
    Three Touring
    Correct; at least, the Repair Manual (more info) doesn’t mention any way to read diagnostic trouble codes from the brake system other than using a Toyota Techstream diagnostic system or equivalent, and the two-digit codes are no longer listed.
  4. ChapmanF
    15,859
    End of an era. Another reason to try to nurse my Gen 3 along for as long as I can. I like alternatives.
    Speaking of alternatives, the Gen 1 repair manual said the body ECU would blink codes out on the door-ajar warning light ... but if it couldn't communicate with the combination meter to do that, it would blink the codes on the dome light instead. :)
