Brake accumulator pump (whirring): how much is too much?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Schofer, Jan 21, 2017.
  1. Schofer
    Schofer Junior Member
    SoCal
    The familiar whirring sound when I open the car door is becoming much more frequent on my 2010 Prius III. From other posts in this forum, I'm pretty sure it is the brake accumulator pump adding pressure to the brake system.
    The pump used to go on once in a while, mainly when I opened the car door to get in. Now I hear it frequently when I'm driving around, sometimes every 2-3 times I hit the brakes.
    NOTE: The car has 41K miles. I checked today and the brake fluid seems full. My VIN doesn't seem to be part of the 2010 brake recall.
    NOTE 2: The whirring seems to have gotten worse pretty recently, just in the last few weeks... though I wasn't paying very close attention to it, so it might have gotten worse more gradually than that.
    Does anyone else experience this? How often does your pump activate? I'm wondering if this is "normal", or an indication that I should get the car checked out...
    Advice would be appreciated!
    schofer
    #1 Schofer, Jan 21, 2017
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    559
    Tucson, AZ
    2021 Prius
    Since there isn't a reliable vacuum source, periodic functioning of the brake accumulator pump is the only way the power assist braking can work. Maybe you are just listening for it now and hear it more often. On my car it runs about every third use of the brake pedal. And always when opening the driver side door. The longer it sits between uses the longer that pump will run when you open the door, so there is some leak-down (pressure loss) with time. There could be a problem if it seems to be running "more than usual", whatever that might mean. Don't know if it will throw a code.
  3. Mitchjorg
    Mitchjorg New Member
    Irvine
    I'm having the same issue... mine activates pretty much every 5-10 seconds no matter what I'm doing, and it is LOUD.
    Here's a vid to show:
    I also get chirping and creaking sounds when I apply the brakes.
    Are my brakes about to completely fail, or am I just gonna have to deal with this?
  4. JC91006
    16,939
    8,647
    Bring it to the dealer, maybe they'll fix it for free
    SM-N900P ?
  5. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    OP, that definitely is abnormal behavior of the accumulator pump.
    The brake accumulator/booster on our 2011 is making some noises when hard brake pressure is applied, and also when almost at a full stop, then further pressure is applied to the brake pedal. Sounds like groaning/low frequency honking sound.
  6. Patrick Wong
    18,213
    6,530
    If your Prius is 2G, the brake actuator pump is covered under extended warranty to at least Dec 2017. My daughter's 2007 (102K miles) recently had similar symptoms as you described, the skid control ECU had logged a fault code, and no warning lights were on. I took the car to the local Toyota dealer svc dept and my findings were confirmed, so the actuator pump was replaced at no charge.
  7. Mendel Leisk
    42,373
    Brake fluid level will gradually move down, as pads wear. Having said that, there's likely not that much pad wear yet. But bottom line: brake fluid normally does NOT need to be topped up.
    I'm not sure about "doesn't seem to be part of the 2010 brake recall": did you check with the dealership?
  8. Michael Reeves
    Michael Reeves New Member
    San Antonio
    Bleed the brakes. Over time the ABS actuator uses a diaphragm that is actuated with a nitrogen cylinder. Eventually, it will leach nitrogen into the brake lines. This is why the increased pump frequency goes along with the barking sound (nitrogen bubbles). The pressure in the lines is not enough and the actuator pump must activate more frequently. Bleed the brakes before the actuator pump fails and it needs replacing. If you bleed the brakes and the barking and increased pump frequency return quickly, like a few weeks, the diaphragm is worn and leaking too much nitrogen and needs to be replaced with a properly working actuator.
  9. Mendel Leisk
    42,373
    Is that a big ticket item, or? We had this recall, I'm not sure exactly what it entailed:
  10. ChapmanF
    19,055
    Pretty sure it's a four-figure ticket. It's good to keep the differences between generations straight though. This thread started out with a Gen 3 question; Micheal Reeves posted a Gen 2 answer about the "actuator".
    For Gen 2, that's ok, as the pump/accumulator and actuator are combined in a single unit anyway, so yes, in a Gen 2, if your accumulator goes bad, you can fix it by replacing your actuator. :) (And if you've a date in Constantinople, she's waiting in Istanbul.)
    In a Gen 3, the pump-and-accumulator are a thing, and the actuator-and-master-cylinder are a different thing, so there's a greater importance on being sure which one you're buying.
    -Chap
    #10 ChapmanF, May 2, 2018
  11. chris mcgee
    chris mcgee New Member
    north texas
    I'm just wondering if you have seen bleeding the system fix this issue? I have a 2007 with 188k miles. pump is running more than it used to but no codes or MIL yet.
  12. JC91006
    16,939
    8,647
    I just had my actuator changed at the dealer, they told me the repair was $4500 retail, billed Toyota at the warranty rate at $3500.
    The initial bleeding worked for about a month, then barking returned. So once it starts barking, prepare your wallet for a big hit
  13. chris mcgee
    north texas
    thanks for the info, selling the car as my wife just got a 2016 VW GTI to replace it (slightly worse gas mileage :ROFLMAO:). Just trying to be honest with potential buyers. Carmax only offered me $1600 for the car, but i would feel better selling to them than to an individual.
  14. JC91006
    16,939
    8,647
    There is no disclosure needed as the pump on your car is working properly. If there's a problem with it, the car would light up the dash with warning lights.
    I think you can easily get $3000 for the car if you list it for sale. Start at $3500-$4000 and settle with whoever offers you $3000+. I bet it'll sell in 1 day or less
  15. ChapmanF
    19,055
    This thread is in the Gen 3 forum. The last few posts look to involve Gen 2, but anyway:
    If you have an early Gen 3 and it makes bark/honk/quack brake noises, don't forget there was T-SB-0363-10. Check the brake ECU firmware in Techstream and if it isn't at least version F152647108 (if you have 15" wheels) or F152647128 (if you have 17"), try getting it reflashed to that version or later before you start thinking about piggy banks and wrenches.
    -Chap
    mjoo likes this.
  16. socc705
    socc705 New Member
    Sarasota, FL
    I have some good news. I sent a letter to Toyota corporate, and with all the complaints they’ve been receiving, they decided to update the Toyota Safety Bulliten to include the additional Prius’ that weren’t previously covered in the C1391 or brake issue. So my $4500 repair bill ended up being $0! I suggest everyone to take their Prius to Toyota if they hadn’t been covered before, you will now. Cheers!
    AzWxGuy, bisco and Mendel Leisk like this.
  17. bisco
    52,891
    wow, thank you!(y)
  18. Sargentjoel
    Sargentjoel New Member
    San Diego
    Do you mean they still covered the C1391 issue after the enhanced warrenty expires. Otherwise did you make the repairs after Decemeber 2017 and Toyota still covered the bill?
